I wiped my drive...help recover!! - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 11-12-2019, 05:26 PM - Thread Starter
dsa44's Avatar
Rep: 0
Major brain freeze and my error here! I have a Seagate Freeagent USB backup drive which had lots of backup stuff on it. I was getting ready to upgrade to Win10, and the media creation tool gave me the option to save the files to a usb drive.
Well you see where this is going.... I thought I could use my Freeagent USB to add the win10 install files to it for later usage. It did NOT warn me that it is going to WIPE the drive and create a bootable USB Win10 install media!!!!
So now I have the Freeagent drive with none of my backup files.
What would be the best way or tool to use to try to unformat and recover my backups and such? Preferably an open source, easy to use software, I have heard of Recuva.
I've been beating myself up over this .....
Thx
dsa44 is offline
post #2 of 12 (permalink) Old 11-13-2019, 11:41 AM
Storage Nut
Sean Webster's Avatar
Rep: 1660 (Unique: 967)
Test disk may be able to help you recover the partition and data as it was before. Or some other commercial software. But, these are backups right? That means the backup is a second or third copy...why not just re-backup the original file versions to the external?
SSD GURU
Storage Essentials | My Server Build Log
"Some say he once took a backup of the entire NSA database. Others say he lays SSDs like chickens lay eggs. All we know is, it's Sean Webster!"
Main Rig
(15 items)
Terrorbyte V2
(16 items)
i7-6700K @4.6GHz
ASRock Z170 OC Formula
Gigabyte GTX 960 WindForce 2X OC
32GB Patriot Viper Elite @2666MHz
480GB ADATA SX8200
1TB Samsung 960 EVO
2TB HP EX950
Corsair RM650
Thermaltake Silver Arrow
Fractal Design R5
Operating System
Windows 10 Pro 64-Bit
BenQ GW2765HT
BenQ GW2765HT
Keyboard
Patriot Viper V760
Mouse
Patriot Viper V560
Intel Core i7 4790K
ASUS Maximux IV Extreme
32GB (2x 16GB) Corsair Vengeance Pro @2.4GHz
2TB WD Red
2TB Samung Spinpoint F4
2TB Hitachi Deskstar 7K3000
1TB Samsung Spinpoint F3
3TB Toshiba DT01ACA300
3TB Seagate Barracuda 7200.14
8TB HGST Ultrastar He8
4TB Seagate Barracuda
Corsair 650TX
Norco RPC 4224
Operating System
Windows 10 Pro 64-bit
Other
LSI 9261-8i
Other
Intel RES2CV240
Intel Core i7 9700K @5GHz
ASRock Z390 Taichi Ultimate
16GB (2x 8GB) Kingston HyperX Predator RGB @3.6GHz
Intel Optane SSD 905P 1.5TB
EVGA 500W
Noctua NH-U14S
Operating System
Other
ASRock TB3 AiC
Sean Webster is offline
post #3 of 12 (permalink) Old 11-13-2019, 12:13 PM
Overclocker
JackCY's Avatar
Rep: 344 (Unique: 243)
I'm quite sure it does warn you. You can always make an ISO and then create a media of your choice with that.
You've overwritten part of the old data, so that is gone for the most part of any worthy effort.
JackCY is offline
post #4 of 12 (permalink) Old 11-13-2019, 12:21 PM
Bad5ector's Avatar
Rep: 3 (Unique: 3)
RIP.
I used to use OnTrack software, it wasn't free, but the UI was great. If you stopped using the drive immediately after you realized the error, you might be in luck in retrieving your backups. As long as it didn't zero out the drive (that would have taken hours to complete).
Bad5ector is offline
post #5 of 12 (permalink) Old 11-13-2019, 12:41 PM - Thread Starter
dsa44's Avatar
Rep: 0
Thx all.
After I calmed down a bit, I guess I'm not too worried, I have other backups on a raid NAS and online, just wanted to know for sure if there was anything major-league different on this Freeagent that I don't have elsewhere. I guess I will try a couple things like Recuva and Disk Drill, but to be honest, even if they find a bunch of file0001, etc, it would probably take me way too much time to figure out what they might be......sigh....
dsa44 is offline
post #6 of 12 (permalink) Old 11-13-2019, 01:39 PM
KCDC's Avatar
Rep: 27 (Unique: 23)
it's been mentioned but wanted to add that testdisk has gotten me out of some pretty hairy situations other software couldn't including failed and overwritten raid 0 arrays. Not as user friendly, but really not that difficult to use. Best part is it's free.
https://www.cgsecurity.org/wiki/TestDisk
ZMT watercool setup -- Phanteks Enthoo Elite -- hwlabs gtr 420 x 2 -- -- xspc tx360 crossflow -- noctua A14 PWM x9 -- 9900x -- x299 TUF Mk1
Corsair Hydro X XC9 -- 64gb 3200 tridentZ Royal CL14 -- AX1500i -- 2x 7600p on hyper m.2 VROC 4TB -- EK ZMT Tubing -- Ek Fittings -- dual Aorus Waterforce xtreme 2080ti -- asus PG279UZ monitors x3 7680x1440 surround
Bertha5.5
(21 items)
9900x
X2399 TUF Mk1
Aorus 2080ti Waterforce Xtreme
TridentZ Royal 3200 CL14
VROC 7600P x2
Ax1500i
HWL GTR 420 x2
XSPC TX360 Crossflow
EK ZMT 10/16
Corsair XC9
Corsair XD5
EK 10/16 Fittings
Noctua A14 PWM x9
Noctua NF-P12 PWM redux x3
Enthoo Elite
Operating System
Win 10 Pro 64
Asus PG279QZ x3
Keyboard
Corsair K95 RGB Platinum
Mouse
Corsair Nightsword
Mousepad
Corsair MM800
KCDC is offline
post #7 of 12 (permalink) Old 11-13-2019, 01:51 PM
Graphics Junkie
UltraMega's Avatar
Rep: 35 (Unique: 31)
I've had good luck with Power Data Recovery. The full version can recover from deleted partitions and all that. It's an easy to find program.
Also, lol.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
post #8 of 12 (permalink) Old 11-13-2019, 01:53 PM
StAndrew's Avatar
Rep: 13 (Unique: 9)
You didn't 'bleach' it so some (maybe most?) data can be recovered using data recovery software but the data that was written over by the window's install are not recoverable. You may find a lot of partially written and corrupted files, unfortunately.
Been there, sucks.
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #9 of 12 (permalink) Old 11-13-2019, 02:01 PM
Graphics Junkie
UltraMega's Avatar
Been there, sucks.
If the drive wasn't full, he probably wont lose anything.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
post #10 of 12 (permalink) Old 11-13-2019, 02:19 PM
Rep: 0
I currently use OnTrack software, though not free. Retrieving backups isn't much of an hassle, with this software.
victornoah is offline
Tags
data , recover
