Another home NAS build. - Overclock.net - An Overclocking Community
post #1 of 60 (permalink) Old 05-27-2012, 04:34 AM - Thread Starter
Boyboyd's Avatar
Rep: 534 (Unique: 417)
Capacity counter: 8.1 TiB.
25
I was rapidly running out of space and SATA ports in my case so i decided to build an inexpensive nas.
Recently i've started ripping my Blu-ray movies and DVD TV Series (not bothering with DVD movies. I have hundreds) to my computer, which means i fast ran out of space. Inspiration came form Murlocke's mighty 52TB unRaid server, but without the unraid. and i'm 48TB short.
It has movies / tv / download folder / documents / and a backup of my photos. There's another backup in raid1 on my sigrig.
398
old configuration (Click to show)
It's 4 2TB drives in raidZ (essentially software raid 5 but without the write hole). Giving a total useable space of about 5.3TB. I'll definitely be adding drives to make it 8x2TB raidZ2 (raid 6) when I can get 2TB drives for less than £50 each again.
Parts list:
Intel Pentium D 820 £7
Asus P5KPL-CM (support for Core 2 processors) £25
4GB DDR2 (hard to get hold of) £35
800w PSU £0
x-case RM-400-10-4u £82
4 x 2TB Seagate barracuda 7200RPM drives £328
1x 250GB WD-IDE Drive (boot) £0
Ikea lack side-table (to make a LackRack) £5.99
20m cat5e £1.99
Freenas 8 £0
Total: £485 (and most of that was HDDs)
Pictures:
Really loud 80mm fans
398
The hard drives (lol ide)
398
Temporary resting place until I get some cable clips and take it to the cellar and attach the rails to make it a lackrack.
398
The front
398
Speeds: (click to enlarge)
Watching video
428
Reading video. Edit: This read speed is bottlenecked by the speed of my steam Raid0 array. I wrote here because I thought it would be the fastest drive but evidently I was wrong.
235
Writing video
231
Small read (.NEF Photos. 30MB each)
380
Small write (.The same .NEF files)
284
New Configuration
Parts list:
Intel i3 530 £40
Asus P7P55-M mATX 1156... £35
1x4GB DDR3 19
450w PSU £25
1x 250GB Drive (boot) £0
20m cat5e £1.99
FlexRAID £38.16
Total: £575.14
Without drives: £247.14 ($394 as of 9th November 12)
Overall i'm really happy with it. It's very very loud but the fans push a lot of air through. With the door shut though I can't hear it now from the next room. Will be able to hear it even less when it's in the cellar. I'd recommend the case to anyone. Lots of room for expansion.
Here's a video of how loud it is. It's mostly the 80mm fans.
Thanks for looking.
Boyboyd is offline
post #2 of 60 (permalink) Old 05-27-2012, 05:05 AM
JCG
Rep: 77 (Unique: 57)
Looking good Boyd. It's funny how the RAM costs more than your CPU, motherboard and PSU put together tongue.gif And I'm jelly at your write speeds.
Thanks for looking.
Amen! You should probably should tidy up those wires a little bit though ..
JCG is offline
post #3 of 60 (permalink) Old 05-27-2012, 05:08 AM - Thread Starter
Boyboyd's Avatar
yeah the wires probably aren't helping airflow. I've replaced the 2 front 120mm fans with AP15s. It was NOT easy to do. I had to cut the molex connector of the old fan to get it out because of the way they've assembled the case.
That's definitely one of my priorities.
Boyboyd is offline
post #4 of 60 (permalink) Old 05-27-2012, 05:24 AM
JCG
Hahaa! Should've gone with the mid-plate version tongue.gif I had no trouble at all, although my cables are far from tidy.
450
Also, having three of them in the middle meant I could take out the two 80mm at the back, they are way too noisy for a bedroom. redface.gif The fans are Zalman ZM-F3 FDB - cost me a fiver each, but they're really quiet and push a lot of air. All drives are under 30C, and they've been under load for ~12hrs now ..
JCG is offline
post #5 of 60 (permalink) Old 05-27-2012, 05:59 AM - Thread Starter
Boyboyd's Avatar
I wanted air going straight over my HDDs because I can't check temps and i'm paranoid. So so hard to change though. easy to get the fan out but hard to get the old molex connector through.
PS have you tried to fit 5 HDDs per rack yet? They literally touch.
Boyboyd is offline
post #6 of 60 (permalink) Old 05-27-2012, 06:07 AM
JCG
I haven't, no. Only got 5 HDDs at the moment, 6th is on the way, so I'm leaving it as 3 per rack, which is probably why they're running so cool.
JCG is offline
post #7 of 60 (permalink) Old 05-27-2012, 06:09 AM - Thread Starter
Boyboyd's Avatar
Mine are in a 3 - 2 configuration. I've set up smart to email me if they go over 30, or if the temp changes by more than 10 degrees from the last email.
Now I have to just wait an hour for it to run. lol
Loving this case though, thanks for the recommendation.
Boyboyd is offline
post #8 of 60 (permalink) Old 05-27-2012, 06:10 AM
JCG
JCG is offline
post #9 of 60 (permalink) Old 05-27-2012, 06:12 AM - Thread Starter
Boyboyd's Avatar
It might have been adz. I recommended the lack rack. I'm hesitant to do it though because i've never ever had an experience with rack server chassis.
Boyboyd is offline
post #10 of 60 (permalink) Old 05-27-2012, 06:16 AM
JCG
Yeah, you brought up Lack, so it was Adz. I've never had any experience with rack-mount chassis either, and I can't for the life of me figure out how the included rails work. So I'm leaving it for now. But if you do take the plunge at some point, I demand pics/vids/instructions biggrin.gif
JCG is offline
