[Swiftech]Swiftech Boreas DIY Liquid Cooling Kits are out! - Page 3 - Overclock.net - An Overclocking Community
post #21 of 34 (permalink) Old 02-01-2019, 02:42 PM
Shooting down fallacies
ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about
ciarlatano's Avatar
Quote: Originally Posted by JackCY View Post
Why on earth would anyone buy a kit when they can choose individual parts then that fit their needs, desires and hardware, maybe this "kit" fits someones but it seems rather limiting considering how many custom cooling options there are.
While I agree with you, I can also see how doing your first loop can be a bit overwhelming, and that a kit may be less daunting and in some cases provide better value. I'm not saying that is the case for all kits, but there are some good ones out there.
Quote: Originally Posted by bfromcolo View Post
On that note once you get the larger radiator and compression fitting options, this seems to work out more expensive than the EK L360 kit by a good bit. Are any of the main components (CPU block, radiator, pump) that much better?
The pump and res are certainly a huge step up on the Swiftech. The Swiftech fittings are noticeably better quality, also. I would imagine that the EK PE rad is definitely going to have an advantage (we have no info on the Swiftech, but the PE is very good rad and thicker than the Swiftech), and we know the EK block has a small performance advantage. And if these fans are the same that they are using on the X3 AiO, they are pretty underwhelming in performance, but have nice lighting if you happen to care about that.
ciarlatano is offline
post #22 of 34 (permalink) Old 02-01-2019, 03:15 PM - Thread Starter
⤷ αC
AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about
AlphaC's Avatar
I have a similar kit, EK L360. It does a great job with my 5820k and 1070, and it has worked well for a couple years now. It's pretty mind boggling initially to figure what all matches what to do a loop for the first time, these kits make it pretty simple. I also got a EK water block for my 1070. Now that I have built a couple loops I wouldn't have any issues getting all the right parts. I also think in the EK case it works out cheaper to get it all together, than separately.
RGB sells things these days and your L360 kit didn't have a D5 pump (AFAIK only X series has it as well as EK's new RGB kit), it likely had a DDC MX 3.1.
The CPU block is probably on par, the radiator is slimmer than a 38mm PE360, pump is stronger due to being a D5.
The launch day pricing on this swiftech kit is only extremely compelling for the RGB fanatics as everything is RGB short of the radiator & fittings (block, fans, pump), it's about half the price of the EK RGB kit. It's fairly priced though.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #23 of 34 (permalink) Old 02-01-2019, 03:46 PM
Overclocker
JackCY has a spectacular aura about JackCY has a spectacular aura about JackCY has a spectacular aura about JackCY has a spectacular aura about JackCY has a spectacular aura about JackCY has a spectacular aura about JackCY has a spectacular aura about JackCY has a spectacular aura about JackCY has a spectacular aura about JackCY has a spectacular aura about JackCY has a spectacular aura about
JackCY's Avatar
Quote: Originally Posted by agatong55 View Post
DIY Kit means buy parts and do it yourself not a closed loop, These kind of DIY kits are becoming more and more popular example look here: http://www.performance-pcs.com/complete-kits
These style of kits are for those who want a loop but not 100% sure what to buy or for newbies like me who want something already package for there first time trying to do watercooling, a lot of people do not know what they are looking for at first even with help from websites and talking to people so it makes it easier to just buy a kit like these, which if you get the right one you could always expand in the future.
Sure. But then shops can already offer you kits like this of their own where they make a kit/bundle of parts that you need. It simply won't be a kit/bundle sold by Swiftech, EK etc. but can have their parts and be put together by a shop.
Same as those CPU+mobo+RAM+GPU kits or what ever combination for people who do not know what to choose "first time" or want a "better total price", these "kits"/bundles can be made by shops or AMD/Intel+partners.
I think that people building their first loop and not wanting to research their parts would rather go with prefilled parts, mount - connect - done. With these EK/Switches unfilled bundles/kits all you're saving is time spent researching what parts there are and what parts you want.
Seems weird to me to buy these bundles unless they offer better price than buying the parts separately. And that's considering the bundle actually fits your needs on all fronts, has the right CPU block, right GPU block and so on.
JackCY is offline
post #24 of 34 (permalink) Old 02-01-2019, 06:09 PM
essanbee is an unknown quantity at this point essanbee is an unknown quantity at this point
essanbee's Avatar
If you are using prefilled CLCs, AIOs, etc, you are not building a loop, you are installing a part. These Swiftech kits are full loops and expandable. My Swiftech kit has been running for over 5 years now. Zero gunk in the blocks or tubes, all I do is dust it and top it off occasionally.
Big Blue
(14 items)
Intel Core i5 2500K
P8P67 DELUXE
EVGA GTX 980 FTW
G.Skill
Western Digital WD1002FAEX-00Z3A0
Optical Drive
ASUS DRW-24B1ST
THERMALTAKE TOUGHPOWER XT 775W
SWIFTECH H20-320 EDGE HD APOGEE HD WATER BLOCK
APEVIA X JUPITER S TYPE METALLIC BLUE
Operating System
WIN7 64bit
ASUS VE258Q
Mouse
RAZER DEATHADDER 3500dpi
Audio
Creative Soundblaster Z
Other
SSD Samsung 840 EVO 250 GB for OS
essanbee is offline
post #25 of 34 (permalink) Old 02-01-2019, 09:39 PM
Sunday League Jibber
SuperZan has a spectacular aura about SuperZan has a spectacular aura about SuperZan has a spectacular aura about SuperZan has a spectacular aura about SuperZan has a spectacular aura about SuperZan has a spectacular aura about SuperZan has a spectacular aura about SuperZan has a spectacular aura about SuperZan has a spectacular aura about SuperZan has a spectacular aura about SuperZan has a spectacular aura about
SuperZan's Avatar
Regular P360 kit has a D5 as well, if I recall correctly. The DDC pump on the L360 is fine, though, if you're not trying to do anything stupid. I had a solid place to mount it and it gets plenty of cooling, so it really hasn't caused me any issue. I had to redo my loop anyway, so I picked up an L360 kit on offer at my local Microcenter and saved a bundle. It came with a PE360 so I just added a 280 and a block for the 1080 Ti and it does great with the 2700x. I'd buy differently for going nuts with Skylake-X and a pair of GPU's, but for stable everyday OC's in single-GPU systems, it's a nice little kit at the right price.
Playing with the Boreas build, I can get it close to the L360's EK website MSRP after adding the 360 rad and 100mm res options though I prefer the tubing in the EK kit. Not a bad price - for reference, at least in the US, the L360 goes for ~$300-330 on Amazon and often less at Microcenter.
Farewel happy Fields; Where Joy for ever dwells; Hail horrours, hail; Infernal world, and thou profoundest Hell; Receive thy new Possessor; One who brings; A mind not to be chang'd by Place or Time; The mind is its own place, and in it self; Can make a Heav'n of Hell, a Hell of Heav'n.
SuperZan's Doombot
(14 items)
SuperZan's YT-1300
(14 items)
AMD Ryzen 7 2700X
ASRock X370 Taichi
Zotac GTX 1080 Ti Leather Jacket Edition 11GB
G.SKILL TridentZ RGB Series 16GB (2 x 8GB) @ 3200 14-14-14-34 1T
Samsung 850 Pro 256GB SSD (Windows)
SanDisk Ultra II 480GB SSD (Games)
Seagate 2TB SSHD (Storage)
Intel 530 Series 480GB SSD (Linux)
Optical Drive
LG DVD RW
EVGA Supernova G2 850w
EK-Supremacy MX CPU Block
EK-XRES 100 + DDC Pump
XSPC Razor (1080 Ti) GPU Block
EK-CoolStream PE 360 Rad
XSPC EX280 Rad
Corsair 760T
Operating System
Windows 10 Pro
Pixio PX277 27" 1440p 144Hz DP-Adaptive Sync w/ LFC
Keyboard
JAR-OWL J1 Rainbow LED Mechanical
Mouse
Zowie FK1
Mousepad
Razor Firefly
Audio
Plantronics Rig 500e Gaming Headset
Audio
Marantz Pro MPH-1 Monitoring Headphones
Audio
S.M.S.L SD-793II Audio DAC + Headphone Amplifier
Other
Xbox One Controller
Other
Wacom Intuous S Drawing Pad (CTL4100)
AMD Ryzen R3 1200
ASRock AB350m Pro4
PowerColor PCS+ R9 380x 4GB
Samsung 8 GB (2x4GB) @ 2400
Biostar M200-240 240GB m.2 SATA SSD (Solus)
Kingston V200 128GB SSD (Windows)
WD Blue 250GB HDD
Seasonic S12II 430 Bronze 430w
AMD Prism RGB Cooler
DIYPC Cuboid-G Black/Green
Operating System
Solus Budgie
Operating System
Windows 10 Pro
Keyboard
LYILIN 2.4GHz Mini Wireless & Bluetooth Keyboard with Touchpad Mouse
Other
Steam Controller
Intel Core i7-4790k @ 4.6GHz
Asrock Z97 Extreme6
EVGA GTX 1070 SC
Corsair Vengeance 16GB (2x8GB) @ 2133 10-10-10-28 1T
Samsung 860 Evo 1TB
Optical Drive
LG DVD RW
EVGA SuperNOVA NEX 650w
Cooler Master Hyper 212 Plus
Corsair Carbide 300R
Operating System
Windows 10
40" Vizio HDTV
Keyboard
HP Generic
Mouse
Logitech Generic
Audio
HyperX Cloud
SuperZan is offline
post #26 of 34 (permalink) Old 02-01-2019, 09:49 PM
Shadowarez Level 1
Shadowarez's Avatar
What I wanted was a 420mm for my i9 7980xe and a pair of 360s in front for the Vega Fe card. But it looks like. It'll cost an astronomical amount once you add I the $400+ in fans. Not inc rads pumps res/block
Sent from my SM-G965W using Tapatalk
Shadowarez is offline
post #27 of 34 (permalink) Old 02-02-2019, 06:08 AM
News Fiend
ryan92084 Level 1
ryan92084's Avatar
Watercooling isn't cheap especially when you want to go overkill like that. No quality kit will help that.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 8
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #28 of 34 (permalink) Old 02-02-2019, 06:14 AM
Shadowarez Level 1
Shadowarez's Avatar
What surprised me most is cost of fans I Remeber buying 15 noctuas for my x79 4960 build for $150 now 10 corsair 120mm ML fans will be nearly $400. This hobby has seriously inflated
post #29 of 34 (permalink) Old 02-02-2019, 06:23 AM
News Fiend
ryan92084 Level 1
ryan92084's Avatar
Not to go too far offtopic...
There are still quality fan options for those trying to save that don't care about RGB. The new arctic P line is a good example of a fan punching well above its asking price https://www.overclock.net/forum/246-...on-thread.html Also, the ML's aren't really recommended.
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #30 of 34 (permalink) Old 02-02-2019, 06:26 AM
Shadowarez Level 1
Shadowarez's Avatar
Thought they were best for rads but there $40+ was a hard sell as Id wanted go water cooling in my corsair 1000D but that'll be next project prob end up costing a minium $3000+ for what I want.
