[Various] Radeon VII Reviews - Page 85 - Overclock.net - An Overclocking Community
post #841 of 894 (permalink) Old 03-07-2019, 05:06 AM
skline00's Avatar
Rep: 14 (Unique: 12)
WannaBe Ocer: Your Radeon VII needs a waterblock, especially since you are already running a custom loop.
The criticism and praises for this card range from the restrained to the extremes.
Having replaced a GTX 1080 water cooled with a Radeon VII in a 2700x rig and also owning a GTX 1080TI water cooled in a 5960x OCd rig, the Rad VII now "feels" like a competitor to the 1080TI. That's not a knock at the GTX 1080, a classy efficient card, but a statement that the Rd VII now has the chops to stand toe to toe with a 1080 TI. To expect it to beat or even come close to a $1200 GTX 2080TI is not in the cards.
The 2080 is a different card based upon a Turing chip. The Rad VII is close enough to it that it's hard to argue one is clearly superior over another.
The 2080 uses less power. The 2080 has ray tracing but most of the reviews indicate , that at present the 2080 isn't the best card for this. The Rad VII has double the memory and it is HBM2, but I haven't seen a test that show this to be an advantage over the 2080 with 8g DDR6.
I suspect the Rad VIIs release was a desire of Dr. SU to have the RTG division release a more powerful high end consumer card to plug the gap from Vega56/64 while the Navi group gets time to polish their chip. In addition it was a neat way to utilize marginal MI50 chips. Finally, "big" Navi" probably won't be released this year. RTG needs a Navi to compete with Nvidia's "Uber" release the GTX1660TI
WannaBeOcer has a right to express an opinion.
At least WannaBeOCer owns a Rd VII.
5960x-4.4-EK Blk|AsusRE5|16g DDR4-2400|Gigabyte GTX1080TI WB |2-500gb ssds|Win10-64|PC P&C 1200W|Thrmltake X9|3 XSPC RX480 |Dell UM3415W|Win 10-64 home
2700x-PBO-EK Blk|Asus C6H|16g-3200 FlareX|Asrock Radeon VII | Corsair MP500-480g|EVGA 850W|Thermaltake V51|2-Magicool 360 slim rads|Acer ET430 k|Win10-64 home
2600x stock H100i v2 240 AIO|Gigabyte 470|16g-3200 Flare-X|Zotac GTX1080FE|3-500g ssds|Antec 750W|Crsr 100R|BenQ3200+Oculus Rift
skline00 is online now
post #842 of 894 (permalink) Old 03-07-2019, 05:45 AM
Performance is the bible
Rep: 432 (Unique: 298)
Quote: Originally Posted by skline00 View Post
The 2080 uses less power, but not a significant amount less
The 2080 takes 30-40% less power than the VII when both at stock (depends on site, test). That is not insignificant amount considering OC headroom.
Power wise the VII is closer or above the 2080 TI.
TPU measured performance per watt, the 2080 is 40% more efficient in their overall test.
It is significant. Maybe not to you, but it exist.
Of course it can depend on the specific card and its cooler, but needing to dispense more heat in the system affects the whole system, and its OC headroom.
AMD are not power efficient for the last good several generations. We all know that, so there is no need to intentionally mitigate it as irrelevant or that it doesn't exist.
Defoler is online now
post #843 of 894 (permalink) Old 03-07-2019, 06:56 AM
ilmazzo's Avatar
Rep: 25 (Unique: 13)
Let's check a 403w 2080ti trio perf/w.................
turing oc headroom is 100mhz if lucky, are you serious?
M8
(11 items)
Otto
(9 items)
AMD Ryzen 2600X
Asrock Taichi X470
sapphire fury nitro oc
GSkill Trident Z RGB 16GB 3200 Cl14
SSD Crucial MX500 500GB
Antec HPC 850 Platinum
noctua dual fan 120
Phanteks Enthoo Pro M Acrylic
Operating System
microsoft windows 10 pro
DELL U2311H
ASUS MX34VQ
Intel Core i3/i5/i7
P8H77-I
AMD Radeon R9 200 Series
8 GB 1600
Crucial M4 256GB
Seasonic G-750
Bitfenix Prodigy mitx
Operating System
Windows 8.1
DELL U2311H
ilmazzo is offline
post #844 of 894 (permalink) Old 03-07-2019, 10:23 AM
I <3 narcissists
bigjdubb's Avatar
Rep: 204 (Unique: 129)
There is tons of overclocking headroom with Pascal and Turing, if you calculate it the right way. Just ignore the actual boost speeds at stock settings and use the numbers on the box.
My 1080ti overclocked nearly 30% using the box numbers, or 7% if I used the actual boost speeds when stock. That 7% is just slightly less than my RVII's overclock percentage of 8%. Keep in mind that the 1080ti had the benefit of an EK block and a 480mm rad while the RVII is using the factory cooler at ear bleeding volume levels. I would say overclocking headroom is fairly equal between the two on average but it will really come down to the chip on your card and not which card you bought.
Power efficiency is another story, but I will leave that to the people who really care about those things. All that matters to me is not tripping the breaker.
El Computer
(15 items)
AMD Ryzen 7 2700X
Asrock X470 Taichi Ultimate
Radeon VII
EVGA 2080ti FTW3 Ultra
G.SKILL TridentZ RGB
Samsung 970 EVO
CRUCIAL 1TB MX500 M.2
EVGA G3
CORSAIR H150I PRO
LianLi PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 32GK850G
50" Vizio 4k TV
Keyboard
Logitech G110
Mouse
G.SKILL RIPJAWS MX780 USB
bigjdubb is offline
post #845 of 894 (permalink) Old 03-07-2019, 10:25 AM
skline00's Avatar
Defoler, I stand corrected about the power draw difference between the GTX 2080 and the Rad VII.
post #846 of 894 (permalink) Old 03-07-2019, 10:52 AM
professional curmudgeon
looniam's Avatar
Rep: 761 (Unique: 441)
not disagreeing with power/performance but . . 100mhz of WHAT?
+100 over the 100mhz the AIB OCed the card to?
and then add the 30-60mhz gpu boost 3 gives you?
the reference boost clock for the 2080ti is 1545 (1635 for FE) so you're saying they all just hit 1650?
sorry you just hit a sore spot, so many times helping someone OC their maxwell card and being told +100 in AB; that could mean a clock speed of 1350 to 1550 at a given voltage; the difference between a dog and great card.
"Name as many uses for a brick as you can in one minute." - interview at graphics-chip maker Nvidia for a campaign-manager job
Fermi: it's better to burn out than fade away.
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
"The more you buy, the more you save." - Jensen Huang GTC 2018
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #847 of 894 (permalink) Old 03-07-2019, 12:51 PM
I <3 narcissists
bigjdubb's Avatar
He probably means 100mhz over the cards actual stock boost speed and not the irrelevant number listed in the specs.
El Computer
(15 items)
AMD Ryzen 7 2700X
Radeon VII
Samsung 970 EVO
EVGA G3
CORSAIR H150I PRO
Operating System
Windows 10 Pro
LG 32GK850G
50" Vizio 4k TV
Keyboard
Logitech G110
Mouse
bigjdubb is offline
post #848 of 894 (permalink) Old 03-07-2019, 02:57 PM
8051's Avatar
Rep: 20 (Unique: 14)
I wonder how much the HBM2 memory contributes to the TDP of the VII? Is this where most of the additional power draw of the VII over a 2080 comes from?
Wouldn't the HBM2 make high levels of AA practically free for the VII?
8051 is offline
post #849 of 894 (permalink) Old 03-07-2019, 03:07 PM
The Sizzler
dubldwn's Avatar
Rep: 18 (Unique: 16)
Using HBM2 lowers power draw. It's why V7s power consumption is within reason.
dubldwn is offline
post #850 of 894 (permalink) Old 03-07-2019, 03:07 PM
EniGma1987's Avatar
Rep: 327 (Unique: 240)
From what I remember HBM2 actually has fairly low power draw (25-30w), while GDDR5x and GDDR6 have pretty high power draw (around 55-60w)
According to Anandtech, the Fury X's HBM memory draw a bit under 15w. HBM2 is more efficient, but has more of it so that 25w estimate people mentioned seems like it would be accurate. They do however say that GDDR5x on a 256-bit bus is estimated around 20w, and GDDR6 is a bit more efficient. So even on a 384 bus I wouldnt think it should reach anything close to 55w. Sounds to me like the memory on R7 and 2080 may be pretty similar power?
EniGma1987 is offline
