[TPU] Noctua Presents NH-U12A Premium Class 120mm CPU Cooler - Overclock.net - An Overclocking Community
post #1 of 63 (permalink) Old 03-19-2019, 10:39 AM - Thread Starter
Forum Moderators
twerk's Avatar
Noctua today presented its new NH-U12A premium-quality quiet CPU cooler. The NH-U12A is the latest, 5th generation of Noctua's award-winning U12 series of 120mm size coolers. Conceived to push the envelope of the 120mm form factor, it combines two of Noctua's flagship model NF-A12x25 PWM 120mm fans with a completely redesigned heatsink featuring 7 heatpipes and an increased fin surface area for superior heat dissipation. This way, the NH-U12A can rival the performance of many 140mm sized coolers while offering 120mm class case and PCIe compatibility.
Link
"Everyone is entitled to their own opinion but not to their own facts"
Define
(18 items)
Intel Core i7-3770K @ 4.3GHz
Gigabyte GA-Z77X-UD5H
ASUS GeForce GTX 980 Ti STRIX 6GB @ 1500MHz
16GB (2x8GB) Kingston HyperX Fury DDR3 @ 2400MHz
Samsung 840 Pro 256GB
Crucial MX100 512GB
EVGA SuperNOVA P2 650W
Noctua NH-U14S
3x Noctua NF-A14 FLX
Fractal Design Define R5 Black
Operating System
Windows 10 Pro 64-bit
Dell U2713HM
Dell U2312HM
Keyboard
Ducky One 2 Skyline TKL (MX Browns)
Mouse
Logitech G403 Wireless
Audio
Sennheiser HD 650
Audio
Fostex TH-X00 Ebony
Audio
Parasound Zdac
twerk is offline
post #2 of 63 (permalink) Old 03-19-2019, 10:40 AM
⤷ αC
AlphaC's Avatar
Rep: 818 (Unique: 550)
NH-U12A is the first air cooler that is exciting in a long while.
It has 7 heatpipes (staggered in the airflow path) and the NF-A12x25 fan , plus it's asymmetrical.
I'm interested in the low RPM performance though : it has 2 NF-A12x25 so it should still perform decently. The fin stack looks to be increased in FPI , there's at least 50 fins.
This will likely dethrone the likes of the Prolimatech Megahalems and Scythe Mugen 5 as strongest 120mm fan coolers. It's 760g without fans and 7 heatpipes and 58mm depth; Megahalems is 790g with 6 heatpipes and 74mm fin stack depth; Mugen 5 has much thicker 85mm fin stack with 6 heatpipes but is around the same weight as well (890g with fan - 140g from 120mm Kaze Flex spec = 750g). There's some other coolers in the 120mm size but they're mostly budget oriented such as the 167mm tall Coolermaster MA610P , 165mm tall Silverstone Argon AR03 (likely press fit fins), or 165mm tall FSP Windale 6 , which opt for direct touch heatpipes and aren't as high performing.
Megahalems for comparison: http://www.silentpcreview.com/article916-page4.html
~47 fins , Fin thickness 0.5mm , 2.0mm fin spacing , 45mm clearance underneath
Mugen 5 is 39 fins, 2.0mm fin spacing and 0.4mm fin thickness
(Also for reference , the 770g NH-U14S has 0.42mm fin thickness and 1.72mm fin spacing : http://www.silentpcreview.com/article1359-page4.html , though if you don't count the low fin area fins there's 51 fins instead of 57)
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #3 of 63 (permalink) Old 03-19-2019, 01:55 PM
Otherworlder
epic1337's Avatar
Rep: 213 (Unique: 121)
$100 USD is a tad bit too much, even more expensive than the NH-D15...
could've just went with a single-fan, extra clips and put it up for $70, which would make it just $10 more expensive than the old NH-U12S.
trolling an adult is very dangerous, don't try it at home nor at work. you don't want to play tag with a rabid man.
epic1337 is online now
post #4 of 63 (permalink) Old 03-21-2019, 07:09 PM
Shadowarez's Avatar
Rep: 24 (Unique: 21)
Sadly $150+ cad for this. My corsair H150 Pro was $165
Sent from my SM-G965W using Tapatalk
Shadowarez is offline
post #5 of 63 (permalink) Old 03-21-2019, 09:49 PM
Rep: 13 (Unique: 12)
Just installed a Grand Macho RT in my M-ATX rig, it was a pretty tight fit but I think I'll be okay. This still looks very nice and the NF-A12x25 fans are nice offering - I use those on my 1080Ti and they keep it under 75 celcius at 2075 MHz without getting noisy.
t1337dude is offline
post #6 of 63 (permalink) Old 03-21-2019, 10:01 PM
Shadowarez's Avatar
I'm replacing a corsair H150 Pro with this. I can't stand the setup atm in my corsair 1000D. It's uneven with a single 360 rad would rather have my 8 Typhons up there all nice and flush. Then 3 140s in front and 2 more Typhons in back.
post #7 of 63 (permalink) Old 03-22-2019, 12:25 AM
Smug, Jaded, Enervated.
GHADthc's Avatar
Rep: 95 (Unique: 61)
Attachment 260118
You seem to be forgetting the Scythe Fuma, which uses 120mm fans, and defeats the Mugen and almost keeps up with a D15.
Forever a WIP.
(15 items)
2700X (XFR2/PBO @ 4.25Ghz ).
Asus CH7 Wifi.
GTX 1080Ti w/ Raijintek Morpheus.
G.Skill Flare-X 16GB 3200C14 (Running @ 3466Mhz C15).
Samsung 970 Evo 250GB (OS), Seagate Ironwolf Pro 6TB (250GB SSD partition+2GB Ram StoreMI setup), Kingston UV400 500GB SSD (half partitioned).
Silverstone Strider Gold 850W ST85F-GS.
Stock cooling....(Custom loop build in progress).
Silverstone TJ11 (Custom loop project)..currently in Lian Li V2000 Plus.
Operating System
Windows 10 Pro N.
Catleap Yamakasi Q270B @ 110Hz.
Keyboard
Steelseries 6Gv2.
Mouse
Zowie EC2-A.
Mousepad
Puretrak Talent.
Audio
Burson Play, Monoprice Monolith M1060C, Rode NTA1 (With Rode arm), Behringer PS400.
Other
2060mm of radiators stuffed inside/outside a TJ11 in the works + 2x D5 strong, Koolance RP-452X2, Koolance CTR-CD1224, blocks, fittings etc etc...
GHADthc is offline
post #8 of 63 (permalink) Old 03-22-2019, 07:28 AM
DNMock's Avatar
Rep: 159 (Unique: 118)
PCIE compatibility
Anyone care to explain what the heck that even means?
DNMock is offline
post #9 of 63 (permalink) Old 03-22-2019, 07:32 AM
Shadowarez's Avatar
Maybe they mean it'll not over hang the top pcie slot nearest to CPU? Mine is on way
post #10 of 63 (permalink) Old 03-22-2019, 08:25 AM
EniGma1987's Avatar
Rep: 328 (Unique: 240)
Width wise, air coolers come pretty close on the big ones to touching cards in the top PCI-E slot. This most likely means it still doesnt cover that slot area. Not that it matters much since most motherboards do not locate a 16x slot at the top, but rather a 1x slot and then a 16x. So spacing for most boards is fine even if it were to cover slot 1
EniGma1987 is offline
