[HDTVTest] Samsung To Begin QD-OLED "Trial Production" Later This Year - Page 3 - Overclock.net - An Overclocking Community
post #21 of 46 (permalink) Old 05-14-2019, 05:48 AM
News Fiend
ryan92084's Avatar
Quote: Originally Posted by EniGma1987 View Post
They have prototypes available in sizes good for smartwatches, smartphones, and all the way up to giant TVs. Size doesnt matter on whether it is doable or not.
pixel density is also a non-issue like many people seem to think. a decade ago they were already in the thousands of PPI range, and a new Canadian company also just demonstrated a 30,000 PPI micro-LED display a few weeks ago (new record). People think they can only be large because of the 4k resolution Samsung used on their "the wall" display. However mLED does not use 1 pixel on the hardware per pixel of displayed resolution. In the same manner as 1080p being displayed on a 4k monitor uses 4 hardware pixels per 1 pixel of resolution, mLED uses dozens to even thousands of hardware pixels to 1 pixel of displayed content. So pixel density and hardware resolution is extremely high, even if we still only send the display a 4k frame that our video cable supports.
Right, currently we have very small prototypes and very large in production. The question is will the small tech scale up or the big scale down to the standard 55-80" by 2023? Samsung obviously doesn't think so.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #22 of 46 (permalink) Old 05-14-2019, 08:33 AM
Frog Blast The Vent Core
Rep: 371 (Unique: 184)
Wow, what a load.
I looked into Samsung's quantum dot tech a while back, and while I was really intrigued by it at first as you can make quantum dot emissive displays, that's not what this is. It's a quantum dot absorptive filter in their products, and that's another thing entirely. Yes, it's better than an LCD panel, since you don't start with throwing half of the light away at the first polarizer, but you still are running the problem of an absorptive filter with a backlight. Emissive displays will always beat them for black levels and therefore contrast, and that applies to color contrast as well.
Sure, you can put OLEDs behind a quantum dot absorptive filter, but that's just taking one technology and then adding another that plays to its weaknesses instead of its strengths. The problem with OLED is brightness, they simply can't put out the same light levels and with the brightness they can achieve longevity becomes an issue. Putting an absorptive filter in front of it just makes everything bad about OLED worse. The alternative approach that they seem to be using, which is to use an OLED emitter that is downconverted by the quantum dots, will again lose brightness due to inefficiency in the energy transfers. So, same problem: taking an OLED with brightness issues and making it less bright using quantum dots to change the color of the backlight.
And no, they can't make an emissive quantum dot display. I ran the math a while back while I was trying to sift through Samsung's QLED marketspeak, and it would take around fifty standard semiconductor wafers to make a 75" TV out of emissive quantum dots. Completely hopeless.
Mand12 is offline
post #23 of 46 (permalink) Old 05-14-2019, 09:35 AM
mfw
ToTheSun!'s Avatar
Rep: 451 (Unique: 219)
You heard it here first, folks! It can't be done. Someone tell Samsung to halt all production.
Intel 6700K
Asus Z170i Pro Gaming
Gigabyte 2070 Super Windforce OC
G.skill Trident Z 3200CL14 8+8
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Fractal Design Core 500
Operating System
Windows 10 Education
ViewSonic XG2703-GS
Keyboard
Vortex Race 3 RGB
Mouse
Glorious Odin
Mousepad
Gigabyte AMP500
Audio
Fiio E17K v1.0 + Beyerdynamic DT 1990 PRO (Dekoni pads)
ToTheSun! is offline
post #24 of 46 (permalink) Old 05-14-2019, 09:47 AM
News Fiend
ryan92084's Avatar
They would have to start first
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #25 of 46 (permalink) Old 05-14-2019, 10:39 AM
My point was that it would never be commercially viable, which you well know.
Mand12 is offline
post #26 of 46 (permalink) Old 05-14-2019, 11:01 AM
mfw
ToTheSun!'s Avatar
Actually, I don't well know. Looking for a commercially viable semblance of an OLED competitor, that also excels where it faults, in the marketing material for QLED was never going to be very fruitful because they never meant QLED to be anything other than a different, though better, type of backlight.
We have no idea what kind of configuration they deemed potentially viable to fulfill the role they intend to surpass OLED's PQ, other than the fact that they're probably going to use a mix of organic and non-organic LED's.
Intel 6700K
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Operating System
ViewSonic XG2703-GS
Keyboard
Vortex Race 3 RGB
Mouse
Glorious Odin
Mousepad
Gigabyte AMP500
Audio
post #27 of 46 (permalink) Old 05-14-2019, 11:05 AM
So if you know so little, why the snide remark at someone who does know more and thought it helpful to share? I mean, I could go into more detail about how quantum dots work and what they're capable of doing, but I'm not inclined to throw any more bones if this is the response I get.
Mand12 is offline
post #28 of 46 (permalink) Old 05-14-2019, 11:26 AM
The Robot's Avatar
Rep: 130 (Unique: 82)
microLED or bust.
Main
(17 items)
Nintendo DS
(8 items)
6700K
Gigabyte Z170X-Gaming 3
MSI GTX 1080 Gaming X
G.Skill Ripjaws V 16GB 3000
Samsung 850 Evo 500GB
WD Blue 3TB
EVGA 650 G2
Noctua NH-D15S
Nanoxia Deep Silence 140mm
Nanoxia Deep Silence 120mm
Corsair 400Q
Operating System
Windows 10 Enterprise
ViewSonic XG2703-GS 1440p
Keyboard
Leopold FC750 (MX Brown)
Mouse
Logitech Performance Mouse MX
Audio
Mayflower Objective2 + ODAC Rev. B Combo
Audio
Audio-Technica ATH-A990Z
ARM946E-S 67.028 MHz
ARM7TDMI 33.514 MHz
4 MB
256 kB
850 mAh
Operating System
DS OS
3" 256×192 18-bit
3" 256×192 18-bit
The Robot is offline
post #29 of 46 (permalink) Old 05-14-2019, 11:52 AM
subtec's Avatar
Rep: 58 (Unique: 53)
Wow, what a load.
QD-OLED is emissive though. It sounds like you may be a little confused about what's what. Quantum dots can be used several different ways in a display. Check out this graphic:
Samsung's "QLED" TVs they've been selling for a few years (and the "SUHD" TVs before that) are the first type: traditional LCDs with a quantum dot film-enhanced backlight. This gets you a somewhat better color gamut, but doesn't do anything to fix LCD's shortcomings (contrast, viewing angles etc.)
QD-OLED, in contrast, is a variant of the photo-emissive type (2nd from bottom). This type uses quantum dots as color converters (QDCCs) on top of another display type - LCD, OLED, or even MicroLED could be used.
In this case, with QD-OLED Samsung is using OLED to produce only blue light, which is converted using QDCCs into red and green (the blue subpixels are lit by the OLED directly. An advantage of this approach is that you don't need to pattern the OLED emitters to make RGB, reducing manufacturing complexity and cost. This is similar to LG's patented WOLED approach, except that uses white OLEDs plus traditional color filters, whereas QD-OLED uses blue OLEDs plus QDCCs.
Name:	nanosys quantum dot displays.jpg
subtec is offline
post #30 of 46 (permalink) Old 05-14-2019, 12:46 PM
Yes, I talked about that aspect of it, and mentioned the efficiency hit from downconversion. Also, since they're still polarization devices, you get another 50% brightness hit. Which, when you're starting with a blue OLED, the type that has the fastest decay rate, is a major problem.
Manufacturing RGB OLED subpixels is no harder and likely easier than manufacturing quantum dot conversion subpixels, so you don't actually reduce overall complexity. The color patterning still has to happen, it just happens at a different stage.
The most efficient way to do color displays is to pattern the emitters. That's what RGB subpixel OLED does. That's not what QD-OLED is going to do. Yes, it will still achieve good black levels because you get subpixel intensity patterning, but the brightness will be abysmal. And because of the abysmal brightness, you'll have to crank up the OLED to levels where longevity will suffer. Burn-in would be the logical result, spots of your TV where the absolute intensity has to be higher are going to decay faster than the rest. It's taking an existing issue with OLED and making it worse.
It's that last line on the chart that's a legitimate competitor to OLED. Electroluminescent displays might get there, as but they don't have the brightness yet as far as I know. Maybe in that 2021-2023 timeframe they will have improved to the point of being an alternate emitter type.
As far as the holy grail, that's a fully inorganic display. Inorganic RGB-patterned emitters will be the best display technology we can get, and people have done it. Micro-LED devices are already being used by helmet-mounted displays, for example. The problem is that manufacturing costs are enormous, even for a few square inches, so only the military can afford it. And it's completely out of the question for TV sizes as a commercial product.
Mand12 is offline
