[Tom's Hardware] Thermalright Dips Foot Into AIO Liquid Cooling - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 06-06-2019, 10:45 AM - Thread Starter
sudo apt install sl
Rep: 191 (Unique: 131)
Source: https://www.tomshardware.com/news/th...0-c,39410.html
Thermalright, a long time air cooling specialist, has finally bitten the bullet and ventured into the AIO (all-in-one) liquid cooling realm. The company recently announced its Turbo Right 240 C and Turbo Right 360 C liquid coolers.
The new Turbo Right liquid cooling systems employ Thermalright's own Turbo Right CPU copper waterblock that employs 0.1mm microchannels with a large contact area for optimum liquid flow. The Turbo Right pump has been placed on the outside of the waterblock which, according to Thermalright, helps reduce vibrations and stress on the processor and motherboard. The waterblock has a transparent window where you can gaze at the rotating blade, liquid flow, coolant level and incorporated RGB lighting.
Silent
(20 items)
Core i9 9900K... CoffeeTime! @ 5.1Ghz w/ 1.36v
Maximus VIII Formula
Titan RTX @ 2100Mhz/2075Mhz
TeamGroup Xtreem 32GB 3200Mhz CL15
HP EX950 2TB
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
EVGA SuperNova 1200w P2
EK Supremacy Full Copper Clean
XSPC D5 Photon v2
Black Ice Gen 2 GTX360 x2
EK-Vector RTX RE Ti - Copper + Plexi
Thermaltake Core X5 Tempered Glass Edition
Operating System
Solus Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Alugraphics GamerArt
Audio
Definitive Technology Incline
Audio
SMSL M8A
WannaBeOCer is online now
post #2 of 11 (permalink) Old 06-06-2019, 11:54 AM
Melcar's Avatar
Rep: 641 (Unique: 441)
Hopefully they don't go crazy with the RGB. I like that it has a fill port that you can actually use, which opens up the possibility of some end-user maintenance options. Al radiator I presume? That sucks. Hopefully they come out with a 140/280/420 using TY-143SQ fans. THAT I would buy.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
CM Storm QuickFire TK
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #3 of 11 (permalink) Old 06-06-2019, 01:12 PM
Meep
Gilles3000's Avatar
Rep: 332 (Unique: 234)
Nope, looks like a copper radiator, same OEM as the Magicool G2's.
Thermalright:
Magicool G2:
Gilles3000 is offline
post #4 of 11 (permalink) Old 06-06-2019, 01:19 PM
Melcar's Avatar
That's great if true.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #5 of 11 (permalink) Old 06-06-2019, 01:27 PM
The 6502 Still Rocks
Master Chicken's Avatar
Rep: 31 (Unique: 29)
I wonder if they have to pay the Asetek royalty for this? It looks like it but they are also saying the pump is outside of the water block ... whatever that means.
Master Chicken is offline
post #6 of 11 (permalink) Old 06-06-2019, 01:28 PM
Meep
Gilles3000's Avatar
As far as I know, there isn't any other radiator that uses that end tank design, so I'd be very surprised if it wasn't.
post #7 of 11 (permalink) Old 06-07-2019, 03:53 AM
Sexagenarian
Rep: 28 (Unique: 21)
Hopefully they don't go full retard with the RGB. I like that it has a fill port that you can actually use, which opens up the possibility of some end-user maintenance options. Al radiator I presume? That sucks. Hopefully they come out with a 140/280/420 using TY-143SQ fans. THAT I would buy.
Plus 1 on the no RGB
pony-tail is offline
post #8 of 11 (permalink) Old 06-07-2019, 10:52 AM
white owl's Avatar
Rep: 136 (Unique: 103)
It's not like it's up to them. The people that want a CLC likely only want it as a platform for RGB delivery, that and becasue getting a cheap CLC makes you an elite water cooler.
The handful that actually want performance isn't a large enough market to pander to, they'd probably be better off making it as gaudy as possible. You're dealing with a market that doesn't really care about performance or noise first, obviously many of us do but we cost a lot more to satisfy...or you can make it look like a ricer and sell as many as you can make.
I'm glad TR is trying something but it's sad that they can't stand on their own making air coolers anymore, I'm sure at the same noise their air coolers will still be on par with their CLCs, it would be really hard to make a CLC that's truly better than the True Spirit 140 Power.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #9 of 11 (permalink) Old 06-07-2019, 11:07 AM
Meep
Gilles3000's Avatar
You know that this isn't a CLC right? Its a refillable and technically expandable AIO, although no specs on the pump yet so I'm not sure how much headroom there is for expandability.
The copper radiator should give it an edge over most CLC's as well.
They seem to have gone out of their way to make an attempt at a decent product, rather than be lazy and slap their name on Asetek junk like most others.
post #10 of 11 (permalink) Old 06-07-2019, 12:00 PM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
If they can price it <$200 they might be able to sell it. Copper radiator and copper CPU block isn't a standout anymore , its been done cheaply.
Right now the top contender in the AIO market is the Swiftech Drive x3 (~6W MCP pump) , with the Alphacool Eisbaer second (DC-LT pump). The~ $300 EKWB MLC Phoenix is too expensive as an AIO (despite using a 6W SPC pump) and caters to people that are lazy to fill a watercooling loop and just want something that has EK on it, essentially. Alphacool Eisbaer Extreme has the VPP75 in-house D5 pump so I don't think it is reliable and the size is a constraint as well.
The biggest problem besides availability with the Swiftech AIO is size since the reservoir takes up a lot of space under the radiator to the point it extends 90mm thickness off the top of the radiator: http://www.swiftech.com/drive-x3-aio.aspx
There's a larger gap in performance from a $40-50 decent air cooler such as the Thermalright Macho series or Scythe Mugen 5 to copper radiator of 240mm size or greater only if the pump is stronger than 6W (EKWB's lower end kits all use SPC-60 PWM which is a 6W pump). So realistically you're looking at similar performance from a $50 air cooler to a $150 AIO with 240mm radiator unless you upgrade the pump to a D5 and add a copper radiator, which pushes you closer to $350. For example, the Drive x3 280 or 360 kit is around $160, Eisbaer (or LT) is around $150 for 240/280/360 radiator.
At its core, what you have is a $50-70ish MSRP CPU block , $50-70 MSRP radiator, $30-150 pump+reservoir (most of the cost comes from here), and $30-50 in fittings/fluid/tubing. Fans usually are cheap unless it's a higher end unit ; you can get Arctic P12 for example for <$5 each.
From thread on OCN: https://www.overclock.net/forum/246-...rmalright.html
There's speculation that it is a Raijintek Orcus rebrand with their fans. This means a 2W 5000RPM pump, so don't expect amazing things. 66 L/h max flow rate is in line with the DC-LT pump.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
