[Various] Radeon RX 5700 XT and 5700 reviews - Page 127 - Overclock.net - An Overclocking Community
post #1261 of 1335 (permalink) Old 09-10-2019, 10:46 AM
bucdan's Avatar
Rep: 202 (Unique: 181)
Quote: Originally Posted by PontiacGTX View Post
if you go with a reference card look on some alternative cooling then, I dont like the temperature under load, also Vega has to get cool enough to perform properly otherwise you will end with a card slower than benchmarks...but if this is for raw compute application yeah doesnt matter much it is fine but still temperature have to be under control, I have had a Vega 56 ref cooler and it overheated (not sure if this is a problem specific to this model) and ended performing like my R9 FURY due to the temperature.. so hotspot has to be below 100c and the core temp below 75c to perform fine
I guess I'll patiently wait for a Navi sale somewhere (it isn't for me). Thanks. I'm waiting for big Navi as well. Itching for that [email protected]/144 performance.
Computer viruses are like herpes. You never think in a million years you'd get one... Till you do.
bucdan is offline
post #1262 of 1335 (permalink) Old 09-10-2019, 04:38 PM
diggiddi's Avatar
Rep: 106 (Unique: 86)
Quote: Originally Posted by bucdan View Post
Yeah, reference cooler. Was thinking UV+OC. There's pretty much no non reference cards for Sub $250, pretty much gets into the territory of the RX 5700. V56 Reference can be had for as cheap as $200.
Where are you seeing those prices? I'm looking for a used Vega can't find anything on Amazon(I have giftcard)
But can it run.... Angry Birds???
About the NVidia GTX 970
"When comes down to it, it's really a $250 card with lies printed all over the box."--Rexer
diggiddi is offline
post #1263 of 1335 (permalink) Old 09-10-2019, 08:07 PM
treetops422's Avatar
Rep: 7 (Unique: 5)
Vega 56 was down to $270 for almost 6 months, but it shot up recently on Newegg, Amazon new, likely because of bit coin prices rising. They are great miners. However you can get a used card for about $220 used on Ebay. Never seen a new one at $200.
https://www.ebay.com/sch/i.html?_fro...rt=nc&LH_BIN=1
You can get a new 5700 non XT for $330
https://www.amazon.com/Sapphire-Rade...gateway&sr=8-5
Amazon used prices usually suck compared to Ebay. Maybe you can exchange it for an ebay card or sell it for cash idk. Or wait for low end, prices might also go down again.
https://www.google.com/search?client...bitcoin+prices
Sapphire Radeon RX 5700 Blower, Ryzen 2600 4.0 ghz, AIO Cool Mast Seidon 120mm, 3200 ddr3 cl16, B450m Asrock Pro 4 Mobo, 700 Watt PSU.
treetops422 is offline
post #1264 of 1335 (permalink) Old 09-11-2019, 07:16 AM
buttface420's Avatar
Rep: 18 (Unique: 16)
has anyone found any successful aftermarket cooling for the 5700xt that is not a waterblock? was gonna get a g12 or a frostflow or even a accelero extreme iv but after watching a couple youtube vids it seems none of those are even working right because hotspot is skyrocketing?
buttface420 is offline
post #1265 of 1335 (permalink) Old 09-11-2019, 07:36 AM
new to OCN?
PontiacGTX's Avatar
Rep: 1542 (Unique: 926)
PontiacGTX is offline
post #1266 of 1335 (permalink) Old 09-11-2019, 07:37 AM
new to OCN?
PontiacGTX's Avatar
2nd hand on ebay or maybe on craiglist or...
post #1267 of 1335 (permalink) Old 09-11-2019, 07:45 AM
Portgas D. Ace
keikei's Avatar
Rep: 311 (Unique: 238)
Morpheus cooler maybe?
PCMR
(18 items)
AMD RYZEN 7 1700
ASROCK TAICHI X370
ASROCK RX 570
G.SKILL Ripjaws V Series 16GB (2 x 8GB) DDR4 3200
WD Red 4TB NAS HDD (x2)
8TB Seagate Barracuda HDD (x2)
SAMSUNG 860 EVO SSD 1TB
WD Blue SSD 2TB
EVGA SuperNova 1300 G2
Noctua NH-U14S (CPU COOLER)
Cooler Master JetFlo 120mm Blue LED Fan (X6)
LIAN LI PC-V760B
Operating System
WINDOWS 10 64
Dell UltraSharp UP2718Q - LED monitor - 4K - 27"
Keyboard
VORTEX POK3R WHITE EDITION
Mouse
LOGITECH G305 WIRELESS GAMING MOUSE
Audio
Sennheiser HD 598 Cs Headphones
Other
Real Arcade Pro. 4 Kai Joystick modded
keikei is online now
post #1268 of 1335 (permalink) Old 09-11-2019, 07:58 AM
Rep: 7 (Unique: 5)
You need to know where the memory is at, so your fan(s) on say the g12 are hitting the hot points. The normal fan bracket is way off. I have the non XT. But it's the same layout. For the most part you need to aim at the black squares around the core. (some grey in this pic). I put some old cpu fans in the 2nd pic up on it and it did pretty good without any heat sinks. You can zip tie whatever fan(s) you use with a aio to hang around the hot spots. If you want to slap your Blower fan back on with a cardboard shroud, combined with a AIO.... You can get some amazing temps even without heat sinks.
I'm moving a lot of stuff around so it's all sloppy atm. Don't use tape on any hotspots if you do make a cardboard shroud, you can zip tie it.
post #1269 of 1335 (permalink) Old 09-11-2019, 08:13 AM
lol this is amazing on so many levels..never thought of a cardboard shroud lmao, got me thinking about cutting some thin plexiglass/plastic sheet and making my own!!!!
this is something i considered, if it works out well like he said in the video this may be the best option, my only worry is how good is a chinese aio and when is it gonna start leaking? otherwise this is perfect.
post #1270 of 1335 (permalink) Old 09-11-2019, 08:35 AM
Rep: 7 (Unique: 5)
Just remember the little half curve for the blower around the intake circle. You can see it on the plate if you decide to copy it. I made a quick one, you can kind of see it the pic. Really simple stuff.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
keikei
