[EKWB] EK Releases Meltemi 38mm thick 120mm fan - Page 3 - Overclock.net - An Overclocking Community
post #21 of 71 (permalink) Old 08-23-2019, 09:44 AM
Smug, Jaded, Enervated.
GHADthc's Avatar
Rep: 101 (Unique: 66)
Quote: Originally Posted by epic1337 View Post
the massive fan hub basically ruined its potential, it could've gained far more airflow with minimal loss in pressure if the hub was smaller.
the only way this fan can outperform all other fans is when its used in super-high fin density radiators.
And that is exactly what its meant for....you don't go buying 38mm thick fans unless you are using EK XE, HWL GTR or Koolance high FPI rads, or else there is no point.
Which is odd, there must be a very select few people that fall into the niche within a niche, that will forgo the silence that people generally strive to attain when going with watercooling, and go for all out performance regardless of the noise generated (I once had a high FPI 480mm radiator with a 40mm thick fesser shroud, and then 38mm Scythe Ultra Kaze 3000rpm fans on it, in my first loop...it was overkill and unnecessary to say the least...).
2700X (4.3GHz All-Core).
Asus Crosshair VII Hero Wifi.
Inno3D 1080ti X2 w/ Raijintech Morpheus 2100mhz/11200mhz.
G.Skill Flare X 16GB(2x8GB) 3200 mhz CL14 OC'ed to 3533Mhz CL14.
Samsung 970 Evo 240GB M.2 NVME (OS Drive), Kingston 500GB SSD, Seagate Ironwolf 6TB HDD (StoreMI, 250GB SSD Partition+2GB RAM fast cache).
Silverstone 850W Strider Plus.
Custom water-loop in the works.
Silverstone FT02.
Operating System
Windows 10 1903.
Catleap Yamakasi Q270B (Overclocked to 110Hz).
Keyboard
SteelSeries 6Gv2.
Mouse
Microsoft Intellimouse Pro w/ GT-5000 grip-tape, CeeSa paracord cable.
Mousepad
Artisan FX Shidenkai XL.
Audio
Burson Play, Monoprice M1060C (modded), Audio-Technica ATH-A900X, Rode NTA-1 w/ Rode arm, Behringer PS400.
GHADthc is offline
post #22 of 71 (permalink) Old 08-23-2019, 10:35 AM
skupples's Avatar
Rep: 630 (Unique: 342)
Quote: Originally Posted by ToTheSun! View Post
Hold up a minute! How do you know it wasn't the right gentle typhoons in the wrong boxes?
cuz they were the 14s in 15 boxes
they ramp up to slightly lower speeds.
skupples is offline
post #23 of 71 (permalink) Old 08-23-2019, 12:34 PM
New to OCN?
PontiacGTX's Avatar
Rep: 1543 (Unique: 926)
Quote: Originally Posted by AlphaC View Post
$36 , it better be darn good.
at least if they were F4/FF models they would be quite good but for this much or adding 5-15 more you can get 3 high pressure fans
Quote: Originally Posted by PureBlackFire View Post
I'd expect better cfm and static pressure from 38mm fans almost $40 each. I've seen similar and better specs in fans half the price.
https://koolance.com/fan-120x38mm-116cfm
PontiacGTX is offline
post #24 of 71 (permalink) Old 08-23-2019, 12:50 PM
Overclocker in training
ThrashZone's Avatar
Rep: 118 (Unique: 79)
Hi,
No rgb so what's with the price right ek with the same buttugly looking front :/
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #25 of 71 (permalink) Old 08-23-2019, 12:52 PM
New to OCN?
PontiacGTX's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
once they became popular they are just selling a brand it seems.. I mean there is no reason to spend 30 on one when there are far better for 1/3 the price
post #26 of 71 (permalink) Old 08-23-2019, 12:55 PM
ThrashZone's Avatar
Hi,
Indeed dirt cheap non rgb corsair ML's are a far better price, better fan too, higher rpm as well 2k and 2 pack is the same price I believe.
Here's the rgb's
https://www.newegg.com/corsair-co-90...82E16835181111
Hi,
Amazon for the 2 pack 120mm 31.41
https://www.amazon.com/Corsair-Premi.../dp/B01G5I6MRK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #27 of 71 (permalink) Old 08-23-2019, 01:59 PM
DNMock's Avatar
Rep: 171 (Unique: 125)
Quote: Originally Posted by skupples View Post
if I remember correctly, supply issues were already cropping up by the time I ordered, which is easily 6+ years ago now. I ended up driving over to Perf-PC to pick up an entire box full . I have 40 of that box left, and all 40 have ran near 24/7 since, and all but one are as quiet as day one.
folks were even getting the wrong gentle typhoons in the right boxes @ one point. I have a few of these. The easy tell is one came with white tips, the others black. I just don't remember which is which now.
About 3 or 4 years ago someone picked up the same Nidec Servo fans that were getting branded as the GT15's. I forget who it is off the top of my head, but you can get them on Performance PC's.
That said, my GT15's started dying off last year and I replaced them with Silent Wing high static pressure fans and they have been working fabulously. Just as good as GT15's if not better imo.
On topic: It's hard to make a case for expensive fans like this since the best application seems like it would be highly space constrained cases where you can't fit much rad space, and in that case the 38mm thickness would likely be problematic. On the other end of the spectrum if it's all about performance, slapping 4 180mm Silverstone AP fans on a 1080mm MORA-3 will give you all the performance you can muster on a single power outlet and do it cheaper than these expensive little boogers can.
DNMock is offline
post #28 of 71 (permalink) Old 08-23-2019, 02:35 PM
skupples's Avatar
if I remember correctly, they're still available in lots of 1,000 so that doesn't surprise me. I'd guess there's just no Scythe / Nedic shared branding or whatever.
also, if I remember correctly - they were less than $20 a piece when I got mine.
skupples is offline
post #29 of 71 (permalink) Old 08-23-2019, 03:06 PM
bucdan's Avatar
Rep: 202 (Unique: 181)
Watch this product start the next hype of 38mm fans again, RGB anyone?! I'll stick to the ole Panaflo 38mm I have running since 2009.
Computer viruses are like herpes. You never think in a million years you'd get one... Till you do.
bucdan is offline
post #30 of 71 (permalink) Old 08-23-2019, 05:11 PM
Eh, Wha?
Zero4549's Avatar
Rep: 722 (Unique: 533)
So.. whats the point?
The only thing this has over the venrable old Panaflo is PWM, and if you want PWM at the cost of all else, Delta's been providing that for years with proven reliability and a lower price point.
Systems: Fukurou | Prodigy | Tempest | ArcaneServers: Minecraft SMP | Logs: Build Log - Arcane | Video Logs: Project Arcane
Quote:Originally Posted by Zen00 https://www.overclock.net/img/forum/go_quote.gifZero, you are a master story teller, I am sleep now. http://files.overclock.net/images/smilies/thumb.gif
Arcane
(33 items)
Sanctum
(9 items)
Fukurou
(14 items)
Core i7 980x
GIGABYTE GA-EX58-UD5
MSI GeForce GTX 1080TI DUKE
MSI GeForce GTX 680 Lightning
Kingston HyperX T1
Samsung 840 EVO
WD Caviar Black FASS
Plextor M5S
WD Velociraptor
WD FALS
Optical Drive
Sony DVD Burner w/ Lightscribe
Optical Drive
LG Bluray + HDDVD
EVGA 1000 P2
Black Ice GTX 360
Black Ice GTX 240
Cooler Master HAF 932
Operating System
Windows 10 Pro (64)
X-Star DP2710
ASUS VK266H Black 25.5" 2ms LCD
Keyboard
X-Armor U9BL (Mech)
Mouse
Razer Deathadder Chroma
Mouse
Cougar Control
Audio
ATH-A900X
Audio
Maudio AV-40
Audio
Polk PSW-10
Audio
Zalman Mic-1 (Clip-on Mic)
Audio
Sound Blaster X7 LE
Other
Logitech G13
Other
Wacom Intuos 3
Other
Modded PS4, PS3, Xbox 360, and Logitech PC Controllers
Other
Thrustmaster T.16000M FCS HOTAS
Other
Rocketfish 720p Webcam
Other
Scythe "3-Foot Switch"
Ryzen 7 1700
MSI B350M Mortar Arctic
RX Vega 64
G.Skill TridentZ
Samsung EVO 960
Consatellation
Corsair HX 1050
Raijintek Aeneas White Window
Operating System
Windows 10 Pro
Core i5-661
GA-H55-USB3
12GB DDR3 1333
WD Caviar Black AALS 640GB
WD Caviar Green EARS 2TB
Vertex Turbo 60GB (SSD)
Optical Drive
Samsung Blu-ray, Samsung DVD Burner
Seasonic X750 Gold
H50 (With push/pull nocturas)
CM690 II
Operating System
Windows 10 Professional 64
LG 47inch LED LCD
Keyboard
Saitek Eclipse Lite-touch Wireless
Audio
Passive bookshelfspeakers + amp.
Zero4549 is offline
