[TechSpot]Intel to introduce advanced cooling solution for laptops at CES 2020 - Page 3 - Overclock.net - An Overclocking Community
post #21 of 29 (permalink) Old 01-04-2020, 07:45 PM - Thread Starter
speed_demon's Avatar
Rep: 95 (Unique: 74)
I'm running with a liquid metal repaste & an elevated four-post riser deal to drop temps all the way down to just 75c load on a 4c/8t i7 7700HQ (8300H really but it's the same deal) laptop. I used to get antsy when I saw temps spike past 60c on my desktop - This new style of heat output took some getting used to.
Quote: Originally Posted by Rayleyne View Post
I mean my laptop has a fully fledged 8700k at 5ghz and runs just fine...
My Clevo/Sager has a desktop 6700K and it runs lightyears cooler than my Dell G7 w/8850H did. Hugely different cooling setups between them.
Quis custodiet ipsos custodes?
speed_demon is offline
post #22 of 29 (permalink) Old 01-06-2020, 12:29 AM
8051's Avatar
Rep: 26 (Unique: 20)
Really? For how long does it run at 5 Ghz. without throttling? Did you have to lower uncore to the floor to do it? Or do you only run it at 5 Ghz. from inside a walk-in freezer?
8051 is offline
post #23 of 29 (permalink) Old 01-06-2020, 10:09 AM
Otherworlder
epic1337's Avatar
Rep: 220 (Unique: 127)
5Ghz on idle is completely doable on an anemic cooler.
load? maybe on one core at ~20% usage.
trolling an adult is very dangerous, don't try it at home nor at work. you don't want to play tag with a rabid man.
epic1337 is offline
post #24 of 29 (permalink) Old 01-26-2020, 02:19 PM - Thread Starter
If he has a Clevo which is pretty likely given that it's one of the few laptops with a desktop socket - Then he's probably not running nearly as hot as you'd expect. The P750DM will run a desktop 6700K @ 4.8Ghz and keep it surprisingly cool. The extra 2 cores and 200mhz shouldn't make all that much of a difference.
Pics of a Clevo's to-the-extreme 7x heatpipe heatsink -
post #25 of 29 (permalink) Old 01-26-2020, 02:54 PM
Meep
Gilles3000's Avatar
Rep: 313 (Unique: 227)
Quote: Originally Posted by ToTheSun! View Post
Sure, but I meant from Intel for, uh... their own products. AMD's coolers work reasonably well.
Bit late, but Intel already has a more advanced "stock" cooler, they just don't include it with anything...
Its the BXTS15A which has a vapor chamber in the center with proper fins surrounding it.
Gilles3000 is offline
post #26 of 29 (permalink) Old 01-26-2020, 03:26 PM
TheBDK's Avatar
Rep: 21 (Unique: 17)
I grabbed an xbox cooler back in the day, it still cools my laptops. All you need is a fan at the bottom. The bigger the better.
TheBDK is offline
post #27 of 29 (permalink) Old 01-27-2020, 10:15 AM
thegreatsquare's Avatar
Rep: 319 (Unique: 272)
I'm still using the original thermal paste on my 5yo GT72 with an OC on the 980m 8gb and a small one on the 4710hq. There's a turbo button for the fan, but these temps are stock fan after an hour of FO4 [9grids in ini].
[Edit]
Quote: Originally Posted by Imglidinhere View Post
It's not normal to have to repaste every three months because the TIM burns out.
What TIM are you using?
Can anyone explain to me why MSI needs our laptops back on top of the wholesale price they're already more or less recouping from us with their GT72(s)/GT80(s) trade in program? MSI isn't a company you can trust!
thegreatsquare is offline
post #28 of 29 (permalink) Old 01-28-2020, 09:35 AM
8051's Avatar
"The extra two cores and 200 Mhz. shouldn't make all that much of a difference." Have you ever tried to bring an 8700k up to 5 Ghz.? The shared, 4 heatpipe design of that cooler wouldn't stand a chance.
8051 is offline
post #29 of 29 (permalink) Old 01-28-2020, 09:50 AM - Thread Starter
That's just goofy because the latest generation using this chassis has the i9-9900K & RTX 2080 and users are overclocking those. And I assure you the 9900K produces more heat than an 8700K.
https://xoticpc.com/collections/sage...g750-p750tm1-g
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
geoxile , Iridium31
