[TechSpot]Intel to introduce advanced cooling solution for laptops at CES 2020 - Page 5 - Overclock.net - An Overclocking Community
post #41 of 57 (permalink) Old 02-02-2020, 06:30 AM
8051's Avatar
Rep: 27 (Unique: 21)
Quote: Originally Posted by nailghaar View Post
"We stress the laptop with synthetic loads to identify for any potential throttling or stability issues. When running Prime95, the CPU will run as high as 4.7 GHz for the first few seconds until reaching a core temperature of 88 C. Thereafter, clock rate drops to a steady 4.5 to 4.6 GHz in order to maintain a cooler core temperature of 83 C."
Source
The laptop in question is running a 9900k so I'm inclined to believe that an 8700k could run at 5 Ghz without throttling depending on the workload.
"Depending on workload" being the operative phrase. An 8700k at 100% load and 5.0 Ghz.? Only in your delusions. I'd bet you couldn't even get 75% load without throttling.
Airflow has as much to do w/how well a given heatsink works as well as the heatsink itself and both of those factors on any laptop are going to be severely restricted vis-a-vis practically any tower setup anywhere.
On another note, how well is the VRM circuitry on this laptop going to hold up to 130 Watts? Or are those MOSFET's going to be burning up?
8051 is offline
post #42 of 57 (permalink) Old 02-02-2020, 10:21 PM - Thread Starter
speed_demon's Avatar
Rep: 98 (Unique: 77)
Ignorance is preferable to error, and he is less remote from the truth who believes nothing than he who believes what is wrong.
- Thomas Jefferson
Quis custodiet ipsos custodes?
speed_demon is online now
post #43 of 57 (permalink) Old 02-03-2020, 04:36 PM
8051's Avatar
- Thomas Jefferson
And proof is better than speculation, so let's see the proof.
8051 is offline
post #44 of 57 (permalink) Old 02-03-2020, 04:49 PM
LTSC Consiglieri
skupples's Avatar
Rep: 648 (Unique: 349)
i made the mistake of picking up one of the first dual core laptops. VRMs got hot enough to melt it to my desk @ school
luckily, getting it replaced via rma very few months wasn't much of an issue.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is online now
post #45 of 57 (permalink) Old 02-03-2020, 07:48 PM
Rep: 0
Here's a video proving you wrong:
And here's another proof:
Source: http://forum.notebookreview.com/threads/the-mighty-clevo-p870dm-g-phoenix-gets-an-8700k-and-gtx-1080-upgrade.814711/page-53#post-10744834
If you need more proof, feel free to dive into the countless threads in notebookreview.com regarding overclocking Clevo laptops. Or, you could just keep believing whatever it is that you wanna believe.
nailghaar is offline
post #46 of 57 (permalink) Old 02-07-2020, 01:00 PM
Zfast4y0u's Avatar
Rep: 4 (Unique: 3)
i wouldnt be supprised he moded his desk to pump AC air into it like some ppl did with their laptops while ''benching''. there is no way in hell he has 8700k at 1.3v @5GHZ in 70c on freakin air, just **** xd
Zfast4y0u is online now
post #47 of 57 (permalink) Old 02-17-2020, 02:18 PM
trents2019's Avatar
Rep: 0
In an earlier post in this thread someone advocate using liquid metal TIM to produce better cooling in a laptop.
Liquid metal tends to "pump out" from between the two surfaces with heating and cooling cycles which, in a laptop, tend to be more exaggerated than on a desktop CPU. I wouldn't want liquid metal spilling over onto other electronic components nearby.
CPU: R7 2700X stock
Motherboard: MSI B450i Gaming Plus AC
Memory: GSkill Platinum Z 3200
GPU: Rx580 Saphire Nitro
Cooler: CM MasterLiquid 240
"The thief comes only to steal and kill and to destroy. I came that they might have life and have it abundantly." John 10:10
Last edited by trents2019; 02-17-2020 at 02:23 PM. Reason: forgot to include the quote from the post I was responding to
trents2019 is offline
post #48 of 57 (permalink) Old 02-17-2020, 07:12 PM - Thread Starter
That was probably me mentioning it. When applying the LM you need to create barriers to prevent runoff. In some cases you also need to seal nearby components with a high temp potting application. It's definitely not something for the faint of heart.
post #49 of 57 (permalink) Old 02-17-2020, 07:14 PM
LTSC Consiglieri
skupples's Avatar
you're using too much LM
you gotta pulllllllllllllllllll it out from that tiny dot.
hmmm... or just switch to those solder pads from extremeRigs or whatever it was.
post #50 of 57 (permalink) Old 02-17-2020, 08:38 PM
Not a linux lobbyist
rluker5's Avatar
Rep: 51 (Unique: 38)
But you can save time using the pea method ;P
L5
(17 items)
Lea2
(11 items)
L7
(11 items)
5775c
Maximus VII Hero
Aorus 1080ti Waterforce
16 Gb Gskill Trident @ 2400,cas10,1.575v
8 Gb Gskill Trident @ 2400,cas10,1.575v
1Tb Team ssd
seagate barracuda 3T
Optane 900p 480G OS
Optical Drive
Asus BW-16D1HT
EVGA Supernova 1300 G2
Cooler Master MasterLiquid Pro 120 (cpu)
2 140mm case fans, 2 120mm
Fractal Design R4 (no window)
Operating System
W10 64 pro
panasonic TC-58AX800U
Audio
Focal Elear, Nova 40, 598se, HE4xx, DT990pro w b.boost earpads
Audio
SoundbasterX AE-5, onboard
4770k
Asus Z87 Deluxe
Fury Nitro
8Gb klevv urbane 2133
ROG Raidr 240Gb pcie
1Tb WD blue
Pc Power&Cooling silencer Mk2 950w
Deepcool Lucifer V2
DIYPC P48-W
Operating System
W10 64 pro
40"tv
4980hq
Asus H81T/CSM
8Gb 1600 samsung
Samsung 850 evo 120gb
Skyvast 90w brick for hp pavilion something
SilverStone Tek Super Slim
SilverStone Tek PT13B
Operating System
W10 64 pro
24" samsung 1080p
Keyboard
Logitech K400+
Other
Intel wifi ac card and noname antennas
rluker5 is offline
