[PCPer] Corsair Introduces The A500 CPU Air Cooler - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 01-09-2020, 03:49 AM - Thread Starter
Meep
Gilles3000's Avatar
Rep: 313 (Unique: 227)
CORSAIR RETURNS TO AIR COOLING WITH THE A500
The A500 is a very substantial cooler, with fans the cooler is 144 x 169 x 171 mm. The cooler (with fans) weighs in at 1460g / 3.2 lbs, which is more than large coolers such as Noctua’s NH-D15 (1320 g). ...
An interesting feature of the A500 Dual Fan CPU Cooler is the “slide-and-lock” fan mounting system, which allows for variable mounting height of both fans to accommodate tall memory modules. With other coolers this generally involves manually placing and clipping fans higher up on the heatsink, which is hardly ideal (and sometimes problematic). This slide-and-lock system, which uses a ratcheting mechanism, sounds like a nice innovation.
The included ML120 fans are part of CORSAIR’s magnetic levitation series, and are PWM fans with a wide 400 – 2400 RPM range. ...
The CORSAIR A500 Dual Fan CPU Cooler retails for $99.99 USD and is currently up for pre-order on CORSAIR’s site with availability “in 1 week”.
Source
Product page
The design is pretty nice, and it seems to come with some good fans and its ratcheting fan mounts are simply amazing. But the size and price is pretty rough for a single tower; dual 120mm cooler.
Still happy to see newcomers in the air cooling space, hopefully it performs well enough.
Gilles3000 is offline
post #2 of 12 (permalink) Old 01-09-2020, 04:01 AM
Tetrapyloctomist
Aenra's Avatar
Rep: 37 (Unique: 23)
So basically the old A70, with almost the same concept behind fan securement; sole difference that this time they're slided down rather than snapped on a plastic housing.
Amazing stuff.
But they added a faux-plated cover on top, so i guess that's enough to elevate it up to 'new'. Mmk..
For that pricing, why would anyone bother; i already have a better air cooler (or could acquire one had i been looking), with lifetime platform mounting support; and chances are it performs better as well.
I know people will go out and get this, sure, i just.. as always, fail to relate frankly
Pride, honour and purity.
Aenra is online now
post #3 of 12 (permalink) Old 01-09-2020, 09:50 AM
EniGma1987's Avatar
Rep: 342 (Unique: 252)
Its nice that it looks nice. That is 90% of what matters.
EniGma1987 is offline
post #4 of 12 (permalink) Old 01-09-2020, 10:49 AM
DNMock's Avatar
Rep: 171 (Unique: 125)
Amazing stuff.
one word: Aesthetics
DNMock is offline
post #5 of 12 (permalink) Old 01-09-2020, 11:15 AM - Thread Starter
Meep
Gilles3000's Avatar
Amazing stuff.
C'mon dude, give some credit where credit is due. The old A70 has those terrible fixed height plastic clips that clipped straight onto the fins. that's worse than even the 212 evo clips, they're arguably worse than most wire clips. Its not "almost the same"
These ratcheting clips are by far the nicest solution I've seen for fan securement on an air cooler.
The heatpipe config looks nicer than the A70 as well, and it has a way flatter base. Although I very much doubt their choice of 2 fat + 2 regular heapipes is going to pay of as much as they hope, especially for that price.
Its easy to be cynical but at least its a step in the right direction...
post #6 of 12 (permalink) Old 01-09-2020, 11:30 AM
Vandelay Industries
maltamonk's Avatar
Rep: 79 (Unique: 60)
$100 no ty
maltamonk is offline
post #7 of 12 (permalink) Old 01-09-2020, 05:54 PM
Tetrapyloctomist
Aenra's Avatar
Gilles..
It's a cooler with nothing to boast of in terms of cooling. What it has to boast is "looks" (and this is a cooler, so frankly, give me a break if you think "looks" should enter the cooling situation) and, which i mention myself, an "improved" fan attaching solution.
Is that of such an import to you? By all means then, go and buy one when it's out.
For me, it's not; simple. For one, i've both hands functioning and can manage with traditional clips just fine; two, said solutions almost always involve either compatibility issues with fan casings or one's inability to add extra fans due to the very casing required for said fans to slide/clip on; three, said solutions usually don't leave much room for vibration dampening.
All that on top of a subpar cooler that is expected to cost about as much as other 'top' ones. One of which, i will mention this again, is a onetime purchase, given its lifetime support.
And you call me cynical for failing to grasp why folks don't ignore this..
And this is what you call and i quote "a step in the right direction"..
Respectfully disagree
That folks care about the looks of internal components, that folks care about looks inside a chassis that is additionally all about looks? That's their problem, not mine. Said it a million times, we can all like or have a tendency towards dumb or insensible things. Problem only arises when we're no longer capable of admitting, if only to ourselves, that said predisposition IS dumb, just.. hey, we do it anyway.
Am not being cynical here. Am being rational. If you or anyone else has gone so far that you're by now incapable of grasping the difference between the two? Not my fault.
Aenra is online now
post #8 of 12 (permalink) Old 01-09-2020, 06:52 PM
m4fox90's Avatar
Rep: 13 (Unique: 11)
MSRP $99? How many $50 towers is this going to be outperformed by?
Silence in the Snow
(12 items)
Ryzen 3900X
ASRock X370 Taichi
RTX 2080Ti Black Edition/Hydro Copper
G.Skill RipJaws V 16 GB
Samsung 960 EVO 500GB
2x WD 1 TB SSD
EVGA G3 1000W
EK PE360 + Hardware Labs Black Ice GTS360
EK Supremacy EVO
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Home
Predator XB271HU
m4fox90 is offline
post #9 of 12 (permalink) Old 01-09-2020, 07:16 PM
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
Rep: 162 (Unique: 127)
aluminum base
nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴ
TK421 is offline
post #10 of 12 (permalink) Old 01-09-2020, 08:03 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 610 (Unique: 503)
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
Fractal Design Arc Midi R2
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
