[PCGamer] After overheating concerns, Asus is helping RX 5700 owners tighten their screws - Page 5 - Overclock.net - An Overclocking Community
post #41 of 45 (permalink) Old 02-26-2020, 02:17 PM
TheBDK's Avatar
Rep: 24 (Unique: 20)
Quote: Originally Posted by qwertymac93 View Post
I've never seen torque be measured in PSI. Usually I see lb/ft or N*m. Did they mean to measure clamping force? In that case, couldn't the same screws be used and only the springs be replaced? Torque is mainly used to prevent screws from loosening over time, not for measuring clamping force. At least, not with screws these small and weak. If we were talking wheel studs it'd be a little different.
Yeah psi is pressure (usually air). Torque is nm. I'm no expert ..
TheBDK is offline
post #42 of 45 (permalink) Old 02-26-2020, 02:26 PM
What goes here?
speed_demon's Avatar
Rep: 120 (Unique: 88)
Pressure is the force the molecules of something are exerting external to them.
And torque is the measure of force being applied to an object, you could also call it the amount of twist on something relative to its center line. We have a couple of different metrics to measure it. My last truck had something like ~700 Lb-Ft of torque.
I'm no expert either.
And you can find plastic washers at most mom n pop hardware stores. I found them way out in the boonies for a project so it's more than likely you can find them local wherever you happen to live.
Desktop
(11 items)
Celeron G3930 eXtra Slow Edition
Gigabyte Z270 Gaming K5
MSI R9 390
12GB DDR4-3000
120GB HP M700 SSD
Samsung Spintpoint M9T 2TB
Seagate Barracuda 750GB
Corsair CX750M
Fractal Define S
Keyboard
Alienware W/Cherry MX Switches
Mouse
Logitech G5 Gen.1
speed_demon is offline
post #43 of 45 (permalink) Old 02-26-2020, 02:46 PM
AMD Acolyte
qwertymac93's Avatar
Rep: 76 (Unique: 70)
I tried the washer mod and I ended up with higher temperatures. Maybe it was the 5 year old tube of Noctua thermal paste I used. Anyway, I now have an Arctic accelero III on the card, which was a ton of work but has dropped temperatures quite a bit. If any reference owner is interested in doing the same, buckle up; memory temps will be tricky to tame. I had to buy some 20x20x0.8mm copper shims to act as psuedo "heat pipes" because the ram modules are so close to the die that you cant really put any heatsinks on them directly without bumping into the accellero.
Before the shims the memory hit 88c stock and 100c when overclocked. Post shimming memory is 80c stock, 88c overclocked(1950core/1850mem) which is about 2c higher than with the blower cooler at 2400rpm. Testing methodology was a full run of the 3Dmark Firestrike Extreme stress test which takes about half an hour and pushed temps higher than any game I've played. This is with the Reference XT bios flashed and the fans pegged at 2050rpm(full speed), BTW.
"We should make it clear that NVIDIA is a good company, and we respect their attempted transition into being a smartphone company." - Roy Taylor, AMD
BF3 STATS/BF4 STATS
z87
(19 items)
Media Rig
(18 items)
Core i5 4670k - [email protected]
MSI z87m GAMING
MSI R9 280 GAMING - 1.15ghz core/1.5ghz mem
A-DATA 2x4GB DDR3
PNY 2x4GB DDR3
Crucial M500 240GB
Seagate 3TB
Antec TruePower TP-550
Xigmatek Gaia + Cougar VortexPWM
Silverstone PS07
Operating System
Windows 10 Pro
Viewsonic XG2401
Keyboard
CM Storm QuickFire Rapid
Mouse
Logitech G402
Mouse
Reflex Lab Pro 32 Heavy
Audio
Beyerdynamic DT 770 PRO-80
Audio
Yamaha RX-V663
Audio
Micca MB42x Bookshelf Speakers
Audio
SMSL Q5
AMD Phenom II 720
ASRock 870 Extreme 3
HIS 5750 (840core/1200mem)
2*2GB A-Data DDR3 1600
Seagate Barracuda ST1000DM003
Seagate Barracuda ST3000DM001
Optical Drive
Lite-On Blue Ray WH14NS40
Corsair CX-430
Arctic Cooling Freezer 64 PRO
NZXT Beta EVO
Operating System
Windows 10 pro 64-bit
Vizio M43-c1
Keyboard
Logitech K400
Mouse
Gigabyte M7700
Audio
Sony STR-DN1070
Audio
Definitive Technology BP8 Tower Speakers
Audio
Definitive Technology 2002 Series Center Speaker
Audio
Definitive Technology ProMonitor 1000 Bookshelf Speakers
qwertymac93 is offline
post #44 of 45 (permalink) Old 02-29-2020, 11:20 PM
treetops422's Avatar
Rep: 22 (Unique: 16)
Quote: Originally Posted by speed_demon View Post
ASRock did this with their high end B350 & X370 Fatal1ty ITX boards. Ended up shipping boards with an incredibly thick thermal pad to cover up their mistake. And then they turned around and had the guts to ask customers to pay $50 + shipping fees both ways to have it corrected.
Then a short while later ASRock shipped boards with labelling indicating they were Ryzen 2000 compatible but they actually had an older non-compatible BIOS installed; they wanted customers to pay $50 + shipping to have the correct BIOS module installed in the removable chip socket. Other companies would have shipped you out the part to correct the issue along with an apology.
And this was in recent memory. Despicable is the only word that comes to mind about it.
Nope.
This sort of thing easily happens when a manager feels pressured to meet a quota or obligation. I wouldn't push blame on the engineers that test & verify products because nobody is going to put their stamp of approval on a product that's going to get a bunch of back lash from customers. Or it could have just been up to human error. Sometimes it's hard to tell with this type of issue.
Makes me want to go back and watch the Dilbert tv show. Or buy a newspaper.
You could just flip your computer upside down to give it proper mounting pressure according to HUB. Or upside right if you're an AUSIE .
The design only seems to make a bit of sense the way ref cards position the blower vapor chamber. (Novice speculation)
Like Skupples said, use plastic washers. Think of it like this, your screw is to long, the washer shortens the screw.
Btw this interesting, not to sure if I understand it all.
https://www.igorslab.de/en/gddr6-mem...ight-basics/2/
Sapphire Radeon RX 5700 Non XT Boost Core 2035 Gaming Ram 960 43c Air Water Hybrid Cardboard Blower with a 20$ chinese Waterblock on the core 50 gallon tote of water, Ryzen 3700x 4.25 ghz, 15$ chinese waterblock, same tote 3200 ddr3 cl16 Team T-FORCE VULCAN TUF , B450m Asrock Pro 4 Mobo, 700 Watt OCZ PSU.
treetops422 is offline
post #45 of 45 (permalink) Old 03-01-2020, 04:37 PM
u broke 666 rep :(
skupples's Avatar
Rep: 682 (Unique: 362)
and your local ace should have them in the screw isle, in the box sliders. big box typically doesn't go small enough for anything relating to PC, except for TORX/allen/hex kits.
minor side thought & warning. Those 30 piece screw driver kits on amazon are absolute trash. they're made outta ledplastic or something. They're so soft that you're gonna strip the tip unless you use the perfect fitting driver.
good news is, Dewalt's 2020 revision of the (black) impact bit set is spot on.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is online now
