[PCWorld] How Intel is changing the future of power supplies with its ATX12VO spec - Page 3 - Overclock.net - An Overclocking Community
post #21 of 27 (permalink) Old 03-11-2020, 06:02 AM
News Fiend
ryan92084's Avatar
Still not a political forum.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #22 of 27 (permalink) Old 03-11-2020, 06:42 AM
u broke 666 rep :(
skupples's Avatar
Rep: 682 (Unique: 362)
Quote: Originally Posted by KyadCK View Post
SFF PCs in HP, Dell, and other office computers have been using 12v only PSUs for a while now.
In my personal experience over the last 5 years, we have had maybe five PSU or MB failures out of thousands of deployed PCs. The pros (size, cost, efficiency, complexity) outweigh the cons given how extremely few things use not-12v.
Most laptops and micro desktops use 19.5v. Type-C charging is also 19.5v in the 100w spec. The batteries in the laptops I support range from 7.4v to 11.4v;
Laptop Model	Battery Type	Watt Hours	Voltage	Dell Part Number
Latitude 5*50	G5M10	51Wh	7.4v	#451-BBLN
Latitude 5*70	NGGX5	47Wh	11.4v	#451-BBUJ
Latitude 5*70	6MT4T	62Wh	7.6v	#451-BBTW
Latitude 5*80	GJKNX	68Wh	7.6v	#451-BBZG
Latitude 5*90	GJKNX	68Wh	7.6v	#451-BBZG
Latitude 7280	F3G33	45Wh	11.1v	#451-BBFX
Latitude 7270	J60J5	55Wh	7.6v	#451-BBSY
Latitude 7280	F3YGT	60Wh	7.6v	#451-BBYE
Dell's office SFF PCs have been using these PSUs since the 20-series, so about 6 years now. The 10-series before it, which had a standard 24-pin, was the one with all the failures. HP has been on 12v-only for a while as well.
How many MB failures do you get on a regular basis? They are really not all that common, and even when there is a swap it's like 5 minutes of work. They do a good job of making these things repairable.
genuine non-user caused failure? I'd say i've had 1 laptop and 1 mini-desktop fail in the year I've been at this new spot. Much lower than it was 5-6 years ago, with lenovo, at my previous employer. n actually, neither of those were even board level failures. both were cooked CPUs.
huh, so our stuff is already doing this? cool.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is online now
post #23 of 27 (permalink) Old 03-11-2020, 01:59 PM
8051's Avatar
Rep: 30 (Unique: 21)
Quote: Originally Posted by airisom2 View Post
As long as this stays in OEM chunk boxes I'm good. Don't bring that trash down here. Boards are expensive and delicate enough as it is.
So basically there would be more failure points on a motherboard if they went with this plan? I guess all it would take is one cheap 3.3V DC-DC converter to die and you would have a non-functional motherboard.
Good PSU's seem pretty robust these days, I haven't had a PSU fail in decades. I have a Rosewill 750 Watt unit right now that I bought used.
8051 is offline
post #24 of 27 (permalink) Old 03-12-2020, 03:50 PM
Section31's Avatar
Rep: 14 (Unique: 12)
Funny story folks,my office actually have two of the dell's with the ATX12VO Specs, the rest are old Vostro 270 (3rd Gen i5). The vostros are still going strong though I have recently replaced the PSU's with seasonic focus modular 550watts and installed new ssd's into the system. Those new Dell with the ATX12VO, they have been problematic. I had to replace both of the PSU in two year's and recently had to get an dedicated GPU as the Intel IGP drivers/GPU was causing the display just to shut down at random. That and i had to go to moddiy just to order the adapter for our old standard ATX PSU to work.
Section31 is offline
post #25 of 27 (permalink) Old 03-12-2020, 04:02 PM
Hueristic's Avatar
Rep: 433 (Unique: 289)
Smart, move more components to the motherboard to cool. It's not like the power supply has a regulated sealed airflow to cool components or anything.
Mobo RMA's are gonna rocket when all those vrms start overheating on systems built by idiots..
READ this thread before starting your first build!!!
ALWAYS power up a Mobo Before installing it! Consider Less than helpful posts as Free Bumps.
devil-smiley-019.gif¡¡¡ʍʇɟ qn1ɔ uoıʇɐıɔǝɹddɐ 939 ʇǝʞɔos ǝɥʇthumbsupsmiley.pngsozo.gifRetro Rulezsozo.gif
1.
If you can't afford to lose it don't mod or OC it.
2.
At least read the ENTIRE OP before commenting.
Semper Fi
Hueristic is offline
post #26 of 27 (permalink) Old 03-17-2020, 06:21 PM
Raghar's Avatar
Rep: 38 (Unique: 32)
Quote: Originally Posted by ACleverName View Post
so if the new parts fry on the mother board, intel still makes us buy another mother board? Why does this feel similar.
Can we have daughterboard with VRM components, that we simply plug into new MB? That would work best wouldn't it?
Raghar is offline
post #27 of 27 (permalink) Old 03-17-2020, 08:13 PM
Politically incorrect
Liranan's Avatar
Rep: 620 (Unique: 302)
What would be even better is to leave everything as is.
Haha, Liranan, you creep.
Tacitus - The more corrupt the state, the more numerous the laws
Only when the last tree has died and the last river been poisoned and the last fish been caught will we realise we cannot eat money. - Cree Indian Proverb
Liranan is offline
