[AT]Intel Comet Lake Core i9-10900K, i7-10700K, i5-10600K CPU Review - Page 11 - Overclock.net - An Overclocking Community
post #101 of 124 (permalink) Old 05-22-2020, 09:39 AM
I <3 narcissists
bigjdubb's Avatar
Rep: 228 (Unique: 143)
Quote: Originally Posted by doom26464 View Post
Id have to see some data on that outside of some very outlying games(bf5 for example)
Most reviews I see even with any of intels skylake arch running at 5ghz its like 7-9% at best vrs zen 2
It gets a little tricky with review numbers because they aren't trying to reach a certain frame rate. Sometimes when you see those 125 fps vs 115fps it seems like there is very little difference between cpu's. What those charts don't show is the result of turning the graphics settings down to try and get 144fps.
Battlefield is one of those games that seems to work well for AMD cpu users, I can scale the frame rate up or down to where I want it by changing the graphics settings. I can do the campaign with all the pretty bells and whistles at 60fps and then adjust the settings and play multiplayer at 144fps. I wish it was like this in all games.
This may be irrelevant if games get a lot more demanding over the next year, but they need to get a lot more demanding because we will also have higher gpu performance at some point.
Gaming Rig
(12 items)
Couch Gaming Rig
(10 items)
Work rig
(11 items)
Ryzen 7 3700x
Gigabyte X570 Master
EVGA RTX 2080ti FTW3
G.Skill TridentZ RGB
HP EX920 m.2
Intel SSD6 m.2
Intel SSD6 m.2
EVGA G3
CORSAIR H150I PRO
LianLi PC-O11 Dynamic
Operating System
Win 10 Home
LG 32GK650G
Ryzen 5 3600
Asus x470i
Radeon VII
Samsung 970 evo
InWin A1
NZXT M22
InWin A1
Operating System
Win10 Home
Vizio 4k TV
AMD Ryzen 7 2700X
Asrock X470 Taichi Ultimate
GTX 750
Patriot Viper
HP EX920 M.2
EVGA G3
CORSAIR H150I PRO
NZXT Source 210
Operating System
Windows 10 Pro
BenQ PD3200Q
LG 32UD59
bigjdubb is offline
post #102 of 124 (permalink) Old 05-22-2020, 11:06 AM
7850K's Avatar
Rep: 92 (Unique: 59)
Quote: Originally Posted by EastCoast View Post
https://youtu.be/_j56hMgZNHU
Right now, if I understand it correctly:
Ryzen 2000 series support AVX via software
Ryzen 3000 series support AVX2
Ryzen 4000 series will support AVX512
where did that info come from?
AMD has had AVX in their uarch since first gen Bulldozer. All zen versions so far released support up to AVX2 and can run AVX512 instructions by combining AVX2. It's not as fast as Intels native AVX512
It's rumored Zen3 (desktop Ryzen 4000) with support native AVX512
7850K is offline
post #103 of 124 (permalink) Old 05-22-2020, 12:10 PM
Mooncheese's Avatar
Rep: 20 (Unique: 16)
Quote: Originally Posted by aayman_farzand View Post
I would hold off on statements such as marginal gaming differences between 3900X and 10900K. Its clear that a lot of the gaming benches are getting GPU bottlenecked so the maximum performance still remains to be seen. Over time the gap should widen and that time isn't really that far off.
Please post your results. I was looking to do the same but didn't pull the trigger. I'm already stable at 5.1 but the temps seem to high so I just keep it running at 5.0. no AVX offset.
What do you mean no upgrade path? I thought Gen 11 is supposed to work on Z490 as well. If that's the case then the upgrade path is the same as the 3900x, one additional generation.
Dude, you are contemplating delidding? Are you kidding? Delidding with liquid metal is easily worth 25C. Here's Prime95 small FFT whilst also mining crypto on Nicehash (1080 Ti @ 250W as seen in Hwinfo64) back when the delid was new with 300W less radiator surface area and single D5 only at 70% RPM (60-65C):
Quote: Originally Posted by MrTOOSHORT View Post
There is stock of 10900Ks at newegg.ca, just got one!
Edit: all gone, must have had only a few in stock. I just happen to check my bookmark, and I had time to snag one.
Congrats I guess, my pre-order for Valve Index and Half Life Alyx finally popped up, about $1080 after tax, or the equivalent of a 10900k, motherboard and ram. To me picking up VR is a much more worthwhile way to spend $1k but I guess if your form of entertainment is having the best CPU score on 3DMark, more power to you. 10900k presents marginal gains outside of 3DMark for anyone with a 14nm Intel CPU from Coffee Lake forward (I nearly want to say Kaby Lake and Sky Lake but the going from 4 to 6 cores presented a rather substantial increase in multi-threaded performance, whereas there are basically marginal gains going from 8700k to 10900k as evidenced by Gamers Nexus 10600k review in my previous post here).
Quote: Originally Posted by maltamonk View Post
No it's not. It's only marginally better. Considering that it lacks in every other aspect by a much larger margin...ya...definitely not convincing. That said the 10700k isn't a good buy either. Maybe the i5 might be at 1080p, but neither the i7 nor the i9 are worth buying unless they drop the price massively (like $100) imo.
As far as faulting ppl buying the overpriced chips...ya I can see a reason to. They are supporting Intel putting out marginal products at bad prices. They sustain stagnation.
Bingo, someone else gets it, this is exactly what I said elsewhere here recently. Intel knows they can keep drip feeding us iterative garbage because they know that those those short on smarts and flush with cash will buy anything they offer, not understanding that it's this very demand that continues to perpetuate the iterative refresh cycle. If we didn't buy 9th series CPU's because they offered no real meaningful performance above 8th gen then Intel would have been forced to release Rocket Lake early. All of this nonsense about how Intel is having problems dropping the node to 10nm is just hogwash. If there was no longer any demand for 14++++++++++++++++++++++ they would have released 10nm node real fast.
8700k @ 5.1 GHz - 0 AVX @ 1.386v Dynamic Offset w/ EK Monoblock + Delid | Gigabyte Z370 Aorus Gaming 7 | EVGA 2080 Ti XC2 Ultra @ 2070 Mhz core, 8025 MHz memory @ 1.019v w/ 375W FTW3 vbios + Phanteks Glacier Block | EK CE 420 + EK XE 360 | 2x16GB G-Skill Trident Z Royal 3600 MHz 17-20-20-38 | 2 TB Sabrent Rocket | Corsair RM1000x | Thermaltake View 71 | Alienware AW3418DW + Asus ROG Swift PG278Q (for 3D Vision) on Amazon Basics Arms | Win10 Pro 1809
Mooncheese is offline
post #104 of 124 (permalink) Old 05-22-2020, 12:16 PM
Overclocker
EastCoast's Avatar
Rep: 151 (Unique: 99)
29:15
AMD really needs to get onboard with AVX512. The software industry (from my observations) have adapted it. So lets hope that Ryzen 4000 actually offers it.
EastCoast is offline
post #105 of 124 (permalink) Old 05-22-2020, 12:24 PM
aayman_farzand's Avatar
Rep: 11 (Unique: 11)
I should've been more clear. I already delidded my 8700K but my real interest is the third party IHS vs stock.
As for GPU bound....by the time new GPUs will make any differences more apparent newer CPU's will most likely also be in the space...ie Zen 4 and we'll have to reevaluate.
I disagree, we already see plenty of GPU bound benches and the newer generation of GPUs is expected to be a big jump (or at most one generation later).
aayman_farzand is online now
post #106 of 124 (permalink) Old 05-22-2020, 12:29 PM
mfw
ToTheSun!'s Avatar
Rep: 500 (Unique: 234)
Cool story, bro.
Intel 6700K
Asus Z170i Pro Gaming
Gigabyte 2070 Super Windforce OC
G.skill Trident Z 3200CL14 8+8
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Fractal Design Core 500
Operating System
Windows 10 Education
ViewSonic XG2703-GS
Keyboard
Vortex Race 3 RGB
Mouse
Glorious Odin
Mousepad
SteelSeries QcK+
Audio
Fiio E17K v1.0 + Beyerdynamic DT 1990 PRO (Dekoni pads)
ToTheSun! is offline
post #107 of 124 (permalink) Old 05-22-2020, 12:34 PM
Overclocker in training
ThrashZone's Avatar
Rep: 170 (Unique: 103)
Hi,
For MrTOOSHORT this is just another of many toys and paid more than 1k.us too and still doesn't matter
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
10900k
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
Operating System
ThrashZone is offline
post #108 of 124 (permalink) Old 05-22-2020, 11:32 PM
Vandelay Industries
maltamonk's Avatar
Rep: 80 (Unique: 60)
I guess you either didn't understand what you quoted or you don't think new CPUs will require us to reevaluate? Maybe you don't think new CPUs will be here by then?..Heck idk what you are saying bc it doesn't fit the context of what you quoted.
maltamonk is offline
post #109 of 124 (permalink) Old 05-23-2020, 12:35 AM
rdr09's Avatar
Rep: 886 (Unique: 640)
https://youtu.be/BAsInofP3SQ?t=1375
It is called use case. Some here (should be most cos it is OCN) are benchers first before anything else including gaming. No need to compare.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is online now
post #110 of 124 (permalink) Old 05-23-2020, 03:14 AM
New CPUs will obviously come out but doesn't mean users will upgrade from the current generation. New GPUs will be coming out soon where "only 5% margins" that we see in the current processors will be increasing because we are already benching several GPU bound titles.
