[YT]Corsair XG7 leaking GPU block design flaw! - Page 3 - Overclock.net - An Overclocking Community
post #21 of 37 (permalink) Old 05-22-2020, 07:22 PM
Hueristic's Avatar
Rep: 436 (Unique: 291)
Quote: Originally Posted by orlfman View Post
if you watch linus video, he wasn't even trying to test for it and he got the same leak when he was trying to pull the tube up gently to attached his cpu tube that was slightly short. he had to go back up into his attic to find a longer tube to use. he wasn't even doing anything near the pressure that jaw was doing. the corsair block is clearly designed for absolutely no extra pressure pulling on the fitting at all.
but you can sit there and mock america like a stereotypical, smug european.
The guy is a muppet, why do people even bother to mention him? He was yanking on the tube because it was too short and causing the card to cause pressure on the pci-e slot.
He is a straight up moron.
READ this thread before starting your first build!!!
ALWAYS power up a Mobo Before installing it! Consider Less than helpful posts as Free Bumps.
devil-smiley-019.gif¡¡¡ʍʇɟ qn1ɔ uoıʇɐıɔǝɹddɐ 939 ʇǝʞɔos ǝɥʇthumbsupsmiley.pngsozo.gifRetro Rulezsozo.gif
1.
If you can't afford to lose it don't mod or OC it.
2.
At least read the ENTIRE OP before commenting.
Semper Fi
Hueristic is offline
post #22 of 37 (permalink) Old 05-22-2020, 08:21 PM
Xinoxide's Avatar
Rep: 281 (Unique: 250)
Think of all the noobtubers out there though, with the 35" run of 1\2x3\4x tube pulling on that terminal, bound to happen because we aren't all even OCN members.
Firestrike vs. Similar Systems
FIRESTRIKE EXTREME ULTRA
LittleBitties
(15 items)
PC of the Son.
(9 items)
ryzen 7 3800x
ASRock X470 Gaming-ITX
ASRock Phantom Gaming RX 5700 XT Challenger D
G.Skill RGB Z 3600 C14
Intel EX920 M.2 1TB
EVGA SUPERNOVA G2 1000
Corsair H100i v2
Metallic Gear MGNE210 BLACK
Viotek GN34C
Keyboard
Corsair K75 LUX
Mouse
Logi G502 Hero
Mousepad
Corsair "speedmat?"
Audio
AKG K240 ( 1987 )
Audio
Alienware by Ultrasone
Audio
Roland RH-200
Ryzen 5 1600
ASRock AB350M
Zotac GTX 1050Ti OC
GeIL EVO SPEAR 2x4GB DDR4-2400
HP EX900 500GB M.2
Corsair CX450M
AMD Wraith SPIRE RGB
CM Q300L
QNIX 2710
Xinoxide is offline
post #23 of 37 (permalink) Old 05-22-2020, 10:02 PM - Thread Starter
dansi's Avatar
Rep: 32 (Unique: 22)
https://www.igorslab.de/en/corsair-h...-watt-success/
Igor already informed Corsair of their flaw in 2019!
Unfortunately, the terminal was a bit weak. If you put it on it, use very rigid hoses and then also slightly edge them (but only then), then there can be a bending of the terminal foot and thus also slight leaks. With angles, normal hose or hard tubes, however, you can give a calm warning. But it is a possible source of error that the manufacturer was able to reproduce according to my indications and wants to replace with a new injection molding terminal.
dansi is offline
post #24 of 37 (permalink) Old 05-22-2020, 10:07 PM - Thread Starter
dansi's Avatar
Quote: Originally Posted by J7SC View Post
I agree with @tcclaviger re. Zotty's response...no matter what the technical arguments are / aren't, he made it much worse for Corsair's business . Also, no matter what I (or anyone else) think/s about Linus in general, the relevant Linus vid posted up front was the more convincing for me as he did nothing too extreme.
...I do in fact think that leaving out the third (center) screw / bolt can certainly contribute to a technical weakness. With only two on either side, you have pressure on only one side of each of the two o-rings...but with a third (center) one, the o-rings are secured on both sides, in addition to more overall rigidity of that mount. In fact, all the GPU blocks I own by various manufacturers (some for 8 yrs plus), have three screws @ that mount instead of two.
Agree!
Corsair probably wanted to save cost using 2 screws closer together.
But all other blocks have been using 3 or more, i think these vendors are more experienced and know better not to save here.
Corsair rep response was just the kick to our nuts. Makes the situation worse to accuse YT of fishing for views.
dansi is offline
post #25 of 37 (permalink) Old 05-22-2020, 10:20 PM
sudo apt install sl
Rep: 188 (Unique: 130)
Quote: Originally Posted by dansi View Post
Agree!
Corsair rep response was just the kick to our nuts. Makes the situation worse to accuse YT of fishing for views. [IMG class=inlineimg]/forum/images/smilies/mad.gif[/IMG][IMG class=inlineimg]/forum/images/smilies/mad.gif[/IMG][IMG class=inlineimg]/forum/images/smilies/mad.gif[/IMG]
The rep was pointing out that Major w/e channel is phishing for views. Which he clearly is, he's putting force on it to make it leak just like Jay did but at least Jay explained it. Just like Linus explained his tubing he was planning to use was too short causing the terminal to leak.
If it's a flaw it would of leaked without his hand on the terminal cover. They can improve their design by adding the third screw.
Silent
(20 items)
Core i9 9900K... CoffeeTime! @ 5.1Ghz w/ 1.36v
Maximus VIII Formula
Titan RTX @ 2100Mhz/2075Mhz
TeamGroup Xtreem 32GB 3200Mhz CL15
HP EX950 2TB
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
EVGA SuperNova 1200w P2
EK Supremacy Full Copper Clean
XSPC D5 Photon v2
Black Ice Gen 2 GTX360 x2
EK-Vector Radeon VII - Copper + Plexi
Thermaltake Core X5 Tempered Glass Edition
Operating System
Clear Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Alugraphics GamerArt
Audio
Definitive Technology Incline
Audio
SMSL M8A
WannaBeOCer is offline
post #26 of 37 (permalink) Old 05-22-2020, 10:27 PM - Thread Starter
dansi's Avatar
It is a flaw because a simple tug during installation caused the leak.
Igorlab reported to Corsair last year and they acknowledged it and was supposed to retool a fix. Probably they forgot!
And no Major is better than to phish for views. Oh please. Stop speaking up for corporate mistakes, which is pretty clear in this case.
dansi is offline
post #27 of 37 (permalink) Old 05-22-2020, 10:34 PM
sudo apt install sl
Did you watch Jay's or Linus's video? That's not just a simple tug.
Silent
(20 items)
HP EX950 2TB
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
XSPC D5 Photon v2
Operating System
Clear Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Audio
Audio
SMSL M8A
post #28 of 37 (permalink) Old 05-22-2020, 10:50 PM
prznar1's Avatar
Rep: 45 (Unique: 37)
Quote: Originally Posted by prznar1 View Post
So you are telling me that i should buy a sports type of a tyre set and try to do offroad, than complain it's underdesigned? Only in murrica people have to pet idiots like jay.
And i will. Tell me, how many times do you pull the tube or pipe when your loop is full od liquid? Once, to drain it. 2nd thing. From Corsair reaction i can tell you already that those videos is straight up fishing for views. Normal guy would call Corsair first and inform them about it. They got this info before as i can see, maybe 2nd call would change their point ov view and made them to use more screws to fix working thing... Whatever. But those half celebs are fishing for views. They havent called Corsair first (can easly assume that by the rwaction od Corsair guy) as they should and imo, Corsair should sue them for bad and intentional PR.
And tell me how i cannot look at USA as motherland of stupidity when you have people like this
https://www.heraldtribune.com/articl.../605209362/SH/
Ryzen 5 3600 | ASUS TUF B450 PRO | 2x16 GOODRAM IRDM PRO 3600Mhz DDR4 | MSI VENTUS GTX 1660 Ti | PNY 1TB NVMe SSD | IN WIN 303 | be quiet! STRAIGHT POWER 10 500W
prznar1 is offline
post #29 of 37 (permalink) Old 05-22-2020, 10:53 PM
AMD Acolyte
qwertymac93's Avatar
Rep: 77 (Unique: 71)
End users are often idiots; engineers kind of have to account for this. Even if the design works 100% flawlessly in the clean white design room, once it reaches the hands of some rando that can barely read but has loads of cash to drop you can bet they will find a way to mess it all up.
The Iphone6+ could bend much more easily than its contemporaries. Did it only effect some people, people who used their phones in ways Apple hadn't considered "proper use"? Sure. It was still a problem and one the Iphone6s+ was adjusted to alleviate.
That's just phones. If you want to look at "dangerous" things look at how modern firearms are designed. Features and ergonomic decisions that protect users without them even knowing. For example, everyone knows you shouldn't drop a loaded gun, it still happens and good guns designed within the last 100 years have nearly all been designed(or later modified) with firing pin blocks for just such an occasion.
People like whom? The Winnebago driver that doesn't exist, the 5 year old girl that got her fingers chopped of by a poorly maintained machine, or the greedy *expletive* that formed a shell company to falsify maintenance reports? Explain with simple words please, I'm an American.
"We should make it clear that NVIDIA is a good company, and we respect their attempted transition into being a smartphone company." - Roy Taylor, AMD
BF3 STATS/BF4 STATS
z87
(20 items)
Media/File server
(14 items)
Core i5 4670k - [email protected]
MSI z87m GAMING
ASUS RX5700
A-DATA 2x4GB DDR3
PNY 2x4GB DDR3
XPG SX8100
Seagate 3TB
Antec TruePower TP-550
Xigmatek Gaia + Cougar VortexPWM
Silverstone PS07
Operating System
Windows 10 PRO
Operating System
MANJARO 20
Viewsonic VX3211
Keyboard
CM Storm QuickFire Rapid
Mouse
Logitech G402
Mouse
Reflex Lab Pro 32 Heavy
Audio
Beyerdynamic DT 770 PRO-80
Audio
Yamaha RX-V663
Audio
Micca MB42x Bookshelf Speakers
Audio
SMSL Q5
Intel i5 3470
Proprietary Dell
8GB DDR3
Seagate Barracuda ST6000DM003
8TB External HDD
Optical Drive
Lite-On Blue Ray WH14NS40
Corsair CX-430
Operating System
Windows 10 PRO
TCL 55S517
Keyboard
Logitech K400
Audio
Sony STR-DN1070
Audio
Definitive Technology BP8 Tower Speakers
Audio
Definitive Technology 2002 Series Center Speaker
Audio
Definitive Technology ProMonitor 1000 Bookshelf Speakers
qwertymac93 is offline
post #30 of 37 (permalink) Old 05-23-2020, 02:47 AM
mfw
ToTheSun!'s Avatar
Rep: 500 (Unique: 234)
The guy was probably already protected several times in his lifetime by overengineering, but he's sitting here defending a company (which he can't even publicly trade).
Intel 6700K
Asus Z170i Pro Gaming
Gigabyte 2070 Super Windforce OC
G.skill Trident Z 3200CL14 8+8
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Fractal Design Core 500
Operating System
Windows 10 Education
ViewSonic XG2703-GS
Keyboard
Vortex Race 3 RGB
Mouse
Glorious Odin
Mousepad
SteelSeries QcK+
Audio
Fiio E17K v1.0 + Beyerdynamic DT 1990 PRO (Dekoni pads)
ToTheSun! is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
