[ANANDTECH] DDR5 Memory Specification Released: Setting the Stage for DDR5-6400 And Beyond - Overclock.net - An Overclocking Community
post #1 of 22 (permalink) Old 07-14-2020, 02:14 PM - Thread Starter
Original 16-bit Genesis®
Omega X's Avatar
Rep: 68 (Unique: 45)
Marking an important milestone in computer memory development, today the JEDEC Solid State Technology Association is releasing the final specification for its next mainstream memory standard, DDR5 SDRAM. The latest iteration of the DDR standard that has been driving PCs, servers, and everything in-between since the late 90s, DDR5 once again extends the capabilities of DDR memory, doubling the peak memory speeds while greatly increasing memory sizes as well. Hardware based on the new standard is expected in 2021, with adoption starting at the sever level before trickling down to client PCs and other devices later on.
Originally planned for release in 2018, today’s release of the DDR5 specification puts things a bit behind JEDEC’s original schedule, but it doesn’t diminish the importance of the new memory specification. Like every iteration of DDR before it, the primary focus for DDR5 is once again on improving memory density as well as speeds. JEDEC is looking to double both, with maximum memory speeds set to reach at least 6.4Gbps while the capacity for a single, packed-to-the-rafters LRDIMM will eventually be able to reach 2TB. All the while, there are several smaller changes to either support these goals or to simplify certain aspects of the ecosystem, such as on-DIMM voltage regulators as well as on-die ECC.
https://www.anandtech.com/show/15912...400-and-beyond
Omega X is offline
post #2 of 22 (permalink) Old 07-14-2020, 02:56 PM
go4life's Avatar
Rep: 588 (Unique: 418)
Looking forward to this. Thought we would have DDR5 a bit sooner, but better late than never. Have planned an upgrade once it comes out.
I am betting that we will see 10000mhz DDR for the first time, since there was a post/news here on OCN which said DDR5 was already at 8600mhz or something like that. Exciting!
From the cold North
|i9 9940X @ 4.6ghz 1.22v|
|MSI X299 PRO|
|MSI RTX 2080 Ti Duke @ 2ghz/8200mhz|
|4x4gb Corsair Vengeance @ 4000mhz CL17-20-20-35 1T|
|1tb Samsung 970 Pro M.2| |2tb Intel 660p M.2|
|Corsair AX1600i|
|EK Velocity| |HWLabs Black Ice Nemesis 420 + 280| |EK-D5 PWM G2|
|LD PC-V7|
Operating System
|Custom Windows 10 Enterprise x64|
|Acer Predator X34P 3440x1440 @120hz IPS|
Keyboard
|Logitech G613|
Mouse
|Logitech G Pro|
Audio
|JBL L890| |2x Advance Acoustic MAA-705 mono amps| |Emotiva XDA-2 DAC receiver|
go4life is offline
post #3 of 22 (permalink) Old 07-14-2020, 03:46 PM
Graphics Junkie
UltraMega's Avatar
Rep: 61 (Unique: 54)
So is all DDR5 ram going to be ECC?
Sounds like DDR5 is too far out to wait for an upgrade for me.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #4 of 22 (permalink) Old 07-14-2020, 04:09 PM
EniGma1987's Avatar
Rep: 348 (Unique: 257)
"10000mhz", aka 5GHz DDR, aka still on the same old 200mhz internal memory clock still.
Wonder when they will stop just increasing prefetch each generation and actually get a clock speed bump. Then we could actually get higher speed without having to go a lot higher again on the column strobe latency. If all they want to continue to do is double the prefetch each time then jedec should just jump to 128n now and stop wasting everyones time.
edit: Ha. Well at least Anand writers arent completely stupid either and at least tried to point out the elephant in the room:
The big challenge as always for DRAM speeds, comes from the lack of progress in DRAM core clock rates. Dedicated logic is still getting faster, and memory busses are still getting faster, but the capacitor-and-transistor-based DRAM underpinning modern memory still can’t clock higher than a few hundred megahertz.
EniGma1987 is offline
post #5 of 22 (permalink) Old 07-14-2020, 04:40 PM
Graphics Junkie
UltraMega's Avatar
Can you explain why that would matter? Does it make a performance difference in the end?
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
Audio
Sound Blaster z
post #6 of 22 (permalink) Old 07-14-2020, 07:08 PM
mfw
ToTheSun!'s Avatar
Rep: 521 (Unique: 240)
+1
I want to avoid a google rabbit hole on this, unless someone has a relevant article handy discussing this.
Intel 6700K
Asus Z170i Pro Gaming
Gigabyte 2070 Super Windforce OC
G.skill Trident Z 3200CL14 8+8
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Fractal Design Core 500
Operating System
Windows 10 Education
ViewSonic XG2703-GS
Keyboard
Vortex Race 3 RGB
Mouse
Glorious Model O Glossy White v2.0
Mousepad
SteelSeries QcK+
Audio
Fiio E17K v1.0 + Beyerdynamic DT 1990 PRO (Dekoni pads)
ToTheSun! is offline
post #7 of 22 (permalink) Old 07-14-2020, 08:55 PM
EniGma1987's Avatar
As we keep going up in the speed of the external interface without raising the internal clock of the memory itself we also have to go up in CAS timings. These timings are how many clock cycles pass between providing the memory address and then receiving the data. They go up as the external interface goes up but internal clock doesnt. If DDR5 were to actually raise the internal memory clock, then we would actually be able to make a jump in speed to things like "DDR-6400" without doubling the CAS timings like we have every generation.
post #8 of 22 (permalink) Old 07-14-2020, 09:26 PM
doom26464's Avatar
Rep: 14 (Unique: 12)
Will this mean more RGB ram? Twice the amount of RGB on one stick?
doom26464 is online now
post #9 of 22 (permalink) Old 07-14-2020, 11:16 PM
Graphics Junkie
UltraMega's Avatar
Interesting. Is there a easy to understand reason why it's difficult to increase the internal clock?
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
Audio
Sound Blaster z
post #10 of 22 (permalink) Old 07-15-2020, 12:57 AM
Otherworlder
epic1337's Avatar
Rep: 227 (Unique: 131)
it has something to do with how the memory cells handles charge-discharge cycles.
the way they had bypassed this is charging more cells in parallel (more bits per cycle).
SRAM would be superior to DRAM in this case, but it has it's own disadvantages.
trolling an adult is very dangerous, don't try it at home nor at work. you don't want to play tag with a rabid man.
epic1337 is online now
