Resize Gif - Possible? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 10-15-2017, 06:02 AM - Thread Starter
OCer
Rep: 6 (Unique: 6)
Hi
I was wondering if anyone is able to resize the following .gif image down to 64 x 64 pixels at a file size lower than 50 KB, and without making the image look squished or flaky.
I've attempted myself, but it always turns out as washed out or completely incomprehensible.
The background can be black if that helps managing the file size. The sides also need to be cropped as they're not all equal.
Link to image: https://i.imgur.com/vIxbK4v.gif
♫ A B C, is as easy as 1 2 ... ♫ - Gabe Newell
GPU History (Click to show)
1x ASUS STRIX GTX 1080 Ti, air
1x EVGA GTX 980 Ti ref., custom water
2x EVGA GTX 780 ACX, air
2x EVGA GTX 680 ACX, air
2x EVGA GTX 580 ACX, air
2x Sapphire HD 6950 flashed to HD 6970 /w shader fix, custom water
1x XFX HD 5850, air
1x Nvidia 9800 GT, air
CPU History (Click to show)
Intel 5930K @ 4.5GHz, custom water
Intel 3930K @ 4.6GHz, custom air
Intel 2600K @ 4.3GHz, custom air
AMD Phenom II X4 965 BE @ 4GHz, custom water
Intel Q8400 @ stock, stock air
Arkheios is offline
post #2 of 11 (permalink) Old 10-15-2017, 06:14 AM
Here you go:
Cybertox is offline
post #3 of 11 (permalink) Old 10-15-2017, 06:16 AM - Thread Starter
OCer
Rep: 6 (Unique: 6)
Originally Posted by Cybertox View Post
Here you go:
Looks perfect! Do you think there's a way to get the file size under 50 KB?
If need be, you're welcome to change the background to black, to help lowering the file size.
1x XFX HD 5850, air
Arkheios is offline
post #4 of 11 (permalink) Old 10-15-2017, 06:22 AM
This one is under 50kb:
Cybertox is offline
post #5 of 11 (permalink) Old 10-15-2017, 06:24 AM
Another one under 50 KB but with better compression:
Cybertox is offline
post #6 of 11 (permalink) Old 10-15-2017, 06:27 AM - Thread Starter
OCer
Rep: 6 (Unique: 6)
Looks good, I was wondering if making the background completely black would eliminate those pixelated frames in the coloring.
1x XFX HD 5850, air
Arkheios is offline
post #7 of 11 (permalink) Old 10-15-2017, 06:32 AM
Not really, whats taking up space is mostly the amount of frames, not the background. Plus, I cant be bothered to revise the background for each of those frames tongue.gif
Cybertox is offline
post #8 of 11 (permalink) Old 10-15-2017, 06:43 AM - Thread Starter
OCer
Rep: 6 (Unique: 6)
1x XFX HD 5850, air
Arkheios is offline
post #9 of 11 (permalink) Old 10-15-2017, 06:45 AM
You are welcome.
Cybertox is offline
post #10 of 11 (permalink) Old 10-15-2017, 07:33 AM - Thread Starter
OCer
Rep: 6 (Unique: 6)
I played around in Photoshop with the first version you made, and apparently it had two loops going, instead of just one.
I removed all the frames from the duplicate loop, and reduced the exposure offset, which completely removed the background.
With this I managed to get the file size below 50 KB, without any pixelation. Yay! smile.gif
Result:
1x XFX HD 5850, air
Arkheios is offline
