Help with HTPC - Overclock.net - An Overclocking Community
Help with HTPC
post #1 of 16 (permalink) Old 03-27-2019, 10:02 PM - Thread Starter
Joe Schmoe's Avatar
Rep: 0
Help with HTPC
Hi Guys,
I need help engineering a HTPC with the focus on it being operated by remote. I will be using the Playstation Vue service on it most of the time on it.
I already know what you guys are thinking. Why don't I use a Roku, FireTV or an Android TV device? The reason is they won't function at two different locations at the same time. Due to the way Playstation Vue works, I can only stream with those devices from home. I cannot use them when I visit my parents if someone is streaming from my place. I can use non TV-connected device like a phone, tablet or laptop though.
So it occurred to me that I should able to stream via a browser at my parents' place with their old PC connected to the TV since technically a PC is not considered a TV device. I tested the theory and it worked so now I want to put something together than can stay at their house with the emphasis on simplicity.
Lastly, I have a spare I5 2500k, Asus motherboard and 16gb of ram I was thinking of using on this machine to get 1080p with no issues. So keeping in mind that this all has to operate through a browser, whats the best way to approach this? What else do I need?
Thanks in advance guys.
Joe Schmoe is offline
post #2 of 16 (permalink) Old 03-28-2019, 05:35 AM
downlinx's Avatar
Rep: 161 (Unique: 137)
Why are you only wanting to use a remote as the remote you will need to buy will be quite a bit more than buying the corsair k83 HTPC keyboard?
Waiting for something to blow up!
downlinx is offline
post #3 of 16 (permalink) Old 03-28-2019, 07:15 AM - Thread Starter
Joe Schmoe's Avatar
Rep: 0
I wanted to keep things simple in the event my parents would want to use it. It's easier to hand them a remote than a keyboard.
I've also been considering to somehow get Android onto the PC since the Vue app lends itself to remote usage. I tried an emulator but the frame rate of the video wasn't that great and the highest resolution was far from HD. If I installed Linux, could I get Android functioning somehow?
post #4 of 16 (permalink) Old 03-28-2019, 07:32 AM
downlinx's Avatar
you can install android x86, there are a few different good variants out on xmdb if you wanted to run android as an OS. But if you are wanting a remote, I do believe that one of the Logitech Harmony remotes will work. for your needs.
downlinx is offline
post #5 of 16 (permalink) Old 03-28-2019, 10:55 AM - Thread Starter
Joe Schmoe's Avatar
Rep: 0
Ok, I'll give Android x86 a shot. I'm not big on the Kodi setup though. Those menus will definitely confuse my parents. I think something more vanilla that resembles their phones would be best. Are there any variants you would recommend And do they display at 1080p?
post #6 of 16 (permalink) Old 03-28-2019, 11:14 AM
downlinx's Avatar
just remember, that you will need to be able to do onboard audio maybe through onboard hdmi/dvi as they still do not have hdmi audio though dedicated gpu's yet.
downlinx is offline
post #7 of 16 (permalink) Old 03-28-2019, 11:32 AM - Thread Starter
Joe Schmoe's Avatar
Rep: 0
With that being said, do you think my I5 2500k is sufficient enough for a consistent 1080p stream? I can overclock if necessary. I was able to clock it up to 4.6ghz on a noctua fan. Not sure if I wanna plunk down $80 for another one to get this machine working though.
post #8 of 16 (permalink) Old 03-28-2019, 12:15 PM
downlinx's Avatar
the 2500k stock should be enough.
downlinx is offline
post #9 of 16 (permalink) Old 03-28-2019, 12:15 PM
Graphics Junkie
UltraMega's Avatar
Rep: 31 (Unique: 27)
Of corse an i5 2500k can steam 1080p, no question.
I built my parents an HTPC a while back and they bought a different device for streaming. They are not computer illiterate but the HTPC was too much extra effort for them.
I would advise against setting old people up with an HTPC.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
post #10 of 16 (permalink) Old 03-28-2019, 12:48 PM - Thread Starter
Joe Schmoe's Avatar
Rep: 0
They're familiar with Android since they have it on their phones. And honestly they're probably going to use it sparingly. It'll get more use out of me and other (younger) family members.
