Help with 4K (Best Quality) - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 06-21-2019, 10:30 AM - Thread Starter
llChaosll's Avatar
Rep: 10 (Unique: 10)
Hey all, I have a question regarding getting the best picture quality out of movies, 4K to be exact.
Currently I use an AMD R9 280X, which I know doesnt output HDR, but does output 4k.
I have a Samsung Q6FN, which does 4K @ 60, 10bit HDR.
I would like to output my movies, which are on the drive to the TV but my video card doesnt do HDR.
So I end up using Plex on my Xbox One X to stream the movies to the TV, which gives me 4k HDR but it shows 24P as the signal.
Does this mean I'm losing quality or frames? Or both? Movies play fine and do look awesome but I do feel like it should probably look better.
Is this fine? Am I losing quality by letting the Xbox One X and Plex stream the movies? or should I invest in a 4k HDR gpu?
I was considering getting a RX 580 or something similar that outputs at 4K, HDR 4:4:4.
btw, I'm using a display port to HDMI 2.0 adapter.
Any help or suggestions would be awesome.
Thanks all
llChaosll is offline
post #2 of 7 (permalink) Old 06-21-2019, 11:20 AM
Shawnb99's Avatar
Rep: 66 (Unique: 47)
Dumb question but are you sure the movie wasn't a 24P movie?
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #3 of 7 (permalink) Old 06-21-2019, 11:44 AM
Graphics Junkie
UltraMega's Avatar
Rep: 59 (Unique: 53)
What is 24p? You mean 24hz? As in 24fps? Movies are all 24 fps so if that's what 24p means then that would make sense.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is online now
post #4 of 7 (permalink) Old 06-21-2019, 11:51 AM - Thread Starter
llChaosll's Avatar
oh I didnt know that. So the 4K HDR 60hz is referring to gaming, not movies right?
My signal resolution on the TV while playing a 4K HDR 10 bit file, shows 4K UHD/HDR 24P.
So I'm assuming this is correct and the movie is playing at the best quality etc with 10bit?
I don't know what 24P is, I just thought it was 24hz, but the movie plays fine, no stutter so it cant be 24hz.
Thanks
post #5 of 7 (permalink) Old 06-21-2019, 12:03 PM
Shawnb99's Avatar
Yeah 24P would mean 24fps. It's playing fine.
If you have The Hobbit it should show 48P, think that's the only one not in 24fps
My Baby
(23 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
post #6 of 7 (permalink) Old 06-21-2019, 12:10 PM
Robotic Chemist
Asmodian's Avatar
Rep: 202 (Unique: 134)
24p means 24 Hz progressive (as opposed to interlaced), it is 24 Hz but since the movie is also 24 fps (probably 23.976 fps actually) there is no stutter. Your TV's OSD does not tell you the bit depth so it could be either.
You are losing potential quality compared to using madVR with a new GPU but you are not losing quality by using 24p, in fact 24p is better than 60p for movies; you always want to use the same refresh rate as the movie's frame rate. When using madVR on a PC it would be better to switch to 24p too, in fact madVR has a feature to switch the display to the same refresh rate as the source.
"Soldering resistors onto your video card to bypass the manufacturers over current protection kind-of sort-of absolute-definitely voids your warranty"
Desktop
(17 items)
AMD Ryzen 3950X
Asus Crosshair VIII Hero
Nvidia 2080 Ti
32GB DDR4 3600
Intel 900P
Samsung 960 Pro
Optical Drive
Asus BW-16D1HT
Seasonic 1200W
EK Velocity + EK GPU Block
Old Marble Slab
Operating System
Windows 10 Pro
LG C9 55"
Keyboard
Wooting two
Mouse
Logitech G903 Lightspeed
Mousepad
Logitech G PowerPlay
Audio
Arctis Pro Wireless
Other
Mellanox 40GbE
Asmodian is offline
post #7 of 7 (permalink) Old 06-21-2019, 12:33 PM - Thread Starter
llChaosll's Avatar
How would I know if its playing with 10bit 4:4:4 though? I wouldnt? I know on PC it would show it under display settings. I should look into that madvr.
