Quietest Fans and such, I need advice. - Page 3 - Overclock.net - An Overclocking Community
post #21 of 30 (permalink) Old 09-04-2017, 03:15 PM
Rep: 24 (Unique: 21)
Mag-lev bearings require proper manufacturing and handling, defects and mistreatment affect them in major ways.
Hydraulic bearings start out quieter but they produce more and more noise as the bearing wears out. They also handle mistreatment far better.
Notice that mag-lev bearings are far more resistant to high temperatures, so they do live far longer as processor cooler fans.
PsyM4n is offline
post #22 of 30 (permalink) Old 09-04-2017, 05:32 PM - Thread Starter
WildWhite's Avatar
Rep: 0
Can you recommend any others then the corsair ML? Looking for quiestest and most air pumping at any speed. A silent as can be build.
WildWhite is offline
post #23 of 30 (permalink) Old 09-04-2017, 06:01 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 428 (Unique: 285)
Check out the be quiet! Silent Wings 3. There is a comprehensive review on thermalbench.com
ciarlatano is offline
post #24 of 30 (permalink) Old 09-04-2017, 06:01 PM
That will be a problem actually. Most PWM implementations suffer from noise at some voltage ranges. The ML series seem affected so far.
Personally, I would visit the Enermax site, check what's available and see if a local dealer that accepts rmas has any of the ones I want available.
Quality control is very important with mag-lev fans and nowadays manufacturing quality is inconsistent, meaning that you might get a dud or two.
The good news are that if the fan doesn't have issues after some months, it won't die for at least a decade or so.
PsyM4n is offline
post #25 of 30 (permalink) Old 09-06-2017, 07:34 AM - Thread Starter
WildWhite's Avatar
Rep: 0
Can you comment on who has the highest quality control for magnetic levitation fans?
post #26 of 30 (permalink) Old 09-06-2017, 09:57 AM
Almost everything is made in China nowadays so everyone is affected.
Best bet is to be able and rma locally, in case you are affected.
PsyM4n is offline
post #27 of 30 (permalink) Old 09-06-2017, 10:18 AM
ciarlatano's Avatar
Which Enermax series uses a maglev bearing?
post #28 of 30 (permalink) Old 09-06-2017, 10:20 AM
All.
PsyM4n is offline
post #29 of 30 (permalink) Old 11-07-2017, 06:47 PM
josephytakagi's Avatar
Rep: 0
Everyone has different ears.
Here's a resource I used when deciding on fans: Cooling Technique (youtube)
Just a basic recording of various fans from 0-100%
I found that the noise profile was more important to me than DBA. A lot of fans make a buzzing or humming or whirring etc. etc.
In the end I sold myself on the $20+ Corsair MLs. I forget what my second choices were, I think Gentle Typhoons & something else
I've also had Antec TrueQuiets (140mm) that I thought were extremely quiet, & would continue to use them at $8-12, except they're 3-pin
ML140 review- no regrets other than price. Paired with a 30mm radiator. Use SpeedFan to keep them @500-600 RPM (~30-35%) until 70 degrees C. They don't get audible for me at 5 feet distance until 650-750 RPM / ~35-45%
josephytakagi is offline
post #30 of 30 (permalink) Old 12-24-2018, 11:46 AM
SirWaWa's Avatar
Rep: 39 (Unique: 34)
Corsair 140 ML's but only the 1200rpm version, the 2000 rpm is much too loud.
I'm tried both corsair quiet edition and ML's both rated at the same speed, size and the ML's are indeed quieter
The Z390
(19 items)
The X299
(18 items)
Intel i7 8086K @ 4.0Ghz
Asus ROG Z390 Maximus XI Extreme
Asus ROG Strix 1080 8GB GDDR5X A8G Edition
G.Skill Trident Z RGB 32GB DDR4 XMP 3200MHz 15-15-15-35
Intel 760p M.2 PCIe Solid State Drive 512GB
Intel 545s Series SATA III Solid State Drive 512GB
Corsair HX850 80 Plus Platinum
Corsair H115i PRO RGB 280mm Radiator
Corsair 750D
Operating System
Windows 10 Pro
LG 27MP68VQ-P 27" 1920 x 1080 75Hz IPS LED
Keyboard
Logitech G810 Orion Spectrum RGB
Mouse
Logitech G502 Proteus Spectrum RGB
Mousepad
SteelSeries 4HD
Audio
Logitech X-540 5.1 Speaker System
Intel i7 7820X @ 3.6GHz
Asus ROG Strix X299 Gaming XE
Asus ROG Strix 1080 Ti 11GB GDDR5X OC Edition
G.Skill Trident Z RGB 32GB DDR4 XMP 3200MHz 16-18-18-38-2N
Corsair 750D
Operating System
Windows 10 Pro
Asus ROG Strix VG27VQ 144Hz VA
Keyboard
Mouse
Mousepad
Logitech G440
Audio
Logitech Z323 2.1 Speaker System
SirWaWa is offline
