Hello, my case is the Corsair 200R. My CPU and fans are silent, but the problem is my 3TB hard disk. It is installed in the hard disk bay as shown in the picture (not the actual photo). There are no screws to hold the disk in place, just the plastic clips.
The noise is very annoying however (it makes the whole case vibrate), if I move the case a bit the noise stops but starts again after a while. My case is on this floor stand. I can't find a way to dampen the noise. I was thinking of putting some thin absorber sheets between the hdd case and the disk itself, but as you can see in the picture there's no space to fit them.
Can someone suggest a cheap way of getting rid of the noise?
Thanks
Thanks
