Mineral Oil Submerged Computer ? - Overclock.net - An Overclocking Community
post #1 of 43 (permalink) Old 06-23-2009, 08:27 PM - Thread Starter
magicalmuffin's Avatar
Rep: 0
Now im wondering, this really works? I want silent desktop. Can i put it inside mineral oil?
Are there any step by step guides how to do it?
magicalmuffin is offline
post #2 of 43 (permalink) Old 06-23-2009, 08:29 PM
Rep: 98 (Unique: 70)
Yes it works, has been done for 20 years. Its a Very high maintenance setup. Also requires Expensive part to build correctly. <--- CORRECTLY, not just done to bench, but for a 24/7 rig, gets expensive.
Jason4i7 is offline
post #3 of 43 (permalink) Old 06-23-2009, 08:30 PM
STG3 VET
Juggalo23451's Avatar
Rep: 1174 (Unique: 756)
systm on youtube did this and they explain how to do it Ill try to find the vid
EDIT:found it
better vid
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><p><a href="https://www.overclock.net/water-cooling/913181-water-cooling-guide-noobs.html#post11984918">Water cooling guide for noobs,parts,setup install case suggestions,etc</a></p><span></span><p><a href="https://www.overclock.net/water-cooling/962044-upgrade-time-update-2-3-18-a.html">Case labs TH10/ build log (2 gtx 590s) water cooling oh my</a></p><span></span><p><a href="https://www.overclock.net/water-cooling/528648-heatkiller-club.html">Founder of the Heatkiller Club</a></p><span></span><p><span>W</span><a href="https://www.overclock.net/water-cooling/601449-water-cooling-cases.html">ater cooling case suggestions</a></p></div></div>
Juggalo23451 is offline
post #4 of 43 (permalink) Old 06-23-2009, 08:32 PM
Rep: 114 (Unique: 107)
It's worthless for a practical application. Just a science experiment of sorts.
mr.derp is offline
post #5 of 43 (permalink) Old 06-23-2009, 08:33 PM
B-roca's Avatar
Rep: 49 (Unique: 47)
don't bother the minrel oil give you **** as temps you could get better temps on a pretty much silent air cooling rig or spend the money and go to water cooling
the local pc store had a display rig that was a submerged mineral oil and all the mineral oil did was heat up and stay like that and the tanks was hot to the touch and had a slight leak out the bottom
B-roca is offline
post #6 of 43 (permalink) Old 06-23-2009, 08:36 PM
Well temperatures continually build up because what it's going to cool the mineral oil?
Unless you plan to use an atom based rig with at least a 10 gallon tank, heat will be a problem
mr.derp is offline
post #7 of 43 (permalink) Old 06-23-2009, 08:39 PM
B-roca's Avatar
you could get better temps if you pumped the oil through a rad but whats the point when you start including rads and pumps and stuff you might aswell build a water cooling loop
B-roca is offline
post #8 of 43 (permalink) Old 06-23-2009, 08:42 PM
Linux Lobbyist
GigaByte's Avatar
Rep: 357 (Unique: 272)
It should work great for a while untill all that heat gets trapped in the oil, then it becomes an oven, if theres no way to move that heat out of the oil fast enough.
GigaByte is offline
post #9 of 43 (permalink) Old 06-23-2009, 08:51 PM
See and thats the problem, people think about nothing. Even in oil cooled systems, you still need a radiator. You need to pull oil out of the system and cool it. It will help regulate temps, but not drop them huge amounts. The closed systems that gather and gather heat are done incorrectly. You need a cooling source. All of these that have been mentioned, the fish tank, the one in the shop. Know what they are missing? Heat dissipation. Hurray for poor planning.
Jason4i7 is offline
post #10 of 43 (permalink) Old 06-23-2009, 08:55 PM
B-roca's Avatar
yes this is what i'm saying too watch the video on oil cooling above and all they can mention is the many many cons of oil cooling its really not worth it go get water cooling or something if its really necessary but otherwise stick with air
B-roca is offline
