The [Official] Noctua Club - Overclock.net - An Overclocking Community
post #1 of 3308 (permalink) Old 05-15-2011, 01:06 PM - Thread Starter
Retired Staff
animal0307's Avatar
Rep: 116 (Unique: 103)
Welcome to the Noctua Club.
This is the spiritual successor to this thread (thanks Zippit for your work) but includes all of Noctua's great products. If you enjoy their heatsinks, fans or even their thermal paste feel free to join us here.
If you would like to be added to the list please post in the thread with a list of your Noctua Products. If you would please post a picture of your rig. It's not required but we all love some Noctua loving. If I manage to miss your post please pm me with a link to your post. If you are updating your current entry please state it.
Thank you,
Animal0307
Official Website
OCN's Official NH-D14 Club
Ehume's Review on the New PWM fans
FANS
NF-P14 FLX
Size 140x140x25 mm
Bearing SSO-Bearing
Blade Geometry NF-P14 Blade Design with VCN
Rotational Speed (+/- 10%) 1200 RPM
Rotational Speed with L.N.A. (+/- 10%) 900 RPM
Rotational Speed with U.L.N.A. (+/- 10%) 750 RPM
Airflow 110,3 m³/h
Airflow with L.N.A. 83,7 m³/h
Airflow with U.L.N.A. 71,2 m³/h
Acoustical Noise 19,6 dB(A)
Acoustical Noise with L.N.A. 13,2 dB(A)
Acoustical Noise with U.L.N.A. 10,1 dB(A)
Static Pressure 1,29 mm H2O
Static Pressure with L.N.A. 0,77 mm H2O
Static Pressure with U.L.N.A. 0,53 mm H2O
Input Power 1,2 W
Input Current 0,1 A
Voltage Range 12 V
MTBF > 150.000 h
NF-P12
Size 120x120x25 mm
Bearing SSO-Bearing
Blade Geometry Nine Blade Design with VCN
Rotational Speed (+/- 10%) 1300 RPM
Rotational Speed with L.N.A. (+/- 10%) 1100 RPM
Rotational Speed with U.L.N.A. (+/- 10%) 900 RPM
Airflow 92,3 m³/h
Airflow with L.N.A. 78,5 m³/h
Airflow with U.L.N.A. 63,4 m³/h
Acoustical Noise 19,8 dB(A)
Acoustical Noise with L.N.A. 16,9 dB(A)
Acoustical Noise with U.L.N.A. 12,6 dB(A)
Static Pressure 1,68 mm H2O
Static Pressure with L.N.A. 1,43 mm H2O
Static Pressure with U.L.N.A. 1,21 mm H2O
Input Power 1,08 W
Input Current 0,09 A
Voltage Range 12 V
MTBF > 150.000 h
NF-S12B FLX
Size 120x120x25 mm
Bearing SSO-Bearing
Blade Geometry NF-S12B Blade Design with BBT
Rotational Speed with U.L.N.A. (+/- 10%) 600 RPM
Airflow 100,6 m³/h
Airflow with L.N.A. 75,8 m³/h
Airflow with U.L.N.A. 49,2 m³/h
Acoustical Noise 18,1 dB(A)
Acoustical Noise with L.N.A. 10,6 dB(A)
Acoustical Noise with U.L.N.A. 6,2* dB(A)
Static Pressure 1,31 mm H2O
Static Pressure with L.N.A. 0,76 mm H2O
Static Pressure with U.L.N.A. 0,34 mm H2O
Input Power 1,2 W
Input Current 0,1 A
Voltage Range 12 V
MTBF > 150.000 h
NF-S12B ULN
Size 120x120x25 mm
Bearing SSO-Bearing
Rotational Speed (+/- 10%) 700 RPM
Rotational Speed with U.L.N.A. (+/- 10%) 500 RPM
Airflow 56,9 m³/h
Airflow with U.L.N.A. 38,2 m³/h
Acoustical Noise 6,8* dB(A)
Acoustical Noise with U.L.N.A. 5* dB(A)
Static Pressure 0,44 mm H2O
Static Pressure with U.L.N.A. 0,23 mm H2O
Input Power 0,6 W
Input Current 0,05 A
Voltage Range 12 V
MTBF > 150.000 h
NF-F12 PMW
500
Size 120x120x25 mm
Connector 4-pin PWM
Bearing SSO2
Blade Geometry Heptaperf™
Frame Technology Focused Flow™
Rotational Speed (+/- 10%) 1500 RPM
Rotational Speed with L.N.A. (+/- 10%) 1200 RPM
Min. Rotational Speed (PWM) 300 RPM
Airflow 93,4 m³/h
Airflow with L.N.A. 74,3 m³/h
Acoustical Noise 22,4 dB(A)
Acoustical Noise with L.N.A. 18,6 dB(A)
Static Pressure 2,61 mm H2O
Static Pressure with L.N.A. 1,83 mm H2O
Max. Input Power 0,6 W
Max. Input Current 0,05 A
Voltage 12 V
MTBF > 150.000 h
Scope of Delivery
* Low-Noise Adapter (L.N.A.)
* 4-Pin Y-Cable
* 30cm Extension Cable
* 4 Vibration-Compensators
* 4 Fan Screws
Warranty 6 years
NF-B9
Size 92x92x25 mm
Bearing SSO-Bearing
Blade Geometry NF-B9 Blade Design with BBT & VCN
Rotational Speed (+/- 10%) 1600 RPM
Rotational Speed with L.N.A. (+/- 10%) 1300 RPM
Rotational Speed with U.L.N.A. (+/- 10%) 1000 RPM
Airflow 64.3 m³/h
Airflow with L.N.A. 52,6 m³/h
Airflow with U.L.N.A. 41,1 m³/h
Acoustical Noise 17,6 dB(A)
Acoustical Noise with L.N.A. 13,1 dB(A)
Acoustical Noise with U.L.N.A. 7,9* dB(A)
Static Pressure 1,61 mm H2O
Static Pressure with L.N.A. 1,09 mm H2O
Static Pressure with U.L.N.A. 0,64 mm H2O
Input Power 1,32 W
Input Current 0,11 A
Voltage Range 12 V
MTBF > 150.000 h
Size 92x92x25 mm
Connector 4-pin PWM
Bearing SSO
Airflow  64.3 m³/h
Static Pressure with L.N.A 1,09 mm H2O
Max. Input Power 0,96 W
Max. Input Current 0,08 A
Voltage 12 V
MTBF> 150.000 h
Size 80x80x25 mm
Connector 4-pin PWM
Bearing SSO
Blade Geometry Raised Blade Design
Rotational Speed (+/- 10%) 1800 RPM
Airflow 53,3 m³/h
Airflow with L.N.A. 39,4 m³/h
Acoustical Noise 17,1 dB(A)
Acoustical Noise with L.N.A.10,2 dB(A)
Static Pressure 1,41 mm H2O
Static Pressure with L.N.A. 0,74 mm H2O
Max. Input Power 0,72 W
Max. Input Current 0,06 A
Voltage 12 V
MTBF> 150.000 h
NF-R8
Size 80x80x25 mm
Bearing SSO-Bearing
Blade Geometry Raised-Blade-Design
Rotational Speed with U.L.N.A. (+/- 10%) 800 RPM
Airflow 53 m³/h
Airflow with L.N.A. 39 m³/h
Airflow with U.L.N.A. 26 m³/h
Acoustical Noise 17 dB(A)
Acoustical Noise with L.N.A. 10 dB(A)
Acoustical Noise with U.L.N.A. 7* dB(A)
Input Power 1,32 W
Voltage Range 4-13 V
MTBF > 150.000 h
HEATSINKS
NH-D14
Socket compatibility Intel LGA1366, LGA1156, LGA1155, LGA775 & AMD AM2, AM2+, AM3 (backplate required)
Height (without fan) 160 mm
Width (without fan) 140 mm
Depth (without fan) 130 mm
Height (with fan) 160 mm
Width (with fan) 140 mm
Depth (with fan) 158 mm
Weight (without fan) 900 g
Weight (with fan) 1070/1240* g
Material Copper (base and heat-pipes), aluminium (cooling fins), soldered joints & nickel plating
Fan compatibility 140x140x25 & 120x120x25mm
NH-U12P SE2
Height (without fan) 158 mm
Width (without fan) 126 mm
Depth (without fan) 71 mm
Height (with fan) 158 mm
Width (with fan) 126 mm
Depth (with fan) 95/120* mm
Weight (without fan) 600 g
Weight (with fan) 770/940* g
Fan compatibility 120x120x25mm / 120x120x38mm
Socket compatibilty Intel LGA2011, LGA1366, LGA1156, LGA1155, LGA775 & AMD AM2, AM2+, AM3, AM3+, FM1
Height (without fan) 66 mm
Width (without fan) 150 mm
Depth (without fan) 150 mm
Height (with fan) 93mm
Width (with fan) 128 mm
Depth (with fan) 150 mm
Weight (without fan) 415 g
Weight (with fan) 680 g
Fan compatibilty 120x120x25mm & 92x92x25mm
Inluded Items
    1x NF-F12 PWM premium fan
    1x NF-B9 PWM premium fan
    2x Low-Noise Adaptor (L.N.A.)
    Y-Split Cable
    NT-H1 high-grade thermal compound
    SecuFirm2™ Mounting Kit
    Mini-ITX Mounting-Kit
    Noctua Metal Case-Badge
NH-C12P SE14
Height (without fan) 90 mm
Depth (without fan) 152 mm
Height (with fan) 114 mm
Depth (with fan) 152 mm
Weight (without fan) 550 g
Weight (with fan) 730 g
Fan compatibility 140x140x25mm / 120x120x25mm
NH-C14
Height (without fan) 105 mm
Depth (without fan) 166 mm
Height (with fan) 130 mm
Depth (with fan) 166 mm
Weight (without fan) 700 g
Weight (with fan) 850/1000* g
NH-U9B SE2
Height (without fan) 125 mm
Width (without fan) 95 mm
Height (with fan) 125 mm
Width (with fan) 95 mm
Weight (without fan) 460 g
Weight (with fan) 550/640* g
Fan compatibility 2x 92x92x25mm
Here is Noctua's Server and Workstation heatsinks.
animal0307 is offline
post #2 of 3308 (permalink) Old 05-15-2011, 03:31 PM
Retired Staff
Tator Tot's Avatar
Rep: 2146 (Unique: 1310)
I'm watching this thread for potential of "Official" status.
Please do remember that we are not supposed to use the "Unofficial" tag, as everything is unofficial unless stated otherwise.
Tator Tot is offline
post #3 of 3308 (permalink) Old 05-15-2011, 03:33 PM
nagle3092's Avatar
Rep: 386 (Unique: 312)
Ok sorry about that.
nagle3092 is offline
post #4 of 3308 (permalink) Old 05-15-2011, 03:35 PM
Rep: 81 (Unique: 78)
ydna666 is offline
post #5 of 3308 (permalink) Old 05-15-2011, 03:35 PM
Rep: 166 (Unique: 148)
Add me, please: NH-U12P smile.gif
Faraz is offline
post #6 of 3308 (permalink) Old 05-15-2011, 03:37 PM
Paladin Goo's Avatar
Rep: 206 (Unique: 166)
Sign me up for being awesome.
I win.
BIGGUS DICKUS
(21 items)
TERROR-RYZEN
(14 items)
SUPERPLEX
(10 items)
Intel Core i7 6700k
Gigabyte G1 GA-Z170X-Gaming 7
ASUS Geforce GTX 1080Ti Turbo
G.Skill Ripjaws DDR4-3000
Samsung 850 Evo
Western Digital SSD
Crucial SSD
WD Red
WD Green
WD Blue
OCZ Fatality 1000w Sleeved
Corsair H100i V2
Fractal Design Meshify C
Operating System
Windows 10 Pro x64
AOC G2590FX
AOC G2590FX
Keyboard
Corsair K70 Cherry Browns
Mouse
Steelseries Rival 300
Mouse
Razer BF4 Mat
Audio
Creative Soundblaster Zx
Audio
Sennheiser PC G4me One
AMD Ryzen 1600
MSI B350M Gaming Pro
EVGA GTX 980 Reference
G.Skill Ripjaws X DDR4
Kingston SSD
Silverstone Strider
AMD Wraith Spire
Rosewill SRM-01
Operating System
Windows 10 Pro x64
Acer 24" 1080p
Keyboard
Logitech Wireless
Mouse
Logitech Wireless
Audio
Behringer Q502USB Mixer
Audio
Creative X-Fi Titanium PCI-E
Intel Core i7 3770k @ 4.8Ghz
ASUS Maximus V Formula
MSI GTX 680 TwinFrozr
2x8GB G.SKILL Ripjaws X @ 1600Mhz 1.5v
WD Blue
HGST Deskstar
RAIDMAX
Corsair H100
Cooler Master Haf X
Operating System
Windows 10 Pro x64
Paladin Goo is offline
post #7 of 3308 (permalink) Old 05-15-2011, 03:45 PM
nagle3092's Avatar
Added
post #8 of 3308 (permalink) Old 05-15-2011, 03:47 PM
Rep: 10 (Unique: 9)
I'm in! I love my NH-U12P.
zhylun is offline
post #9 of 3308 (permalink) Old 05-15-2011, 03:50 PM
nagle3092's Avatar
post #10 of 3308 (permalink) Old 05-15-2011, 03:53 PM
blackbalt89's Avatar
Rep: 296 (Unique: 243)
blackbalt89 is offline
