All intake and no "dedicated" exhaust?! - Page 3 - Overclock.net - An Overclocking Community
post #21 of 37 (permalink) Old 01-01-2012, 08:50 PM
Retired Reviewer
ehume's Avatar
Rep: 1373 (Unique: 856)
Originally Posted by AMD4ME View Post
People who have never studied gas flow or actually measured airflow like to argue even when their POV is proven to conflict with reality.
One scientific test is of more value than 1000 meritless opinions. That's why I recommend those who want to learn factual information regarding PC case airflow, perform tests on their specific hardware to see exactly what works for them and ignore the pointless debates by those who prefer to argue even when they have no technical understanding of the subject matter.
Hear Hear. Data beats theory every time.
OP, building a custom case means you can dispense with slot pillars -- those swatches of sheet metal between the back slots. You can build it with no rear grill, so the air can gently blow out the back. Or you can build it with no top grills -- or anything else you like.
I don't recommend positive pressure cases, but I do recommend positive flow cases.
ehume is offline
post #22 of 37 (permalink) Old 01-02-2012, 04:37 AM - Thread Starter
Blue Basher's Avatar
Rep: 7 (Unique: 6)
Originally Posted by ehume View Post
Hear Hear. Date beats theory every time.
Lol I may add a back grill or some 60mm fans but that's it. And the holes on the back are not going to change. They will be closed off unless being used and they are a tight fit against the gpu since the back panel is flat
Blue Basher is offline
post #23 of 37 (permalink) Old 01-02-2012, 09:45 AM
ANTEC LANBOY AIR
/THREAD
HAVO is offline
post #24 of 37 (permalink) Old 01-02-2012, 02:22 PM
Rep: 238 (Unique: 214)
dont have grills, and don't have tiny fans, thats pointless and may actually be worse just let your tower heat sink fans point towards your rear case hole cutout with no grill and let the exhaust itself.
chinesethunda is offline
post #25 of 37 (permalink) Old 01-02-2012, 10:58 PM - Thread Starter
Rep: 7 (Unique: 6)
I'm making the case, those options don't really work for me. Like I said il do 3 intake off the rad and 2 exhaust off the top and maybe the psu will help a bit.
post #26 of 37 (permalink) Old 01-02-2012, 10:59 PM
Rep: 107 (Unique: 94)
Heat rises you need a form of exhaust no matter what. You don't wanna create negativity pressure in the case.
DONATE IN HONOR OF SYRILLIAN
: : The Official Corsair H50/H70/H100 Hydro Series Club : :
NZXT Phantom 820 Club[/CENTER]
post #27 of 37 (permalink) Old 01-02-2012, 11:06 PM
mad0314's Avatar
Rep: 90 (Unique: 79)
You guys make it seem like somebody's talking about putting intake fans on every possible opening rolleyes.gif
And "negative" pressure would be from more exhaust fans than intake.
mad0314 is offline
post #28 of 37 (permalink) Old 01-02-2012, 11:27 PM
ehume's thread regarding case airflow showed you don't need a dedicated case exhaust fan, you can use the fan from the back of a cpu cooler to blow it out, or if you have a rad you can just use the rad to blow out
post #29 of 37 (permalink) Old 01-03-2012, 07:09 AM
HAVO is offline
post #30 of 37 (permalink) Old 01-03-2012, 07:30 AM
DaXxJaPxX's Avatar
Rep: 73 (Unique: 70)
its pretty logical that with open pci-e slots and other grill-type openings in most cases, and dedicated exhaust isnt required. But if you have air being pushed in from 5 different dirrections, poor air flow would be an understatement. just push the air in one general direction with 4 fans and exhaust the last
DaXxJaPxX is offline
