Secrets of the D14 - Chapter 7: PWM fans - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 02-16-2012, 07:30 PM - Thread Starter
Retired Reviewer
ehume's Avatar
Rep: 1373 (Unique: 856)
Related:
Chapter 1: Solo 140mm Fans in the Center Position
Chapter 2: Fan Position
Chapter 3: In and Out Games
Chapter 4: Ultra-Quiet and Very Quiet Operation
Chapter 5: Quiet Operation
Chapter 6: High Performance Fans
Adapting fans for the D14
How to mount three fans on a D14
7.0 Introduction
All right, time to wind this up. I saved the PWM fans for last because I was waiting for Noctua to release PWM fans. And now they have. In fact, they sent me three.
What you will see is a collection of 120x25mm PWM fans placed in the push position with a new Noctua NF-P14 PWM in the center between the fin stacks. Then you will see the same push fans put through their paces with a Thermalright TY-140 in the center. Test setup has been covered before.
Contents:
7.1: Fans
7.2: Cooling Results with NF-P14 PWM in Center
7.3: Cooling Results with TY-140 in Center
7.4: Conclusions
ehume is offline
post #2 of 9 (permalink) Old 02-16-2012, 07:30 PM - Thread Starter
Retired Reviewer
ehume's Avatar
Fans
The fans are set out in the table below. By using a strategically placed ground wire and a PWM Mate I was able to approximate five PWM duty states: 0, 25%, 50%, 75% and 100%. This is what I did in the Noctua PWM fan review. But Noctua specifically made its fans so they would not click. Other PWM fans do make clicking sounds to one degree or another. I noted the type of sound I heard by listening closely to the fans while they ran in open air, then noted them in the table. A key to the notes is below the table.
These fan results were obtained with the fans running in open air. Because of limitations in the environment I was unable to measure sounds less than 32 dBA. So the equivalent sound pressure level (SPL) at 1 meter could not be measured under 32 dBA. Sometimes manufacturers and brand sellers specify the minimum and maximum speeds their fans are supposed to reach at 0 and 100% duty, with purported sound pressure levels. Note that the fans here are not sold by their manufacturers except the Gentle Typhoon AP-30 and the San Ace. For the latter two I was able to get specifications from the manufacturer’s website. The AP-30 is subject to a modification (“mod”) that transformed it from a Voltage-controlled fan to a PWM fan. It was fun to do.
Here’s the data:
PWM Fans
Approximate PWM Duty
Mfr
Spec
≈0
≈25%
≈50%
≈75%
≈100%
Min
Max
Akasa Apache - RPM
519
755
1053
1256
1333
600
1300
                                           SPL (dBA)
13.5
14.5
20
23
25
6.9
16.1
                                    sound quality
QC
QC
QC
fC
NoC
na
na
Arctic Cooling F12 PWM - RPM
1350
1011
1211
1290
1350
400
1350
                                           SPL (dBA)
23.5
20
22.5
23.5
24
na
22.5
                                    sound quality
NoC
QC
QC
QC
NoC
na
na
Cooler Master Blade Master - RPM
791
840
1293
1804
2083
600
2000
                                           SPL (dBA)
16
16.5
24
30.5
35
13
32
                                    sound quality
NoC
VQC
FQC
QC
tone
na
na
Coolink SwiF2 120P - RPM
762
770
1169
1584
1662
800
1700
                                           SPL (dBA)
15
15
23.5
31
31.5
8.5
27.1
                                    sound quality
QC
VQC
FQC
NoC
NoC
na
na
Enermax Cluster - RPM
488
500
735
1083
1220
500
1200
                                           SPL (dBA)
14
14
15
19.5
22.5
8
14
                                    sound quality
fC
fC
NoC
NoC
NoC
na
na
Nidec AP-30, PWM mod  - RPM
1180
1433
2463
3515
4354
na
4250
(D1225C12B9AP-30) - SPL (dBA)
19
21.5
32.5
41.5
46
na
47.5
(sold by Scythe) - sound quality
QC
FC
VFC
NoC
NoC
na
na
Noctua NF-F12 PWM - RPM
0
363
757
1123
1470
300
1500
                                           SPL (dBA)
0
<12
15
22
28.5
na
22.5
                                    sound quality
0
NoC
NoC
NoC
NoC
NoC
NoC
Noctua NF-P12 PWM - RPM
0
330
686
992
1271
300
1300
                                           SPL (dBA)
0
<12
13
19
25
na
19.8
                                    sound quality
0
NoC
NoC
NoC
NoC
NoC
NoC
Noctua NF-P14 PWM - RPM
0
381
721
991
1225
na
1200
(140mm) - SPL (dBA)
0
<12
17
24
29.5
na
19.6
                                    sound quality
0
NoC
NoC
NoC
NoC
NoC
NoC
San Ace“Silent” medium - RPM
827
1099
1383
1626
1864
na
1850
9S1212P4M011 - SPL (dBA)
13.5
18
21.5
24
27
na
24
                                    sound quality
QC
QC
NoC
NoC
NoC
na
na
Scythe SlipStream LM-P - RPM
0
192
713
1085
1331
0
1300
(SY1225SL12LM-P) - SPL (dBA)
0
<11.5
13.5
21
26.5
0
26.5
                                    sound quality
0
NoC
QC
NoC
NoC
na
na
Thermalright TY-140 - RPM
664
654
962
1214
1308
900
1300
(140mm) - SPL (dBA)
12.5
12.5
17.5
22.5
24.5
17
21
                                    sound quality
fFC
fFC
FQC
FQC
NoC
na
na
Titan Kukri - RPM
873
867
869
1483
2242
800
2200
                                           SPL (dBA)
16
16
16
26
37
15
35
                                    sound quality
FC
FC
FC
FC
NoC
na
na
fC
 faint Clicking
FC
 Fast Clicking
fFC
 faint Fast Clicking
FQC
 Fast Quiet Clicking
na
 not available or not applicable
NoC
 No Clicking
QC
 Quiet Clicking
tone
 fans makes a tone, which would drown out any quiet to moderate clicking
VFC
 Very Fast Clicking
VQC
 Very Quiet Clicking
I suppose that my biggest surprise came with the Kukri: its min/max specs were right on. The next surprise came with the Slip Stream: the brand seller’s specs were just what I measured. The AP-30 result was no surprise; I expect accuracy from a company that actually makes fans. The TY-140 was able to go more slowly than advertised, but at the rpm’s noted at its stated minimum fan speed, the SPL was right on spec. The Arctic Cooling fan had some trick that caused it to go full speed when the PWM duty was zero. I wish I had the capability to test a 10% duty to see what it would do. Finally, note that the only fans to produce no clicking at any speed were the three Noctua fans. Clearly, they accomplished what they set out to do.
ehume is offline
post #3 of 9 (permalink) Old 02-16-2012, 07:31 PM - Thread Starter
Retired Reviewer
ehume's Avatar
The cpu is an i7 860 running at 4GHz and stressed with OCCT 3.1 running Linpack, as noted here. The chart below sets out the fans, their speeds, the SPL measured 10 cm from the center fan, and the TOA of each fan combination. Note that TOA stands for temperature over ambient. I subtract the mean ambient from the mean temperature of the hottest core to get the TOA.
Results:
ehume is offline
post #4 of 9 (permalink) Old 02-16-2012, 07:31 PM - Thread Starter
Retired Reviewer
ehume's Avatar
Results:
ehume is offline
post #5 of 9 (permalink) Old 02-16-2012, 07:31 PM - Thread Starter
Retired Reviewer
ehume's Avatar
Conclusions
I think the results speak for themselves. As usual, the San Ace fans at relatively low rpm’s cool well with little noise. They function better on a heatsink than they seem in free air. But relatively few people have the money or the skills needed to buy and adapt a San Ace for computer use.
Also as usual, the Slip Stream functions very well on this kind of heatsink. Unfortunately, they don’t sell this fan with fluid dynamic bearings. Before you use one of these, be sure to lubricate it, and periodically re-lubricate it.
So, it turns out that if you want FDB or ball bearings, the FDB Arctic Cooling F12 PWM is the best all-around performer. Its cable incorporates a “PWM Sharing Technology” that allows you to daisy chain PWM fans and know the rpm of each. Its pretty clever, actually.
And of course, the star of this whole endeavor is the NH-P14, which makes any fan a winner. As usual, you can use the stock fans and get great cooling, quietly.
(Thanks to Noctua for providing the three PWM fans.)
ehume is offline
post #6 of 9 (permalink) Old 02-17-2012, 05:04 AM
masscrazy's Avatar
Rep: 8 (Unique: 5)
For the lazy (like me) who have just bought 3 Akasa black Apache PWM fans (like me). How did/will it fare?
masscrazy is offline
post #7 of 9 (permalink) Old 02-17-2012, 06:07 PM - Thread Starter
Retired Reviewer
ehume's Avatar
ehume is offline
post #8 of 9 (permalink) Old 02-19-2012, 04:29 PM
Otterclock's Avatar
Rep: 101 (Unique: 91)
Though it may seem like a backhanded compliment to Noctua, it's a testament to the NH-D14's efficiency that it gets the kind of results in spite of using the NF-P14. Noctua crafts heatsinks with a level of refinement I haven't seen equalled. The same can be said for some of their fans, but in my humble opinion the P14 is not one of them. In fact I'd guess that most of the 120mm fans tested would have outperformed it in the center slot.
Otterclock is offline
post #9 of 9 (permalink) Old 02-19-2012, 05:26 PM - Thread Starter
Retired Reviewer
ehume's Avatar
I don't think so. For that you'd need a 140mm fan. Really, you do. I haven't posted all the runs I've done with 120mm fans in the middle, but the same thing holds as for case fans: the larger diameter blade sweep means you can run at fewer rpm's and get the same airflow. In the case of the D14, the fin stacks are wide enough and tall enough that the diameter of the fan matters.
As further backing to my own experiences we have the upcoming new version of the Silver Arrow. It will keep its front 140mm push fan, but it will have a 150mm center fan -- at fewer rpm's, I think about 1000 rpm.
I have demonstrated to my own satisfaction that the TY-140 and the various Kaze Maru 2 fans can produce the same cooling as the P14 more quietly, or more cooling not very much more loudly. I would like to try some of the new 135mm fans, since they have 120mm screw holes.
I am told that the reason the NF-P14 PWM does not come in a retail package is that it will be superseded. I am waiting to see what Noctua produces.
ehume is offline
