(FINISHED) Assassin vs NH-D14 Vs Phanteks Vs CM V8 vs Hyper 612 Vs Hyper 212+ - Overclock.net - An Overclocking Community
View Poll Results: WHO WILL BE KING?
Logisys ASSASSIN cooler 17 11.81%
NH-D14 55 38.19%
CM V8 2 1.39%
HYPER 612 1 0.69%
HYPER 212+ 13 9.03%
Phanteks PH-TC14PE_OR 56 38.89%
Voters: 144. You may not vote on this poll
post #1 of 108 (permalink) Old 08-03-2012, 10:46 AM - Thread Starter
Mr.4way SLI
Moparman's Avatar
Rep: 193 (Unique: 173)
Update 8/14/2012 I have had many others comment on my pics an results so here you go I retested the nh-d14 an have no idea why it has such high temps. Also the pics below do not reflect my testing an are only for reference. What the graph is labeled is how it was tested. So please be patient with me an ill have all the other results posted soon for all fan setups that I tested on all coolers.
After nh-d14 retest.
BLADE MASTER TEST.
SLIP STREAM 110cfm TEST
PHANTEKS PH-F140TS FANS.
UPDATE 8/10/2012 I will have complete bar graps as soon as testing on all coolers is finished. for now im putting data in the next 7-8 posts
Unboxing video can be found here for the Assassin. Sorry for the poor quality.
OK this will be my compare Thread on these CPU coolers. The Assassin unboxing is here. https://www.overclock.net/t/1285971/...arison-to-come
FIRST OFF HUGE THANKS TO ALL WHO MADE THIS POSSIBLE.
[COLOR=] If you have other coolers you would like to see in this review an are willing to loan me them for testing let me know. Im on a tight budget an can't afford to spend to much more right now. [/COLOR]
www.performance-pcs.com
Pizzaman
Gizmo
Racer86
Remnant88888888
Again Thanks very much. Its nice to have friends here on OCN that support each other.
Now to the way I will be reviewing the coolers an the test bed.
You guys might be thinking its very crazy to put the V8,612,212+ in this review but i have a good point to show. If we look at the price point of each cooler its unfair to put a $49. cooler up against a $80+ cooler. But lets take that same $49 cooler an add 2 $15.99 fans now we have a cooler that has cost you now $80.98. So lets see how that now fairs against a cooler that is $80 to start with. I think this will be a good review.
Test bed(s). Ok Im going to be using a SKT1366 setup for the review an if time i ill also be using a AMD 1090T setup.
Mobo Asus P6T6 WS Revolution
CPU Xeon W3520(same as D0 i7 920)
Ram 3x2GB crucial 1866 @ 1600 7-7-7-24-1T
Gpu PNY GTX 295 single PCB
PSU Corsair GS 800
Case Inwin malestrom with 10 120mm fans
Also might test without case.
TESTING METHOD.
All coolers will use the Same PK-3 thermal paste t. will run coolers box stock then with extra fan(s) an aftermarket fans. will do a price compare at each point an what gain the cost of fan upgrade got the cooler if any.
Testing software
My poor Xeon will run at 3.8Ghz so 200X19 at 1.21V with HT on will be using REAL TEMP for temps an a digital thermometer for air temp. Stress test will be INTEL burn test running 6 passes at MAX. will then let system idle for 10min an record the highest core temp an the highest idle temp with air temp at time of reading. im working on graphs at this time to plug in data.
BIG 3 Testing. Now Im planing on trying to do an all out compare on the ASSASSIN,D14,an Phanteks since they are some of the largest an most expensive Air coolers an see just how the Logisys Assassin can hold its own.
MORE INFO TO COME SO STAY TUNED.
WILL START TESTING WHEN COOLERS START COMING IN IN A WEEK OR So.
ASSASSIN with 3 slip streams
VS
NH-D14
VS
PHANTEKS
VS
CM V8
VS
CM Hyper 612
VS
CM 212+
Moparman is offline
post #2 of 108 (permalink) Old 08-03-2012, 10:46 AM - Thread Starter
Mr.4way SLI
Moparman's Avatar
HYPER 212+ TESTING.
CM 212+ BOX STOCK WITH PK-1 THERMAL COMPOUND
ALL TESTS WILL BE WITH A [email protected] 4C 8T WITH PK-1 THERMAL COMPOUND 2 PASSES OF BURN TEST @ MAX
AMBEIENT TEMP 24c
IDLE TEMP 44c
LOAD TEMP 88c
CM212+ WITH 2 BLADEMASTERS IN PUSH PULL.
[email protected] 4C 8T 2 PASSES OF INTEL BURN @ MAX
AMBIENT TEMP 24c
IDLE TEMP 43c
LOAD TEMP 85c
CM212+ 2 AP-15S PUSH PULL
AMBIENT TEMP 25c
IDLE TEMP 43c
LOAD TEMP 88c
CM212+ 2 slip streams 1900rpm 110cfm push pull
AMBIENT TEMP 25
IDLE TEMP 42C
LOAD TEMP 85C
CM 212+ 2 YL 2000RPM FANS PUSH PULL.
AMBIENT TEMP 25c
IDLE TEMP 44c
LOAD TEMP 85c
212+ box stock.
212+ with push pull ap-15s
Moparman is offline
post #3 of 108 (permalink) Old 08-03-2012, 10:46 AM - Thread Starter
Mr.4way SLI
Moparman's Avatar
Moparman is offline
post #4 of 108 (permalink) Old 08-03-2012, 10:47 AM - Thread Starter
Mr.4way SLI
Moparman's Avatar
V8 Testing
COOLER MASTER V8 STOCK ONLY
AMBIENT TEMP 25c
IDLE TEMP 41c
LOAD TEMP 88c
V8 box stock
Moparman is offline
post #5 of 108 (permalink) Old 08-03-2012, 10:47 AM - Thread Starter
Mr.4way SLI
Moparman's Avatar
Phanteks PH-TC14PE_OR Testing
Moparman is offline
post #6 of 108 (permalink) Old 08-03-2012, 10:47 AM - Thread Starter
Mr.4way SLI
Moparman's Avatar
Logisys ASSASSIN Testing
ASSASSIN STOCK
AMBIENT TEMP 27c
IDLE TEMP 36c
LOAD TEMP 76c
ASSASSIN 2 BLADE MASTERS PUSH PULL
AMBIENT TEMP 26c
IDLE TEMP 36c
LOAD TEMP 70c
ASSASSIN 2 AP-15S PUSH PULL
WONT MOUNT
ASSASSIN 2 SLIP STREAMS PUSH PULL
AMBIENT TEMP 27c
IDLE TEMP 36C
LOAD TEMP 70c
ASSASSIN 3 SLIP STREAMS PUSH PULL
AMBIENT TEMP 27c
IDLE TEMP 35c
LOAD TEMP 68c
ASSASSIN 3 BLADE MASTERS PUSH PULL
AMBIENT TEMP 25c
IDLE TEMP 34c
LOAD TEMP 70c
Assassin with 3 slip stream 110cfm fans.
Moparman is offline
post #7 of 108 (permalink) Old 08-03-2012, 10:47 AM - Thread Starter
Mr.4way SLI
Moparman's Avatar
Moparman is offline
post #8 of 108 (permalink) Old 08-03-2012, 10:47 AM - Thread Starter
Mr.4way SLI
Moparman's Avatar
Moparman is offline
post #9 of 108 (permalink) Old 08-03-2012, 10:49 AM - Thread Starter
Mr.4way SLI
Moparman's Avatar
Moparman is offline
post #10 of 108 (permalink) Old 08-07-2012, 07:50 PM - Thread Starter
Mr.4way SLI
Moparman's Avatar
Moparman is offline
