Cooler Master Jetflo -- Anatomy of POM bearings (pictures) - Overclock.net - An Overclocking Community
post #1 of 31 (permalink) Old 11-30-2013, 08:46 PM - Thread Starter
Retired Reviewer
ehume's Avatar
Rep: 1373 (Unique: 856)
I received some Cooler Master Jetflo fans. They are advertised as having “Fourth Generation” bearings made of polyoxymethylene (POM, otherwise known as Delryn).
The Jetflo POM bearing differs from the Sickle Flow X bearing I took apart previously. That one was essentially a sealed sleeve bearing, just like the original Sickle Flow bearing, but made with POM so it would last a long time. This . . . second generation . . . of the POM bearing (4th gen, Mark 2?) differs from that one. This one is supposedly water proof and dust proof. How is it made?
Here is Cooler Master’s drawing of the POM bearing, Mark 2. The orange represents POM. POM in its natural state is black:
I took one apart to see what this bearing is made of. So let us start with the frame, and peel off the label. We can see a steel plug surrounded by what looks like a brass ring. It is actually a brass case, as we shall see later.
I pounded on the steel plug with a punch and never pushed it through. I pried and pried until the blade-and-motor assembly finally pulled away from the frame. Since we can see that the plastic was more soft than rigid, I should have taken a heat gun to it. Ah, well. Next time.
This shot shows where I pounded on the steel plug. No wonder I couldn’t pound it through. Look at those cleats! The picture also shows one very scuffed circuit board.
Would the circuit board still work? I tried the fan, now that it was free of the frame. It wouldn’t spin, but it did light up.
Now let us peel the Cooler Master label off the fan head. The blade disk (the blades are part of it) is a translucent plastic.
The blade disk did pull off.
And I was able to push the bearing out of the motor assembly.
A closeup of the 4th generation bearing, Mark 2:
I took my hacksaw and cut off the steel tip.
Clearly the steel is just an insert in the brass casing.
I reassembled the pieces so you can see how they relate:
Another attack with the hacksaw, and the retaining disk comes away. The mushroom top of the shaft pops through the retaining disk, which -- um – retains the shaft in the bearing assembly.
With the retaining disk off, the shaft comes out. Inside the brass case, the barrier ring faces us.
CM Jetflo - 2 034.tif
Pushing the contents out of the case, we see the POM bearing cylinder and the barrier ring:
I have assembled the pieces of the bearing:
The same picture, with the pieces numbered in the order they occur in the bearing:
1. The tip of the shaft that sticks into the plastic blade disk
2. The barrier ring and the part of the shaft that penetrates it.
3. The POM cylinder, the part of the shaft that penetrates it and the brass case.
4. The retaining disk and the end the shaft that penetrates it.
5. The end cap, with its steel plug.
The Cooler Master drawing again. The barrier ring is at the top, the retaining ring at the bottom:
I hope you have enjoyed our little tour through the innards of the Cooler Master Jetflo. BTW – look at those rubber corners. They really do dampen vibration.
ehume is offline
post #2 of 31 (permalink) Old 12-01-2013, 06:45 PM
⤷ αC
AlphaC's Avatar
Rep: 911 (Unique: 592)
Not directly related:
Delryn smells when you try to machine it. That's what I remember about Delyrn besides it being stiff like ABS plastic tongue.gif
Thanks for the overview EHume , will we be seeing noise comparisons since you broke the fan tongue.gif
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #3 of 31 (permalink) Old 12-01-2013, 06:49 PM - Thread Starter
Retired Reviewer
ehume's Avatar
Yes, but at Overclockers. I will post the link when I'm done and it is published.
ehume is offline
post #4 of 31 (permalink) Old 12-02-2013, 01:11 AM
r/madlads
DaveLT's Avatar
Rep: 273 (Unique: 219)
I'm interested in the noise ratings. I've always always mocked CM fans for being very way off listed specs, this being the new baby in the lineup i hope it might change ... Maybe not. (And now their most expensive fan)
*Jon is watching!*
DaveLT is offline
post #5 of 31 (permalink) Old 12-02-2013, 12:16 PM
doyll's Avatar
Rep: 1678 (Unique: 932)
Thanks ehume.
doyll is offline
post #6 of 31 (permalink) Old 12-02-2013, 05:52 PM - Thread Starter
Retired Reviewer
ehume's Avatar
AlphaC - were you successful when you machined Delryn?
ehume is offline
post #7 of 31 (permalink) Old 12-02-2013, 07:24 PM
⤷ αC
AlphaC's Avatar
It's been a while.
I was making a roller (or was it a bushing?) for a robotic mechanism and it was put on lathe to make the roller smaller. It has an acidic smell (maybe because of the acetal component) if I recall correctly.
It cuts like butter and machines really smooth. The big problem is the smell (possibly toxic?) due to low melting point.
AlphaC is offline
post #8 of 31 (permalink) Old 12-03-2013, 07:34 PM
Turtle Lives Matter
damric's Avatar
Rep: 431 (Unique: 332)
Are these fans worth it? I nearly bought some for this build, but stuck with the good Ole sickleflows that are so cheap.
Borg Cube
(16 items)
Sky OC
(10 items)
R5 1600(14nm) @4100MHz
GA-AX370-Gaming K5
XFX RX 570 4GB
Ripjaws V @3466CL16
VPN-100 NVMe
Rosewill CAPSTONE (SF GG)
TCP-612
2x EVGA FX 120mm Fan
2x Cooler Master MasterFan Pro 140 Air Flow
HAF XB
Operating System
10-64 PRO
Samsung 4K 60Hz
Keyboard
Logitech G105
Mouse
Devastator II
Audio
Xonar SE
Audio
Logitech Z623
Z170 K4/D3
Vega 64
2x8GB RipjawsX
Silicon Power A80
Supernova G3
i7 Stock Cooler
Aerocool Bolt
Operating System
10 Pro
Samsung 58" 4K
damric is offline
post #9 of 31 (permalink) Old 12-03-2013, 08:10 PM - Thread Starter
Retired Reviewer
ehume's Avatar
These fans outperform their specs. Even pulling behind a dust filter the Jetflo pushes out 95 CFM. And they speed up behind the filter. They are strong fans.
ehume is offline
post #10 of 31 (permalink) Old 12-04-2013, 10:10 AM
koniu777's Avatar
Rep: 40 (Unique: 36)
How loud are they?
Sent from my SM-N900V using Tapatalk
koniu777 is offline
