Thermalright True Spirit 140 Power - Page 83 - Overclock.net - An Overclocking Community
post #821 of 898 (permalink) Old 08-08-2019, 09:25 PM
UnexplodedCow's Avatar
Rep: 47 (Unique: 42)
I went and flattened out the base of the D15S, and temps are about 1-2C better than before. It is very clearly making full contact now. Temp under Prim95 is 76C. With video compression (Handbrake) it's averaging 67C. Room temp is 25C, and case fans are linked to the CPU fan speed, so it's moving a fair amount of air. I'm surprised by how toasty these chips are, or else temps are being misreported. I wouldn't find either difficult to believe.
UnexplodedCow is offline
post #822 of 898 (permalink) Old 08-08-2019, 10:36 PM
⤷ αC
AlphaC's Avatar
Rep: 904 (Unique: 590)
Prime95 heats it up due to AVX2 , so turn off AVX2 when using Prime95. Remember that Zen2 has twice the AVX2 of Zen+ as it no longer combines two 128-bit AVX units and also has less area for the CPU cores (i.e. thermal density 1.5x).
Handbrake with 67 Celsius seems reasonable.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is online now
post #823 of 898 (permalink) Old 08-10-2019, 06:46 AM - Thread Starter
doyll's Avatar
Rep: 1661 (Unique: 924)
What do you have Handbrake's priority level set at? If at 'normal' or lower it is not using all the CPU it can. Set it to 'high' for maximum CPU load. In Handbrake / Preferences / Advanced / Priority Level (4th down list), set it to 'High' for maximum load.
Be sure you change it back after testing to 'Normal' or 'Below Normal' if you encode while doing other things on computer. Encodes will take longer, but at least comptur can be used.
doyll is offline
post #824 of 898 (permalink) Old 08-10-2019, 07:43 AM
Be sure you change it back after testing to 'Normal' or 'Below Normal' if you encode while doing other things on computer. Encodes will take longer, but at least computer can be used.
Oh yeah, I forgot about that bit. Thanks for reminding me. 70C is now the average.
post #825 of 898 (permalink) Old 08-10-2019, 12:05 PM
⤷ αC
AlphaC's Avatar
When you milled off the bottom of the NH-D15S , did you remove the nickel plating in the process? If you did make sure you use a thermal compound that doesn't react with the copper.
post #826 of 898 (permalink) Old 08-10-2019, 02:45 PM
Overclocking Enthusiast
ozlay's Avatar
Rep: 274 (Unique: 219)
Good quality fans. Bad quality pic.
In Loving Memory Of Kassandra
Kaby
Rikka
(9 items)
Intel I5-7600k
Asrock Z270M Extreme 4
Titan X
Gskill Royal
970 Evo
Optane 900p
Seasonic Prime Snow
enthoo evolv matx tempered glass
Operating System
windows 10 pro
ozlay is offline
post #827 of 898 (permalink) Old 08-12-2019, 05:50 PM
Indeed, I did, in all but the very corners, to level out the base. True, bare copper does now preclude the use of any gallium based liquid metal, but I'll live, and recently acquired some Kryonaut to try compared to the MX4 or NT-H1.
post #828 of 898 (permalink) Old 08-12-2019, 11:33 PM
- Insanity Beckons -
Elrick's Avatar
Rep: 173 (Unique: 89)
DAMN, the BIGGEST Thermalright Cooler sitting on what looks like, an Asrock X470 iTX Motherboard model (or similar)?
NICE one there. You really showed them what this cooler can do for the tiniest motherboard's .
Elrick is offline
post #829 of 898 (permalink) Old 08-12-2019, 11:42 PM
Rep: 4 (Unique: 4)
If your really keen there are nickel plate kits around though they are probably a bit pricey if this is the only job you would ever use it for.
Also note that Noctua has released NT-H2 which has replaced NT-H1.
clannagh is offline
post #830 of 898 (permalink) Old 08-15-2019, 08:19 PM
Well, I tried a third TS140P, and flattened out the base. It averaged 76C for Prime95, using the same settings in that as before. The main difference is that it's using only one fan (A TY143) and it's on a slower fan curve than the one I used to test the D15, so that's a bit of a handicap for it to achieve the same temps (at a lower noise value) than the D15.
It also takes up less room, and the fan clips are far easier to work with. I'll probably clip on a second fan and see how it does. Good heatsink when it makes good contact.
