Thermalright True Spirit 140 Power - Page 84 - Overclock.net - An Overclocking Community
post #831 of 1022 (permalink) Old 08-16-2019, 05:24 AM - Thread Starter
doyll's Avatar
Rep: 1696 (Unique: 938)
Quote: Originally Posted by UnexplodedCow View Post
Well, I tried a third TS140P, and flattened out the base. It averaged 76C for Prime95, using the same settings in that as before. The main difference is that it's using only one fan (A TY143) and it's on a slower fan curve than the one I used to test the D15, so that's a bit of a handicap for it to achieve the same temps (at a lower noise value) than the D15.
It also takes up less room, and the fan clips are far easier to work with. I'll probably clip on a second fan and see how it does. Good heatsink when it makes good contact.
When comparing coolers it is always good to record temps with fans at same speed, not fan curve. When I compared TY-140/147/147A/143 against Noctua cooelr fans I found Thermalright TY series fans to perform a little better (1-2c lower temps at same speed) all while making less noise and having a nicer sound profile. While 1-2c isn't much of a difference, their sounding nicer when loud enough to be heard makes them the better choice for me.
doyll is offline
post #832 of 1022 (permalink) Old 08-16-2019, 06:11 AM
UnexplodedCow's Avatar
Rep: 47 (Unique: 42)
Yes, I know this. My entire point is that the RPM (and noise) was lower, and using single fan, than dual fans at 100% on the D15. Even without stating the RPM, that it has one less fan, and is not 100% points toward a conclusion.
UnexplodedCow is offline
post #833 of 1022 (permalink) Old 08-16-2019, 07:39 AM
Fix it till its broke
Owterspace's Avatar
Rep: 7 (Unique: 4)
I didn’t bother milling mine down like I was going to. I did just rotate it and made sure I had enough paste, also when I tested last, 2 out of my 3 exhausts on my R4 were not running. @ stock clocks on my x5690 I am seeing the same temps again as I was seeing with LGMRT. For fifty bucks you really can’t go wrong with this cooler.
X5690 E.S. @ 4209MHz 1.35v/Thermalright True Spirit 140 Power/TF8/TY-143
Asus Rampage III Formula @ 200/3608/3608 Bios 0702
16GB G.Skill Mix @ 802MHz 9-9-9-24 1T 1.575v|Intel 545S 256GB x2
EVGA GTX 980 Classified 3988 @ 1497/2001|Asus Xonar Essence ST
CM Silent Pro M2 850|Fractal Design Meshify C/Panaflo NMB x4/TY-147 x2|ZM-MFC2
Owterspace is offline
post #834 of 1022 (permalink) Old 08-17-2019, 03:20 PM
Finally got the 3900X today, and test results over the 3700X are hilarious. 2C hotter under Prime95, and literally the same temp (70C) using Handbrake, still using the TS140P and lower RPM.
post #835 of 1022 (permalink) Old 08-18-2019, 09:59 AM - Thread Starter
doyll's Avatar
True Spirit 140 Power really is the best cooler out there .. and much lower priced as well!
doyll is offline
post #836 of 1022 (permalink) Old 08-18-2019, 03:16 PM
HalongPort's Avatar
Rep: 4 (Unique: 2)
Those are amazing results.
In the meantime, I've returned my LGM RT and replaced it with an ARO-M14.
My temperatures dropped from 80-82°C to 74-75°C.
However, I am still thinking about going with the True Spirit 140 Power or with an expensive Eisbaer (or equivalent AiO) just to get the most out of my 3800X.
How did you lap your cooler?
Obviously, there are a lot of tutorials and reports about lapping on the internet and a short summary is just to get a thick glass plate, sandpaper (800,1000,1200) and either make an eight or push the cooler in one direction 5-8 times and rotate it 45° clockwise.
In the end, polish it with a suitable paste.
That's quite scary for someone who never has lapped a cooler or CPU in his life. Buy a new cooler for 45-50€, lap it wrong and you neither have a working cooler or a refund option.
Edit:
In addtion, I am also thinking about replacing the 3800X with a 3700X.
My 3800X scores the same as a 3700X in Cinebench Multi and it won't boost correctly.
A 3700X produces less heat thus the ARO-M14 should be the perfect match for it.
AM4
(9 items)
3800X
Aorus Pro
Nitro R9 390
Ballistix Sport LT
ARO-M14
Define S
VG270UP
C24FG73
Audio
Titanium HD
HalongPort is offline
post #837 of 1022 (permalink) Old 08-19-2019, 07:18 AM
Lapping by hand is imprecise, but still better than a convex base. I didn't have time to try machining the base properly, but went with the hand method, using diamond-coated files that I use on guitar repairs/builds (that are flat enough for the purpose), then finished up with sandpaper (I only had up to 400 grit) on a flat metal plate (glass will work, too), and then polishing compound to at least smooth things out some. The idea is go to slowly, stay accurate, and prevent the base from being convex again, or from being tilted.
A good, flat, knife-sharpening block will also work well. With such a large cooler, it's easy to reconvex the base, so inverting it (fins down) will help. I had mine slowly spinning while I used the file, and it made a starburst, or asterisk type of pattern overall (though it was constantly turning). The base did have a small ridge that was more like this symbol: /
Once I wore that down to cover the IHS, as the base is a little larger than, I flipped it over, and used the sandpaper, which was adhesive-backed to prevent it from sliding. I'd continuously turn it while moving it back and forth, and this not only worked faster for me than a back-forth/turn method, but it also kept the base flat. Keep the fingers as close to the base as possible, lock the arms, and use your torso to move. This will help minimize odd movements, and prevent the heatsink from tipping, which will convex the edge.
If you're really unsure, try contacting a machine shop locally and see what they'd charge; the end result would be very flat.
post #838 of 1022 (permalink) Old 08-19-2019, 07:57 AM - Thread Starter
doyll's Avatar
Nice guide.
Anyone looking to remove the convex for cooler base needs to be very sure their IHS on CPU is not concave .. because if it is you will end up with a void between flat base of cooler and concave top of IHS.
doyll is offline
post #839 of 1022 (permalink) Old 08-22-2019, 02:57 PM
upgraditus's Avatar
Rep: 8 (Unique: 6)
Yet another iteration of the Macho (rev.C) is silently released with a new high speed TY 147AQ fan, more convenient side mount fan clips, 4mm less in height and they've gone back to the smaller contact plate which could be good for Ryzen 3000.
Complete nonsense (Chinese?) product highlights: "In all the quality, insist on keeping the fanless design way to achieve the perfect way to improve all the performance. The patented technology allows you to enjoy the highest perfect cooling performance for the likes of the players."
Strangely on Thermalrights page the fan is white/black whereas here it's a new grey finish...
Edit: On closer inspection the base doesn't actually look any smaller than ~52mm x 40mm so I guess their technical drawing is wrong.
= Ryzen 7 3700X 4.3GHz @ 1.3v / Thermalright TS140 BW / Prime X470-Pro / 16GB Crucial BSLT 3733 MT/s cl16 / 1080Ti Amp Extreme 2GHz @ 0.987v / Aerocool Project7 P650 / Fractal Define XL =
upgraditus is offline
post #840 of 1022 (permalink) Old 08-23-2019, 05:40 AM - Thread Starter
doyll's Avatar
You have Macho Rev. C ? I have most all other Macho coolers .. actually have had / tested / used most all Thermalright coolers and found them all to be excellent performers in their respective size groups.
doyll is offline
