Thermalright True Spirit 140 Power - Page 87 - Overclock.net - An Overclocking Community
post #861 of 898 (permalink) Old 09-05-2019, 09:28 AM
upgraditus's Avatar
Rep: 8 (Unique: 6)
Quote: Originally Posted by homestyle View Post
I’m attaching this cooler to an asrock x570 taichi and 3700x
How does this perform with 3700x?
Is ram clearance an issue or is this thin enough not to cause comparability issues?
Unsure how the power does but the standard is good so in theory you should fare even better. Low profile RAM like my Ballistix Sport LT fits under so no issues in any config, taller heatspreaders? = dual channel no issue, quad channel might foul slot A1.
= Ryzen 7 3700X 4.3GHz @ 1.3v / Thermalright TS140 BW / Prime X470-Pro / 16GB Crucial BSLT 3733 MT/s cl16 / 1080Ti Amp Extreme 2GHz @ 0.987v / Aerocool Project7 P650 / Fractal Define XL =
upgraditus is offline
post #862 of 898 (permalink) Old 09-05-2019, 10:24 AM - Thread Starter
doyll's Avatar
Rep: 1661 (Unique: 924)
Center CPU to near side of RAM socket is about 52mm so it will be tight. Depends on how tall RAM is. Can always mount fan on back of cooler pulling air through. Make sure case has enough CPU clearance for it's 171mm height.
doyll is offline
post #863 of 898 (permalink) Old 09-05-2019, 02:46 PM
homestyle's Avatar
Rep: 89 (Unique: 81)
What kind of improvement should I see going from stock wraith prism cooker on 3700x to this true cooler?
homestyle is offline
post #864 of 898 (permalink) Old 09-05-2019, 03:00 PM
⤷ αC
AlphaC's Avatar
Rep: 904 (Unique: 590)
At least 10 degree drop based off older Ryzen result
https://www.computerbase.de/2019-08/...l-standardtakt
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #865 of 898 (permalink) Old 09-05-2019, 04:22 PM
homestyle's Avatar
What fan does this come with? And what is the minimum fan speed? I bought off amazon and description says ty-147 which has 900 min rpm. But the thermalright website says this comes with ty-147a which has 300 min rpm.
That is a large delta.
post #866 of 898 (permalink) Old 09-05-2019, 09:23 PM
Abula's Avatar
Rep: 38 (Unique: 33)
My TS140P came with TY147, but if newer batches come with TY147A which has 300rpm min.
Name:	Thermalright TY-147  PWM.png
GAME - Intel i9 9900K | AsRock Z390 Tachi | G.SKILL 32GB DDR4 3200Mhz | Asus RTX2080Ti Strix | Samsung 970Pro 1TB + Samsung 860Pro 4TB
SIM - Intel i7 8700K | AsRock Z370 ITX/AC | Corsair 16GB DDR3000 | MSI RTX2080ti Duke | AData XPG 8200 Pro 1TB
SB - Intel i9 7940X | AsRock X299 Fatal1ty | G.SKILL 32GB DDR4 3200Mhz | Asus GTX1660Ti
WS - AMD 1950X | AsRock X399 Taichi | G.Skill 32GB DDR4 3200Mhz | 9271-8i 22TB Raid6 | Intel 900p 480GB
Abula is offline
post #867 of 898 (permalink) Old 09-06-2019, 03:53 AM - Thread Starter
doyll's Avatar
It would be nice if they made a black/white 600-1500rpm like black/red TY-149A .. even better 600-1800rpm like black/red TY-143B that comes on Silver Arrow T8 but in black/white. Idling at 300rpm is kinda worthless to me because at 600rom it is so quiet you have your ear so close to the impeller it might get hit. to hear fan anyway.
doyll is offline
post #868 of 898 (permalink) Old 09-06-2019, 03:48 PM
upgraditus's Avatar
Rep: 8 (Unique: 6)
With a chain of 3 (Intake->HS->exhaust) I can certainly hear them from ~1m at 600, it's not loud obviously but not silent either. At 300 with the case panel on they are below room background noise level (very low at night), I find 300-1000 perfect for my needs.
post #869 of 898 (permalink) Old 09-07-2019, 02:58 AM - Thread Starter
doyll's Avatar
What about your GPU fan/s, are they quieter or louder? What are your case fans? Do you mean you can hear them at 300rpm with ears less than a foot from case? I'm surprised you only have 3x fans in your system. Define XL supports 1x 120/140mm bottom (plus PSU), 2x front, 2x top and 1x back. With just 1x intake and exhaust your 1x in & 1x out are only moving about as much air as TS140BW uses .. and if stock case fans not that much.
Very quiet room at night is about 30dba, background level in empty recording studio is about 20dba.
doyll is offline
post #870 of 898 (permalink) Old 09-07-2019, 06:03 AM
upgraditus's Avatar
Rep: 8 (Unique: 6)
I'll list all so you can see what is going on, more than just 3 fans in total, case is inverted so CPU chain is furthest distance from ear at approx 1m (when I say chain I mean these fans are controlled from one PWM signal and powered direct from PSU).
CPU Chain = 3x TY-147A (intake->heatsink->exhaust) so ~4.8-6db(A) louder than 1 fan at any given RPM/loudness
GPU Chain = 2x TY-147A (intakes, sanded square) 2x Arctic P12 (heatsink) 1x 140mm Silent Wings 3 (1K RPM model) (exhaust)
I have a calibrated mic for eq'ing subwoofers (http://cross-spectrum.com/measuremen...ated_umik.html) but it's meant for high SPL's and the self noise is too high for these sort of levels, otherwise I'd do some measuring.
