Thermalright True Spirit 140 Power - Page 88 - Overclock.net - An Overclocking Community
post #871 of 1024 (permalink) Old 09-07-2019, 02:43 PM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
Saw this linked elsewhere , not sure how credible it is:
https://twitter.com/HardwareSci/stat...28680562229248
95W heat load seems proper but 185W result is off
edit: test regime seems to be a Z390 series Maximus Hero board, Fractal design S2 case with 2 front intake and 1 exhaust, MSI Gaming X GPU of some sort.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #872 of 1024 (permalink) Old 09-08-2019, 07:14 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
That guy is a complete clown show - https://www.overclock.net/forum/246-...l#post28109080
ciarlatano is online now
post #873 of 1024 (permalink) Old 09-08-2019, 07:17 AM - Thread Starter
doyll's Avatar
Rep: 1702 (Unique: 941)
Indeed!
Doesn't take a rocket scientist to know 212 with 4x 6mm heatpipes w/120mm fan cannot cool betterh than TRUE Spirit 140 Power with 6x 8mm heatpipes 2/ 140mm fan.
doyll is offline
post #874 of 1024 (permalink) Old 09-09-2019, 11:58 PM
Heuchler's Avatar
Rep: 274 (Unique: 193)
anybody know where to get the official Hardware Scientist mittens.
Ease of installation [while wearing mittens] . Applying even mounting pressure [while wearing mittens]. Applying even TIM layer [while wearing mittens of course]. ambient temps ... yeah I got mittens so don't worry about room temps.
edit:
guess I'm the only one that doesn't have OCN HSF mittens
Name:	Hardware Scientist.jpg
Overclocking History (Click to show)
Intel 386DX/16 @ 20 MHz
CX486SLC/50 @ 50 MHz
AM486DX2/80 @ 100 MHz
AM486 DX4-100 @ 120 MHz
AK5x86-P75 [email protected] 160 MHz
Pentium 90 @ 120 Mhz
IBM 6x86L P166+ [email protected] 160 MHz
Celeron 300a @ 454 MHz
Pentium 3 700 @ 933 MHz
Athlon XP 1400+ @ 1600 MHz
Athlon XP 1800+ @ 2088 MHz
Athlon XP 2500+ @ 2200 MHz
Athlon 64 3000+ @ 2603 MHz
Athlon X2 BE2300 @ 1900 MHz
Athlon X2 4200+ @ 2210 MHz
Athlon X2 5000+ @ 2600 MHz
Core 2 Duo E4300 @ 3000 MHz
Core 2 Duo E6750 @ 3600 MHz
Core 2 Duo E8400 @ 4000 MHz
Xeon C2Q L5408 @ 3200 MHz
Xeon C2Q X5450 @ 3300 MHz
Xeon C2Q E5440 @ 3400 MHz
Xeon C2Q E5450 @ 3600 MHz
Phenom2 X4 B50 @ 3700 MHz
Phenom2 X6 1045T @ 4050 MHz
Core i5-2500K Sandy @ 4500 MHz
X5650 6-Core Westmere @ 3982 MHz
AMD FX 8320E Black Edition
FX-8320E @4.5GHz, X5650 @ 4.0GHz, X6 1045T @4.0GHz, i7 [email protected]
Thinkpad T420p with i7-2720QM overclocked because this is OCN
Heuchler is offline
post #875 of 1024 (permalink) Old 09-26-2019, 10:27 PM
ernorator's Avatar
Rep: 2 (Unique: 2)
Welcome home little one One more to my collection. Now looking for Archon I-BE x2 and Thermalright Ultra 120 Extreme Cu
ernorator is offline
post #876 of 1024 (permalink) Old 10-01-2019, 03:53 PM
eBombzor's Avatar
Rep: 42 (Unique: 38)
Anyone put this into a Fractal R4 case? Max CPU clearance for this case is 170 and the cooler is 171 so I hope it fits lol.
eBombzor is offline
post #877 of 1024 (permalink) Old 10-01-2019, 05:28 PM
Abula's Avatar
Rep: 38 (Unique: 33)
The R4 can fit taller heatsinks, even if the manufacturer says 170, imo it can fit close to 190mm or more, when i installed the HR02 there was a lot of space left still.
GAME - Intel i9 9900K | AsRock Z390 Tachi | G.SKILL 32GB DDR4 3200Mhz | Asus RTX2080Ti Strix | Samsung 970Pro 1TB + Samsung 860Pro 4TB
SIM - Intel i7 8700K | AsRock Z370 ITX/AC | Corsair 16GB DDR3000 | MSI RTX2080ti Duke | AData XPG 8200 Pro 1TB
SB - Intel i9 7940X | AsRock X299 Fatal1ty | G.SKILL 32GB DDR4 3200Mhz | Asus GTX1660Ti
WS - AMD 1950X | AsRock X399 Taichi | G.Skill 32GB DDR4 3200Mhz | 9271-8i 22TB Raid6 | Intel 900p 480GB
Abula is offline
post #878 of 1024 (permalink) Old 10-02-2019, 03:18 AM - Thread Starter
doyll's Avatar
What Abula said. ,
TRUE Spirit 140 Power fits nicely in Fractal R4, but I don't think there is 20mm clearance.
doyll is offline
post #879 of 1024 (permalink) Old 10-02-2019, 10:31 AM
Fix it till its broke
Owterspace's Avatar
Rep: 9 (Unique: 5)
I have on in an R4, fits great. Definitely not 20mm left over.
3770K @ 4700MHz 1.35v/Thermalright True Spirit 140 Power TY-143 Push/Pull
ASRock Z77 OC Formula|8GB G.Skill Mix @ 1100MHz 9-11-9-28-2T 1.68v
EVGA GTX 980 Classified 3988 @ 1497/2001|Intel 545S 256 Striped
CM Silent Pro M2 850|Fractal Define R4/5x 120x38 1x 92x38|ZM-MFC2
Owterspace is online now
post #880 of 1024 (permalink) Old 10-02-2019, 10:32 AM
Born to ride
poliacido's Avatar
Rep: 1 (Unique: 1)
NEw owner here too
I was thinking about how to place the cooler: if vertical or horizontal... because i have a 2700X and the die is placed "vertical" when looking at the mobo, so if i install the cooler in the vertical position the hotspot on the IHS is touching only the 2 inner heatpipes. I know it's not direct die with direct touch HPs and the IHS and the colplate dissipate and spread the heat to more surface.... but anyway did anyone tried if you set it horizontally so the HPs are placed in a "crossed" way with the die and more get in touch.
My PC: - Asus Crosshair VII Hero- 3600 - 2x8 Gskill 3200 cl15- RX 5700XT Pulse - AX760 - Asus PG279Q - Corsair C70 Military Green
P.S.: My English isn't the best around, i could do some mistakes so please bear with me
poliacido is offline
