Thermalright True Spirit 140 Power - Page 89 - Overclock.net - An Overclocking Community
post #881 of 921 (permalink) Old 10-02-2019, 12:24 PM
Fix it till its broke
Owterspace's Avatar
Rep: 4 (Unique: 3)
Give it a spin see what happens.. worst case you have to spin it back.
3770K @ 4600MHz 1.315v/Le Grand Macho RT/TY-143/TF8
Asus P8Z77-V/12GB G.Skill Mix @ 1866MHz 9-10-9-24 2T 1.6v
EVGA GTX 980 Classified @ 1480/2000MHz 1.212v
Intel 545S 256 @ Raid 0, WD 1TB Black, Toshiba 1TB
Fractal Design Meshify C TG/CM Silent Pro M2 850
Owterspace is offline
post #882 of 921 (permalink) Old 10-05-2019, 12:17 AM
eBombzor's Avatar
Rep: 42 (Unique: 38)
Thanks for the help! It fits with quite a large amount of space (just less than 2cm by my ruler).
One question: when screwing the metal plate onto the mounting bracket after placing the heatsink, are you supposed to close the gap between them? Here is what I'm talking about:
There is quite a large gap and I didn't want to put too much pressure on the CPU so I left a small gap even though I could screw it in more.
Anyways I very much like the cooler. Was a little daunting to install at first because of all the pieces but it was pretty straightforward after reading the directions. Definitely easier than the 212 Evo. It's a little unfortunate that the 7nm bottlenecks the temps at times. I ran P95 torture and got up to 77 C at some point (it came back down pretty quickly) but I touched the heatsink and it wasn't even warm. But that's p95. I average around 50-65 C during CPU intensive games (after OC'ing IF to 1800) so I'm pretty happy with that
eBombzor is offline
post #883 of 921 (permalink) Old 10-05-2019, 04:12 AM - Thread Starter
doyll's Avatar
Rep: 1663 (Unique: 926)
All screws are tighten. Screws holding backing plate on back of motherboard with spacers through botherboard into barrel nuts (screw nut in instructions), screws attaching anchor mount to screw nuts, and screws holding crossbar to attaching anchor mount are all tight.
Heatpipe coolers never get hot, only warm up a little. The hottest place is inside heatpipes in base where liquid boils / expands into gas and moves away from base toward ends of heatpipes. As this vapor moves up into fins it starts cooling / contracting / condensing on the wicking material on inside of heatpipe where this liquid is cooled even more and moves back to cooler base where it starts the boiling / expanding cycle all over again. If the heatpipes and/or fins were to get hot anywhere but the base the heat transfer cycle would not work as it is designed to.
doyll is offline
post #884 of 921 (permalink) Old 10-05-2019, 05:36 PM
D-EJ915's Avatar
Rep: 4 (Unique: 4)
From mounting and remounting mine like 20 times on my 2066 and 2011 sockets it doesn't make much of any difference to screw it in all the way vs leaving a gap as far as performance is concerned. As long as the screw threading is all the way through the plate you will be fine. If you whack it maybe screw may be more likely to break due to bending as well as lateral load but generally screws snap anywhere and everywhere lol. As long as temps are okay I wouldn't worry about it if you feel like you don't want to screw all the way in, it does get really tight lol.
Kanna
Dark X299
(7 items)
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i9-9900X
EVGA X299 Dark
EVGA Geforce GTX 1080 Ti
G.Skill 4x8GB C14 3200MHz
Samsung Pro 840 250 GB
EVGA Supernova G3 1300
Phanteks PH-TC14PE
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #885 of 921 (permalink) Old 10-07-2019, 05:55 AM - Thread Starter
doyll's Avatar
Cooler mounts are designed for screws to be tightened up so there is no space between mounting components .. and that is the way I suggest everyone uses them.
Mounting a cooler with the screws not drawing up all the slack between mounting components results in less base pressure onto CPU IHS, and this almost always results is warmer temperatures.
If motherboard is in vertical orientation l(ike in tower cases) not tightening the screws all the way can result in cooler angling down with upper edge of seat not as tight as lower .. and this will definitely case higher temps.
doyll is offline
post #886 of 921 (permalink) Old 10-08-2019, 11:58 AM
Smanci's Avatar
Rep: 75 (Unique: 64)
Regardless of the mounting mechanism, coolers should be installed using the least amount of pressure possible to achieve proper contact and by avoiding overtightening. Borderline dangerous advice even if not installing on bare die.
Smanci is offline
post #887 of 921 (permalink) Old 10-08-2019, 12:38 PM
Owterspace's Avatar
Rep: 4 (Unique: 3)
I disagree.
post #888 of 921 (permalink) Old 10-08-2019, 04:51 PM
⤷ αC
AlphaC's Avatar
Rep: 908 (Unique: 590)
The reason why Scythe's Fuma version 1 had better temps than other coolers of similar design was mounting pressure.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #889 of 921 (permalink) Old 10-08-2019, 05:47 PM
D-EJ915's Avatar
Rep: 4 (Unique: 4)
These days with IHS we usually don't get broken dies from heatsink mounting pressure, that used to be extremely common when they switched from socket to flip chip.
Kanna
Dark X299
(7 items)
Mitty
(11 items)
Intel i7-7820X
Asus Strix 1080 Ti
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
Intel i9-9900X
EVGA X299 Dark
Phanteks PH-TC14PE
Intel i7-3930k
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #890 of 921 (permalink) Old 10-08-2019, 08:46 PM
Owterspace's Avatar
Rep: 4 (Unique: 3)
I haven't busted a core since s462 with a Tbred 2600. I crunched that core a few times before it stopped posting.
