Thermalright True Spirit 140 Power - Page 93 - Overclock.net - An Overclocking Community
post #921 of 924 (permalink) Old 11-08-2019, 12:26 PM
Rep: 0
Quote: Originally Posted by doyll View Post
What case do you have? I ask because most cases now have an opening in motherboard mounting panel in back of CPU so coolers can be mounted with motherboard installed. This opening is big enough to clear backing plate.
not mine, it's an ancient steel case
it only has srcew holes in the motherboard area
pepega is offline
post #922 of 924 (permalink) Old 11-22-2019, 10:04 AM
Echoa's Avatar
Rep: 69 (Unique: 54)
Looking at grabbing the TS140 power and combining it with a Noctua a14 IPPC 3000. My Cryorig H5 has served well for several years previously on my 4770k but I feel its not keeping up with how I'm wanting my Temps. Hoping TS140 might keep my R5 3600 under 70c.
The H5 can keep the 3600 at for most work but I've found hitting the CPU hard with something like prime can quickly put it at 85c so I'm trying to hopefully improve that. Thought I was gonna be good till I started attempting higher clocks with PBO and Manual OCing. Still much better than stock cooler but less than I want.
Toxic-DT
(20 items)
Toxic-SV
Toxic-LT
(14 items)
Ryzen 5 1600
Gigabyte X470 AORUS GAMING 7 WIFI
PNY XLR8 GTX 1080ti
Gskill Aegis
Intel 545s
Intel 545s
Sandisk x100
Sandisk x100
Seasonic G Series 650w
Cryorig H5
Arctic Accelero Xtreme III
Define R5
Operating System
Manjaro Budgie
Dell S2415h
Keyboard
Azio MK Retro
Mouse
Logitech G302
Audio
Focusrite Scarlett 2i2
Audio
Monoprice Retro Heaphones
Audio
Monoprice Vocal Dynamic Mic
Audio
Edifier r980t
Xeon w3670
HP z400
FirePro v4800
12gb Gkill Ripjaw
6gb Gkill Ripjaw
Hitachi Ultrastar
Silicon Power S60 SSD
Sandisk x300
HP z400
HP High Performance Cooler
HP z400
Operating System
Ubuntu Server 18.04
Other
Quad Port Intel pro/1000 et
I7 2960xm
Dell M6600
Firepro m6100
16gb Hynix DDR3 1600
Mushkin Eco3
OCZ Vertex 2
Toshiba 128GB mSATA
Delta 240w PSU
Stock m6600
Operating System
Manjaro Xfce
1920x1080 Matte M6600 Screen
Keyboard
M6600 Keyboard
Mouse
Logitech G302
Other
Wireless 375 Bluetooth
Echoa is online now
post #923 of 924 (permalink) Old 11-22-2019, 10:20 AM - Thread Starter
doyll's Avatar
Rep: 1666 (Unique: 927)
My guess is stock fan will give you good temps. If you want higher perfromance/speed fan then TY-143 is a simple swap. Changing to NF-A14 is not because it uses mounting holes spaced 124.5mm (like 140mm square fans) and TY-147 & TY-143 have 105mm hole spacing like 120mm square fans).
doyll is offline
post #924 of 924 (permalink) Old 11-22-2019, 10:52 AM
Echoa's Avatar
Well I already have the Noctua so I figured I'd give it a go on there, thanks for the heads up on the fan mount though. Worst case I use the stock one on the heatsink and Noctua somewhere else.
Edit: just had a thought, maybe I could make the cryorig fan clips work on the TS140, I know the Cryorig clips work.
Toxic-DT
(20 items)
Toxic-SV
Toxic-LT
(14 items)
Ryzen 5 1600
PNY XLR8 GTX 1080ti
Gskill Aegis
Intel 545s
Intel 545s
Sandisk x100
Sandisk x100
Cryorig H5
Define R5
Operating System
Manjaro Budgie
Dell S2415h
Keyboard
Azio MK Retro
Mouse
Logitech G302
Audio
Audio
Audio
Audio
Edifier r980t
Xeon w3670
HP z400
FirePro v4800
12gb Gkill Ripjaw
6gb Gkill Ripjaw
Hitachi Ultrastar
Sandisk x300
HP z400
HP z400
Operating System
Ubuntu Server 18.04
Other
I7 2960xm
Dell M6600
Firepro m6100
Mushkin Eco3
OCZ Vertex 2
Toshiba 128GB mSATA
Delta 240w PSU
Stock m6600
Operating System
Manjaro Xfce
Keyboard
M6600 Keyboard
Mouse
Logitech G302
Other
Echoa is online now
