Thermalright True Spirit 140 Power - Page 96 - Overclock.net - An Overclocking Community
post #951 of 993 (permalink) Old 12-06-2019, 01:57 PM
Echoa's Avatar
Rep: 72 (Unique: 54)
Quote: Originally Posted by doyll View Post
What is air temp into case vs into cooler with both CPU and GPU at full load?
I'm not completely sure, The room temp is between 65-70f but I don't have any measurements for anything else.
Toxic-DT
(20 items)
Toxic-LT
(14 items)
Ryzen 5 3600
Gigabyte X470 AORUS GAMING 7 WIFI
PNY XLR8 GTX 1080ti
Gskill Aegis
Intel 545s
Intel 545s
Sandisk x100
Sandisk x100
Seasonic G Series 650w
Cryorig H5
Arctic Accelero Xtreme III
Define R5
Operating System
Manjaro Budgie
Dell S2415h
Keyboard
Azio MK Retro
Mouse
Logitech G302
Audio
Focusrite Scarlett 2i2
Audio
Monoprice Retro Heaphones
Audio
Monoprice Vocal Dynamic Mic
Audio
Edifier r980t
I7 2960xm
Dell M6600
Firepro m6100
16gb Hynix DDR3 1600
Mushkin Eco3
OCZ Vertex 2
Toshiba 128GB mSATA
Delta 240w PSU
Stock m6600
Operating System
Manjaro Xfce
1920x1080 Matte M6600 Screen
Keyboard
M6600 Keyboard
Mouse
Logitech G302
Other
Wireless 375 Bluetooth
Echoa is offline
post #952 of 993 (permalink) Old 12-07-2019, 03:39 AM - Thread Starter
doyll's Avatar
Rep: 1674 (Unique: 931)
Below is link to how airflow works and how to optimize case airflow. Last bit is what I use to monitor case airflow into coolers.
https://www.overclock.net/forum/22319249-post5.html
doyll is offline
post #953 of 993 (permalink) Old 12-08-2019, 12:28 AM
old school 386 OC
Rep: 0
I was really interested in this cooler since its 14" and seems quiet, but it seems to be really bad in high OC situations according to this youtube review, any comments?
Or should I get eSports 34? I am running an 3570k @ 4.3g with 1.2v and am sick of noisy single slot water cooling. I want some silent pc until my next upgrade.
thanks
tike Myson is offline
post #954 of 993 (permalink) Old 12-08-2019, 04:35 AM - Thread Starter
doyll's Avatar
https://www.youtube.com/watch?v=2GSoaRsuke4
thanks
I tried to find his test procedure but it appears he doesn't give it. Therefore assume video testing procedure is flawed. It does show testing is done in a case but I see nothing about how air temp is monitored during testing. Lots of time talking about a lots of things but nothing at all about how case airflow is setup or how testing is performed. Case appears to be a stock Define case and they have case fans that can't overcome the resistance of front grill and filter so case airflow is extremely low. Testing without air temp into cooler being logged at same time as CPU temp is taken have no base for accuracy because air temp changes as fan speeds change .. and every degree change in air temp is reflected with almost exactly the same change in CPU temp at same cooler fan speeds. Also not mentioned is TRUE Spirit 140 Power is rated for 360w TDP, almost twice what he claims test is. I've ran TRUE Spirit 140 Power on I7 920 @ 3.8GHz for years and we tested at 4.3GHz against NH-D14 which cools same as NH-D15 and it was consistanly cooler as you can see in below graph in post #22 this thread:
https://www.overclock.net/forum/22111036-post22.html
What you get is up to you. But whatever you get I suggest you take the time to read "How Airflow Works and How to Optimize Case Airflow" in link below:
Because if case airflow is not setup so cooler is using cool air (not air 10-20c warmer than room) your CPU temps will be 10-20c hotter than they should. Doesn't matter how good or how bad the cooler is if case airflow isn't setup properly.
doyll is offline
post #955 of 993 (permalink) Old 12-08-2019, 05:48 PM
D-EJ915's Avatar
Rep: 10 (Unique: 10)
thanks
What cooler are you using now? TS 140 Power and Scythe Fuma 2 are probably best price/performance coolers right now at 50 and 60 dollars. I have both and Noctua D15 Chromax and they are all really good.
That review doesn't show fan speeds only db rating so no idea what speeds they are actually running fans at so it is hard to compare.
Kanna
Dark X299
(7 items)
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i9-9900X
EVGA X299 Dark
EVGA Geforce GTX 1080 Ti
G.Skill 4x8GB C14 3200MHz
Samsung Pro 840 250 GB
EVGA Supernova G3 1300
Phanteks PH-TC14PE
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #956 of 993 (permalink) Old 12-08-2019, 06:45 PM
old school 386 OC
Rep: 0
I am currently running on CoolerMaster 120 AIO water setup , when idle, it's quiet, but its pretty annoying during load. (load temps around 70c)
Yeah, I found his reviews a bit fishy and I even found his earlier "rants" on previous posts here so I will take the results with grain of salt.
But its really hard to find any overall reviews of True Spirit , just some russian reviews but not comparing with others.
Thanks guys, I'll read more previous posts as my answers were probably answered somewhere before.
post #957 of 993 (permalink) Old 12-10-2019, 06:28 AM - Thread Starter
doyll's Avatar
Even without fan speeds that review's data is totally out of line. TRUE Spirit 140 Power perform similar to NH-D15. Well actually it performs slightly better than NH-D14 when we tested it with TY-143 fan/s at 1200rpm and 2500rpm, and ehume's comparison testing of NH-D14 against NH-D15 with same fans found D14 to similar to slightly better than D15. No idea what the problem is but there is something seriously wrong .. and any decent reviewer would have at the very least acknowledged something was wrong with results, be it a defective cooler, bad TIM seat, etc.
There are several reviews posted in this thread. If you skip through you will find them and links to view them.
doyll is offline
post #958 of 993 (permalink) Old 12-17-2019, 10:39 AM
1689 Federalist
lightsout's Avatar
Rep: 250 (Unique: 214)
How is the ram clearance on this cooler? I am using AM4 on a b450 ITX Strix board. I have the Macho Rev B and always have ram issues. Even low profile vengence won't fit I had to mod the fan.
I have some Gskill tridentz that I can't use. Does the fan cover the ram or can you use whatever?
Black Box
(11 items)
R5 2600X
Asus Strix B450-I
Sapphire Reference RX 5700
GSkill 16gb 3200c14 Flare
500gb SSD
EVGA G1+ 850
Macho Rev B
NZXT H200 Black
LG 32GK650F-B 1440p 144hz
Mouse
Sensei Raw
Audio
Sony Core Bookshelves
lightsout is offline
post #959 of 993 (permalink) Old 12-17-2019, 10:48 AM
deepor's Avatar
Rep: 479 (Unique: 325)
According to the drawings I could find on thermalright.de, this TS140-Power here should have the exact same problem as what you have on your Macho-Rev-B. The drawings I looked at showed that on both coolers the base is 53 mm long. The front of the fin-stack then starts at the edge of that 53mm base on both coolers.
deepor is offline
post #960 of 993 (permalink) Old 12-17-2019, 11:12 AM
1689 Federalist
lightsout's Avatar
So what do people do with air coolers and ram these days? I guess I could put it in pull config, but these fans are pretty low speed. Seems like a pain of a problem.
Black Box
(11 items)
R5 2600X
Asus Strix B450-I
500gb SSD
EVGA G1+ 850
Macho Rev B
NZXT H200 Black
Mouse
Sensei Raw
Audio
