NH-D15 - Overclock.net - An Overclocking Community
NH-D15
post #1 of 31 (permalink) Old 04-08-2014, 03:48 AM - Thread Starter
Retired Reviewer
ehume's Avatar
Rep: 1373 (Unique: 856)
ehume is offline
post #2 of 31 (permalink) Old 04-08-2014, 04:06 AM
Rep: 58 (Unique: 53)
Only one problem with this cooler, just like the SilverArrow SB-E, it is going to block the top expansion slot on my motherboard.
So do you have a review sample or can you not confirm or deny that?
mam72 is offline
post #3 of 31 (permalink) Old 04-08-2014, 04:20 AM
doyll's Avatar
Rep: 1696 (Unique: 938)
Specification differences are significant:
NH-D15(with fans) = 165x150x161mm(H,W,D), 1320g, 2x NF-A15 PWM 1500rpm 140,2 m³/h 24.6dBA
NH-D14(with fans) = 160x140x151mm(), 1070g, NF-P14 / NF-P12 1200/1300rpm 110,3 / 92,3 m³/h 19,6 / 19,8dB(A
NH-D15 is 5x10x10mm bigger; 250g heavier; 200/300rpm faster; 40m³/h more air (guessing) and is almost 5dBA louder at full speed
doyll is offline
post #4 of 31 (permalink) Old 04-08-2014, 06:36 AM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
The price is EUR 89.90 / USD 99.90 :S
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #5 of 31 (permalink) Old 04-08-2014, 07:49 AM
doyll's Avatar
What is PCI-E socket to center CPU measurement on your mobo?
doyll is offline
post #6 of 31 (permalink) Old 04-08-2014, 08:37 AM
I don't know the measurements but the motherboard is a Rampage IV extreme. I can get a way with 140mm wide heatsinks like the D14 or the Phanteks. Also I have 2 GPUs so I need to keep them as far apart as I can.
mam72 is offline
post #7 of 31 (permalink) Old 04-08-2014, 08:54 AM
doyll's Avatar
Silver Arrow IB-E is offset base with 67.8mm side of cooler to center of CPU compared to NH-D14 being 70mm.thumb.gif
doyll is offline
post #8 of 31 (permalink) Old 04-08-2014, 08:59 AM
Yeah I have been eyeing that on scan biggrin.gif. Should I go for the extreme or the normal one thinking.gif
Well my D14 will have to do for just now.
mam72 is offline
post #9 of 31 (permalink) Old 04-08-2014, 09:05 AM
doyll's Avatar
doyll is offline
post #10 of 31 (permalink) Old 04-08-2014, 08:03 PM
ohhgourami's Avatar
Rep: 67 (Unique: 54)
Now for me to be able to buy one...
Interesting how they are using the 1500rpm version of the NF-A15 on this cooler. I'll probably end up using the 1200rpm versions I currently have and I already limit them to 1000rpm.
ohhgourami is offline
