Noctua NH-D15 Club - Page 177 - Overclock.net - An Overclocking Community
Noctua NH-D15 Club
post #1761 of 1768 (permalink) Old 08-23-2019, 07:46 AM
Pedros's Avatar
Rep: 31 (Unique: 28)
Quote: Originally Posted by doyll View Post
What ciarlatano said. D15 and D15 perform almost exactly the same with same fans, if anything the D14 is maybe 1c better. If it was me and you can't fit 171mm tall by 155mm wide TRUE Spirit 140 Power in, them D14 or D15S would be good choice. D15S has offset fin packs so does not reach as far down toward PCie sockets. It is also less money with only one fan that you plan replacing with TY-143's anyway.
But TRUE Spirit 140 Power with TY-14e's is even better if it will fit.
Really, True Spirit > NH-D15? I've been out so of the air cooling scene so I always go by the rule of thumb of the NH-D14 and NH-D15 being the top dogs
"Oh...your ass is grass and I've got the weed-whacker."
The Hive
(17 items)
i7 4790K 4.8Ghz @ 1.31v (Delided)
Msi Z97 Gaming 7
MSI GTX 1080Ti Seahawk X
Kingston HyperX Savage
Samsung 960 Pro M.2
Crucial MX500 2Tb
XFX Black Pro 1250W
Corsair H105 Push/Pull
Corsair Carbide Air 740
Operating System
Windows 10
LG 32" 32GK850G
Keyboard
Logitech G512 / Ducky One Mini
Mouse
Glorious XXL
Mouse
Logitech G Pro Wireless
Audio
Philips Fidelio X2
Audio
WHARFEDALE10.2 + WHARFEDALE D10
Audio
Burson Playmate + Burson Bang Amp
Pedros is offline
post #1762 of 1768 (permalink) Old 08-23-2019, 08:13 AM
doyll's Avatar
Rep: 1661 (Unique: 924)
It beat D14 by 1-2c on i7 920 @ 4.3GHz, and D14 is as good if not a little better than D15, so yeah it is better .. also about $50 which is a steal for how well it performs.
https://www.overclock.net/forum/22111036-post22.html
doyll is offline
post #1763 of 1768 (permalink) Old 09-21-2019, 07:17 AM
spddmn24's Avatar
Rep: 7 (Unique: 7)
I swapped from my darkrock pro 4 back to my NH-d15. One unintended side effect was the NH-d15 helping my case airflow. The front fan sticking up to clear the ram has the side effect of helping case airflow and forcing the gpu heat out the back of the case. My cpu temps are down ~3c and the gpu is down ~2c. I can physically feel the air off the front fan exiting the back of the gas against the glass side panel. This is why open test bench test results aren't always indicative of real world performance.
Coffee
8700k
Z370 AORUS Gaming 7
ROG-STRIX-GTX1080TI-11G-GAMING
F4-3866C18D-16GTZKW
750 evo
850 evo
XPG SX8200
evga 750 g2
NH-D15
SilverStone Primera
Operating System
windows 10 pro
Mouse
g502 lightspeed
Audio
598
spddmn24 is offline
post #1764 of 1768 (permalink) Old 09-21-2019, 08:54 AM
Retired Reviewer
ehume's Avatar
Rep: 1372 (Unique: 855)
Now, if you really want to improve your case airflow you will take some tin snips and cut away the rear "grill" of your case. It is really not a grill but a perforated wall. See #2 in my sig for an old trial of this. You cover the cut edges with Gorilla tape, and if you have a problem with little fingers, there are finger guards for sale: you use fan screws and #10 nylon license plate nuts (available from auto supply stores) to hold them on.
I love the D15, but I also love the D14 with new fans.
ehume is offline
post #1765 of 1768 (permalink) Old 09-29-2019, 06:17 AM
Rep: 132 (Unique: 90)
Quote: Originally Posted by ehume View Post
Now, if you really want to improve your case airflow you will take some tin snips and cut away the rear "grill" of your case. It is really not a grill but a perforated wall ...
^ Wise words from ehume there.
TELVM is offline
post #1766 of 1768 (permalink) Old 09-29-2019, 07:59 AM
Retired Reviewer
ehume's Avatar
Empty rear window.
I leave my rear windows untenanted after I remove the grill. Instead, I use the pull fan on whatever heatsink I am using to entrain case air and exhaust the case. Item 2 in my sig illustrates the method. But one thing I have learned over the years: Gorilla tape will do a fine job of covering the cut edges.
ehume is offline
post #1767 of 1768 (permalink) Old 09-29-2019, 02:39 PM
Interestingly I always do almost exactly the opposite of what you describe in item 2 of your sig, ehume.
I cover and seal air tight each and every opening in the case, except those in front of intake fans and those behind exhaust fans, which I clear to the utmost. And I'd never left the back or the top rear exhaust fan positions unpopulated, nope nope.
More than one way to skin the cat I guess :-) .
My 2600X with an NH-D15 ontop maxes out @ 54C / 129F running Cinebench R15 (22C / 72F ambient):
TELVM is offline
post #1768 of 1768 (permalink) Old 09-29-2019, 03:24 PM
Retired Reviewer
ehume's Avatar
I just did that experiment in item 2 . . . as an experiment. I wanted to see what a push-pull could do. Since then, I suck from the front and let the air find its own way out the back. The experiment only showed that the pull fan of a heatsink could evacuate a case.
ehume is offline
