Noctua NH-D15 Club - Page 2 - Overclock.net - An Overclocking Community
Noctua NH-D15 Club
post #11 of 2009 (permalink) Old 04-10-2014, 01:16 PM
doyll's Avatar
Rep: 1693 (Unique: 937)
It definitely is bigger.
Specification differences:
NH-D15(with fans) = 165x150x161mm(H,W,D), 1320g, 2x NF-A15 PWM 1500rpm 140,2 m³/h 24.6dBA
NH-D14(with fans) = 160x140x151mm(), 1070g, NF-P14 / NF-P12 1200/1300rpm 110,3 / 92,3 m³/h 19,6 / 19,8dB(A
NH-D15 is 5x10x10mm bigger; 250g heavier; 200/300rpm faster; 40m³/h more air (guessing) and is almost 5dBA louder at full speed
There are 2 NF-A15 fans;
The 1500rpm version supplied with coolers.
And the 1200rpm one we can buy.
Deepor found this in NH-U14S manual there are two versions of A15
Please note that while the NF-A15 fan included with NH-U14S runs at 1500rpm, Noctua recommends using the standard 1200rpm retal version as a rear fan in push/pull mode as the combination of 1500rpm at front and 1200rpm at the rear will provide the best balance of performance and acoustics.
If you would like to run both fans at same speed, please use the supplied Low-Noise Adaptor on the front fan to reduce the speed to 1200rpm.
See here, second page, middle column; "Adding a second fan": http://noctua.at/pdf/manuals/noctua_nh_u14s_manual_en.pdf
doyll is offline
post #12 of 2009 (permalink) Old 04-10-2014, 02:06 PM
It's still almost enough.
Chunky_Chimp's Avatar
Please note that clubs and threads in general can't be made official unless approved by staff; since this section still has no specific Editor, it falls on mega_option101 to decide.
Combined air and water cooling tips: Fan database | My San Ace 9G1212H1011 review | Don't mix metals or use premixes / dyes | Distilled vs. tap water | Good radiator brands | Water (almost) can't flow too fast | Which PT Nuke to use | Regarding thermal paste spreading
Deep Blood
(15 items)
Soft Sentinel
Intel Core i7 920 D0 (Batch # 3901A240)
Foxconn X58 Blood Rage (non-GTI)
Sapphire Vega 64 8GB
6GB Corsair Dominator 1.6GHz TR3X6G1600C8D Rev 3.2
Samsung SSD830 128GB / Seagate 640GB+2TB+2x4TB
Optical Drive
Samsung SH-S223Q 22X
Antec HCPP-850
XTTH | OCZ Freeze | 9G1212H1011
CaseLabs SM8
Operating System
Windows 7 Ultimate x64 SP1
Dell U2410f (rev. A02)
Keyboard
Code 104 w/O-rings + Vortex PBT/POM doubleshot keycaps
Mouse
Roccat Kone EMP w/Dechanic Mini pad
Audio
Asus Xonar DX / Klipsch RM-14s + Dayton DTA-120 / MXL Tempo
Other
Microsoft Lifecam Cinema
Intel Core 2 Duo E6320
Intel DP35DP
XFX GeForce 7600GT
2GB Mushkin DDR2 800 5-5-5-12
Seagate Barracuda 7200.10 320GB
Optical Drive
Asus 18x multi-burner
Enermax Liberty 400w modular
Rosewill R5604-TBK
Operating System
Windows XP Pro SP3 32-bit
Samsung LN-S2351W
Keyboard
Ideazon MERC
Mouse
Logitech MX-518 (rev.2; 1800 DPI [no Teflon feet])
Mouse
Xtrac Pads Ripper
Chunky_Chimp is offline
post #13 of 2009 (permalink) Old 04-10-2014, 03:53 PM - Thread Starter
Capt's Avatar
Rep: 148 (Unique: 126)
Ah, my bad, didn't know.
Capt is offline
post #14 of 2009 (permalink) Old 04-10-2014, 05:09 PM
doyll's Avatar
[Official] is really a joke. Fractal Design Case Club thread has over 11,000 post and is not [Official] rolleyes.gifbiggrin.gif
doyll is offline
post #15 of 2009 (permalink) Old 04-12-2014, 06:45 AM
M'aiq the Liar
BoredErica's Avatar
Rep: 418 (Unique: 272)
The [Official] Haswell thread is dead and the original post stopped updating BEFORE Haswell came out. My thread has 12,000+. Go figure. ;)
I want to see D15 reviews and I want to see them now! NOW!!!! :mad:
BoredErica is offline
post #16 of 2009 (permalink) Old 04-12-2014, 12:45 PM
Micko's Avatar
Rep: 9 (Unique: 8)
Doyll can you give us a rough estimate of delta t we can expect between NH-D14 and NH-D15 ? Thanks.
Micko is offline
post #17 of 2009 (permalink) Old 04-12-2014, 01:08 PM
Rep: 58 (Unique: 53)
The D15 around 1-5°C cooler, This Is An Estimate.
mam72 is offline
post #18 of 2009 (permalink) Old 04-12-2014, 01:24 PM - Thread Starter
Capt's Avatar
In my opinion, maybe 2-3c cooler under load compared to the NH-D14.
Capt is offline
post #19 of 2009 (permalink) Old 04-12-2014, 02:08 PM
doyll's Avatar
I would guess it will perform better but really don't want to guess. Hopefully some will be reviewed soon.
doyll is offline
post #20 of 2009 (permalink) Old 04-15-2014, 06:28 PM
doyll's Avatar
First review of NH-D15
http://www.modders-inc.com/noctua-nh-d15-dual-tower-cpu-cooler-review/
Very similar performance to PH-TC14PE even though NH-D15 uses 1500rpm 82.52cfm NF-A15 Premium fans compared to first generation PH-TC14PE using 1300rpm 78.1cfm PH-F140TS fans. Current PH-TC14PE coolers come with 1300rpm 88.6cfm PH-F140HP fans. Assuming this review is accurate, with improved PH-F140HP fans now used on PH-TC14PE, it should easily be equal to, maybe even slightly better than NH-D15.
doyll is offline
