Noctua NH-D15 Club - Overclock.net - An Overclocking Community
Noctua NH-D15 Club
post #1 of 2009 (permalink) Old 04-09-2014, 11:27 AM - Thread Starter
Capt's Avatar
Rep: 148 (Unique: 126)
Welcome to the Noctua NH-D15 Club!
Built on the basis of the legendary NH-D14 and carrying on its quest for ultimate quiet cooling performance, Noctua’s flagship model NH-D15 is an elite-class dual tower cooler for the highest demands. Its expanded heatpipe layout and two premium grade NF-A15 140mm fans with PWM support for automatic speed control allow it to further improve the NH-D14’s award-winning efficiency. Topped off with the trusted, pro-grade SecuFirm2™ multi-socket mounting system, Noctua’s proven NT-H1 thermal compound and full 6 years manufacturer’s warranty, the NH-D15 forms a complete premium quality solution that represents a deluxe choice for overclockers and silent-enthusiasts alike.
About Noctua
Designed in Austria, Noctua's premium cooling components are internationally renowned for their superb quietness, exceptional performance and thoroughgoing quality. Having received more than 3000 awards and recommendations from leading hardware websites and magazines, Noctua's fans and heatsinks are chosen by more than a hundred thousand satisfied customers around the globe.
Noctua's Website
Noctua NH-D15 Reviews Warning: Spoiler! (Click to show)
Noctua NH-D15 Specifications Warning: Spoiler! (Click to show)
Socket compatibility         Intel LGA2011 (Square ILM), LGA1156, LGA1155, LGA1150 & AMD AM2, AM2+, AM3, AM3+, FM1, FM2, FM2+ (backplate required)
Height (without fan)            165 mm
Width (without fan)             150 mm
Depth (without fan)             135 mm
Height (with fan)               165 mm
Width (with fan)                150 mm
Depth (with fan)                161 mm
Weight (without fan)            1000 g
Weight (with fan)               1320 g
Material                Copper (base and heat-pipes), aluminium (cooling fins), soldered joints & nickel plating
Fan compatibility               140x150x25 (with 120mm mounting holes), 140x140x25 (with 120mm mounting holes), 120x120x25
Scope of Delivery
2x NF-A15 PWM premium fan
2x Low-Noise Adaptor (L.N.A.)
Y-cable
NT-H1 high-grade thermal compound
SecuFirm2™ Mounting Kit
Noctua Metal Case-Badge
Warranty                6 Years
Fan Specifications
Fan specifications
Model           2x Noctua NF-A15 PWM
Bearing         SSO2
Max. Rotational Speed (+/- 10%)         1500 RPM
Max. Rotational Speed with L.N.A. (+/- 10%)             1200 RPM
Min. Rotational Speed (PWM, +/-20%)             300 RPM
Max. Airflow            140,2 m³/h
Max. Airflow with L.N.A.                115,5 m³/h
Max. Acoustical Noise           24,6 dB(A)
Max. Acoustical Noise with L.N.A.               19,2 dB(A)
Input Power             1,56 W
Voltage Range           12 V
MTBF            > 150.000 h
Noctua NH-D15 Pricing and availability Warning: Spoiler! (Click to show)
The NH-D15 will be available by mid-April at suggested retail prices of EUR 89.90 / USD 99.90.
How To Join The Club Warning: Spoiler! (Click to show)
To join this club simply post a pic of your NH-D15 in this thread and I will add you to the list. You are also welcome to post any pics of your rig with the NH-D15 installed so we could see how it fits in your case and if it touches the first PCIe slot of your mobo. Don't double post and keep quoted pics with the spoiler tag so it doesn't get messy.
Capt is offline
post #2 of 2009 (permalink) Old 04-09-2014, 11:28 AM - Thread Starter
Capt's Avatar
Members:
Signature:
[OCN] Noctua NH-D15 Club
[URL=https://www.overclock.net/t/1480717/official-noctua-nh-d15-club/0_30][OCN] Noctua NH-D15 Club[/URL]
Capt is offline
post #3 of 2009 (permalink) Old 04-09-2014, 11:31 AM - Thread Starter
Capt's Avatar
Capt is offline
post #4 of 2009 (permalink) Old 04-09-2014, 12:26 PM
Linux Lobbyist
mav451's Avatar
Rep: 44 (Unique: 34)
Haha here I am Googling for a update on the price (because of Robilar's post about 50mins ago) and then I stumble on this.
http://heatware.com/eval.php?id=31362Build History (Click to show)
CPU History:
Thunderbird-C 800Mhz, 2100+ TBred B, 2600+ XP-M, Opteron 146, Core2 e8400, i5 750, i5 4670K
MB History:
A7V, A7N8X rev1.06, DFI NF4 Ultra-D, DFI LT P35, GB P55-UD3R, GB Z87-UD4H
GPU History:
Matrox G400, ATi 8500LE, ATi 9800Pro, Leadtek 6800NU, BFG 7800GT, BFG 8800GT, GTX 260, eVGA GTX 560 Ti, Zotac GTX 580, eVGA GTX 780, eVGA 980Ti
mav451 is offline
post #5 of 2009 (permalink) Old 04-09-2014, 01:21 PM
doyll's Avatar
Rep: 1697 (Unique: 938)
ehume started a thread yesterday.. like over 30 hours ago.. for NH-D15.
www.overclock.net/t/1480290/nh-d15/0_20
https://www.overclock.net/t/1480290/nh-d15/0_20#post_22082242
Now you use [Offical] rolleyes.gif and start another one. On what authority do you make this one more "official" than ehume's ???
doyll is offline
post #6 of 2009 (permalink) Old 04-09-2014, 03:23 PM - Thread Starter
Capt's Avatar
That thread is more of an announcement of the NH-D15. This thread on the other hand will be the official club of the NH-D15.
Capt is offline
post #7 of 2009 (permalink) Old 04-09-2014, 08:28 PM
Retired Reviewer
ehume's Avatar
Rep: 1373 (Unique: 856)
Yeah. I agree with that.
ehume is offline
post #8 of 2009 (permalink) Old 04-10-2014, 02:44 AM
doyll's Avatar
I stand corrected.
Capt, please accept my apology for jumping at you the way I did.
doyll is offline
post #9 of 2009 (permalink) Old 04-10-2014, 08:41 AM - Thread Starter
Capt's Avatar
I stand corrected.
Capt is offline
post #10 of 2009 (permalink) Old 04-10-2014, 10:01 AM
Devotii's Avatar
Rep: 3 (Unique: 2)
Gosh that thing is a beast!!
Devotii is offline
