* * Ways to Better Cooling; Airflow, Cooler & Fan Data..* - Page 153 - Overclock.net - An Overclocking Community
post #1521 of 1530 (permalink) Old 07-04-2019, 07:12 AM
Rep: 0
What's the best fan solution for best case airflow exists on the market today, among 120 and 140mm fans?
Pure perfomance or perfomance/price, but price isn't the most concern here atm.
Robostyle is offline
post #1522 of 1530 (permalink) Old 07-04-2019, 07:29 AM - Thread Starter
doyll's Avatar
Rep: 1645 (Unique: 922)
Is noise a consern? I ask because for most of us it is eqully important as airflow is.
doyll is offline
post #1523 of 1530 (permalink) Old 07-04-2019, 07:49 AM
Rep: 0
Ofc. I must say, it's even #1 concern, I won't hesitate sacrificing some airflow for silence.
So basically, the best options for airflow under 800/1000/1200rpm, right?
post #1524 of 1530 (permalink) Old 07-04-2019, 07:59 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 397 (Unique: 270)
Thermalbench is down at the moment, or I would post up data. The be quiet! Silent Wings 3 are pretty much the undisputed leader in airflow to noise in 120 and 140mm, and have a really smooth sound signature.
ciarlatano is offline
post #1525 of 1530 (permalink) Old 07-04-2019, 07:59 AM - Thread Starter
doyll's Avatar
Best in my book are be quiet! Silent Wings 3 140mm PWM high speed with same in 120mm 2nd best, but only because 140mm fans tend to flow more air at same noise level by a 2:3 ratio. It takes 3x 120mm fans to equal the same airflow as 2x 140mm fans making less noise.
doyll is offline
post #1526 of 1530 (permalink) Old 07-04-2019, 08:24 AM
Rep: 0
Yeah, I agree about 140mm - thankfully, my case supports 140mm all over, so I think 140mm is a way to go.
So, be quiet! Silent Wings 3 it is then. They are really good at low RPM - misunderstood that part about "PWM high speed"?
P.S. BTW, at the moment I'm using eLoops as radiator fans + one Noctua A14 chromax, and I must admit, overall, six 120mm NoiseBlockers are way quieter than one 140mm noctua. That might be placement issue, but this made me think that I should ask for options first before blindly buying noctua once again :/
post #1527 of 1530 (permalink) Old 07-04-2019, 08:43 AM - Thread Starter
doyll's Avatar
Indeed, even if Silent Wings 3 have same DBa sound pressure level it's a much more pleasant sound so we don't notice it as much.
doyll is offline
post #1528 of 1530 (permalink) Old 07-04-2019, 08:49 AM - Thread Starter
doyll's Avatar
The "PWM high speed" is PWM control with maximum speed of 1600rpm instead of maximum speed of only 1000rpm. While probably 99% of the time 1000rpm is as fast as you will run them, there might be a few occasions when the extra speed will be nice to have .. like super hot days when case filters are dirty.
doyll is offline
post #1529 of 1530 (permalink) Old 07-09-2019, 05:10 PM
Rep: 0
Regarding be quiet! Silent Wings 3 140mm PWM High Speed fans - I have two of them installed as intake and compared to my previous Noctua NF P14s Redux-1200 PWM they have superior characteristics but they also emit this weird high-pitched grinding noise. It sounds like something in between a tiny stream of running water and crickets chirping at night. It's not loud and I usually don't notice it but with Noctua Redux fans I only heard the aerodynamic noise. So a tiny bit of buyer's remorse here.
Mungojerrie is offline
post #1530 of 1530 (permalink) Old 07-09-2019, 09:01 PM
Rep: 3 (Unique: 3)
That sounds broken
Enviado desde mi Redmi Note 3 mediante Tapatalk
Shenhua is offline
