* * Ways to Better Cooling; Airflow, Cooler & Fan Data..* - Page 6 - Overclock.net - An Overclocking Community
post #51 of 1557 (permalink) Old 04-06-2015, 11:33 AM
curmudgeon
miklkit's Avatar
Rep: 306 (Unique: 177)
I replaced some Aerocool Sharks with AC DS fans and while they are a little quieter they don't move much air. Temps went up so I replaced them with el cheapo Arctic Cooling F12s and temp and noise went down.
There are lots of better fans out there than the DS.
IOKIYAR
Junkyard Dog
(18 items)
Blackie
(17 items)
AMD Ryzen 1700
Biostar X370 GT7
Sapphire Nitro+ Radeon Vega 64
G. Skill Ripjaws ddr4 3200 16 GB 4x4
Samsung 850 EVO 500gb SSD
Western Digital 500gb
Samsung 860 evo 1tb ssd
Optical Drive
Memorex Lightscribe dvd
Seasonic 850 watt
Thermalright Silver Arrow IB-E Extreme
Silverstone Redline RL05
Operating System
Win 10 64bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent vertical mouse
Mouse
yes
Audio
Creative X-FI
Other
Sennheiser headphones HD 599
AMD FX8370 @ 5 ghz
ASUS Sabertooth
Sapphire Fury
G Skill F3-14900CL9Q-16GBXL
Western Digital
Samsung 850 EVO
Optical Drive
Seasonic SS-850KM Active PFC F3
Silverstone Redline RL02b
Operating System
Win X 64 bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent VM4
Mouse
yes
Audio
Creative Soundblaster Z
Audio
Sennheiser 428 headphones
miklkit is offline
post #52 of 1557 (permalink) Old 04-08-2015, 06:27 AM
cephelix's Avatar
Rep: 62 (Unique: 47)
@doyll
Hey there, since this seems the most appropriate place, I thought I'd ask you questions I have regarding airflow in the case here instead of starting a new thread.
First of all, the specs for my current build are in my sig, but basically it's in a Corsair 750D, Running a Noctua NH-D15 with stock fans and an MSI R9 290. The case is elevated off the ground, placed on a cabinet with no obstructions to intake or exhause beyond the already restrictive front panel and Demciflex filters. For fans i'm using 7 x AP-15 for all intakes and rear exhaust. The blue rectangle in the picture consists of 2 x Bitfenix Spectre Pro LEDs hung from a bracket.
All intake fans are run off a fan controller (NZXT Sentry 3) at 40% when doing day to day tasks but would be ramped up when needed. The Noctuas and rear exhaust are run off the motherboard with the exhaust having a more aggressive fan profile in order to exhaust out warm air at a higher rate. Ambient temps are around 30deg C and cooler intake temps hover around 2-3 degrees higher.
With fans in their lower settings, I get temps about 6-8 degree above ambients for my cpu but when I crank all the fans to their full rpms, i somehow get warmer temps. Could this be because I have insufficient exhausts? Or that warm air is recirculating back into the case?
Also, i'm thinking of ghetto-rigging another fan to the pcie brackets to obtain a "straighter" path of fresh air past the gpu. In your opinion, would this help in any way or would it just be a waste of time?
Kindest Regards,
Ali
Elevated
(22 items)
i7 4790K
Gigabyte Z97X Gaming 7
MSI Vega 56
Kingston Low Voltage Value Ram
Crucial M500 480GB
Western Digital Green 3TB
Seasonic X750
EK Supremacy Evo
Nidec Servo Gentle Typhoons 1850rpm x 8
Alphacool Nexxos XT45 360mm
Alphacool Monsta 240mm
EK Radeon Vega Acetal+Copper Full Cover
EK XTop D5 PWM Revo
Corsair Obsidian 750D
Operating System
Windows 10 Pro 64-bit
Philips 240B1CB 1920 x 1200
Samsung Syncmaster 2443BW 1920 x 1200
Keyboard
Filco Majestouch 2 Ninja TKL
Mouse
Zowie FK-1
Mouse
Barracuda Juggernaut
Audio
Corsair H2100 Wireless Headset
Other
NZXT Sentry 3
cephelix is offline
post #53 of 1557 (permalink) Old 04-08-2015, 07:26 AM - Thread Starter
doyll's Avatar
Rep: 1661 (Unique: 924)
Hi @cephelix
Looks like a good system.
I think what you are experiencing is what I call airblow, not airflow.
  • Airflow is cool air moving into case to coolers and their heated exhaust moving on out of case without contaminating the cool airflow.
  • Airblow is air moving everywhere mixing heated and cool air and raising temps.
Think of the case as a tub full of water. We want cool water flowing in at one end of tub and the warmed water moving out the other end .. not a jacuzzi mixing it all up.
My suggestions are:
For intakes 2x front, 1x bottom & 1x top should be plenty. Remove all unused PCIe back covers and anything else you can to improve front to back airflow. We want the GPU exhaust to move back and out of case .. out the side if there is a vent directly over or slightly above it sometimes works well. It is often a lot of trial and error experimentation finding the best combination.
doyll is offline
post #54 of 1557 (permalink) Old 04-08-2015, 07:33 AM
cephelix's Avatar
Originally Posted by doyll View Post
Hi @cephelix
My suggestions are:
Yeah, I think i am experiencing airblow as well...didn't want to use the term since i wasn't sure I'd be using it correctly. I've already removed all unused pcie brackets but i may put them back on since sometimes my nieces and nephews come over and they may be very tempted to put stuff into the slots...The case doesn't have a side vent though. Any thoughts on strapping another exhaust to the free pcie slots?
I would try out your configuration when stressing my comp and see if that makes any difference....
Elevated
(22 items)
i7 4790K
MSI Vega 56
Crucial M500 480GB
Seasonic X750
EK Supremacy Evo
EK XTop D5 PWM Revo
Operating System
Keyboard
Mouse
Zowie FK-1
Mouse
Audio
Other
NZXT Sentry 3
cephelix is offline
post #55 of 1557 (permalink) Old 04-08-2015, 07:39 AM
LostParticle's Avatar
Rep: 98 (Unique: 75)
@cephelix. hello, I peg your pardon but I'd like to tell you my subjective and personal opinion, as well, since it is already hiding inside your post :
Ambient temps are around 30deg C ...
Do not expect much.
Thank you.
Intel Core i7-4790K
(27 items)
Intel Core i7-4790K
ASRock Z97 OC Formula; ASUS MAXIMUS VII HERO; Gigabyte Z97X-SOC Force
EVGA GTX 1060 SC GAMING 6 GB
G.SKILL F3-1866C8D-16GTX
Samsung 850 EVO 250 GB
SanDisk Extreme Pro 240GB
Samsung 840 PRO 128GB
Plextor PX-128M5S 128GB
WD 1002FAEX 1TB Caviar BLACK (in enclosure)
Corsair AX760 (Platinum); EVGA SuperNova 750 G2
Corsair H110
2 x Noctua NF-A14 industrialPPC-2000/3000 PWM (Push)
Case Fan: 1 x Noctua NF-A14 PWM (rear, exhaust)
Case Fan: Noctua NF-S12A PWM (front, intake)
Case Fans: 2 x Noctua NF-S12A FLX (front, intake)
Noctua NH-D15S
Corsair Air 540
Operating System
Windows 10 Pro 64 bit
Operating System
Windows 10 TP
Operating System
Linux Mint 18.3 Cinnamon
HP ZR2440w
Dell U2311H
Keyboard
Microsoft Ergonomic keyboard 4000
Audio
Sennheiser HD 600
Audio
Asus Xonar Essence STX II
Other
Aquaero 5LT
Other
THRUSTMASTER GPX LIGHTBACK FERRARI F1 GAMEPAD
LostParticle is offline
post #56 of 1557 (permalink) Old 04-08-2015, 07:45 AM
Dwhite311988's Avatar
Rep: 0
Any suggestion on fan setup with the current hardware that I posted? The 980 Hall of Fame exhausts air into the case.
Dwhite311988 is offline
post #57 of 1557 (permalink) Old 04-08-2015, 07:59 AM
cephelix's Avatar
Do not expect much.
Thank you.
Oh,i know about that...these are just normal operating temps..when i get down to stressing i'll turn the air conditioning on.that brings ambients down to 25 degrees.weird thing is the thermistor on my fan control,which i put about 5cm away from the cooler intake displays 23deg.lol.i may need to adjust the thermistor's position
Elevated
(22 items)
i7 4790K
MSI Vega 56
Crucial M500 480GB
Seasonic X750
EK Supremacy Evo
EK XTop D5 PWM Revo
Operating System
Keyboard
Mouse
Zowie FK-1
Mouse
Audio
Other
NZXT Sentry 3
cephelix is offline
post #58 of 1557 (permalink) Old 04-08-2015, 08:04 AM
Originally Posted by cephelix View Post
Oh,i know about that...these are just normal operating temps..when i get down to stressing i'll turn the air conditioning on.that brings ambients down to 25 degrees...
Intel Core i7-4790K
(27 items)
Intel Core i7-4790K
Corsair H110
Noctua NH-D15S
Corsair Air 540
Operating System
Operating System
Windows 10 TP
Operating System
HP ZR2440w
Dell U2311H
Keyboard
Audio
Sennheiser HD 600
Audio
Other
Aquaero 5LT
Other
post #59 of 1557 (permalink) Old 04-08-2015, 08:07 AM
cephelix's Avatar
Cross your fingers and wish me well...forgot to mention,if it makes any difference that the cpu sits in the path of the aircon vent as well...
Elevated
(22 items)
i7 4790K
MSI Vega 56
Crucial M500 480GB
Seasonic X750
EK Supremacy Evo
EK XTop D5 PWM Revo
Operating System
Keyboard
Mouse
Zowie FK-1
Mouse
Audio
Other
NZXT Sentry 3
cephelix is offline
post #60 of 1557 (permalink) Old 04-08-2015, 07:19 PM
maddangerous's Avatar
Rep: 11 (Unique: 10)
Fractal Design Define R2 modified to 140mm fans, bottom & back grills removed, front refitted to 140mm fans
Very nice. How much of a restriction is the fan.. "grill" built into pretty much every case? Is there much of an improvement in airflow because of the removal of the restriction, or is there more of a noticeable difference in the sound level of the fans while they are moving air? I am interested in doing this myself to both of my cases, but tbh, I'm a tad nervous about it, and do not know what to use for tools. Or how to go about such a thing.
Any tips for that?
Originally Posted by Dwhite311988 View Post
I had recently purchased an Air 540 in Arctic White to do my black/white (mostly white) themed build. I am running an Asus Mark S Sabertooth with the Avexir Sabranco limited edition ram sticks and a Galax GTX 980 Hall of Fame gpu. I know some of that seems irrelevant, but I kind of wanted to give an idea on the theme I have going on here before I ask my questions. I was wondering which black/white fans would be optimal for my case? I am trying to further understand your guides to help choose and set up my fans. Also, I would like a matching cpu cooler that will still allow me to show off my blinking white LED lights on the ram without sacrificing cooling performance? I hear that the mounts for the front intake on the air 540 can slightly restrict the airflow when using two 140mm fans instead of 3 120mm fans. As far as cpu cooler goes, I know there is a Dark Knight II Frostbourne Edition that seems like it may fit well with my theme - http://www.techpowerup.com/180801/xigmatek-dark-knight-frostbourne-edition-cpu-cooler-announced.html. Any suggestions on case fan choice/setup would be greatly appreciated. What is your opinion on the Aerocool Dead Silence case fans? I am also considering the TY-147A fans. I live in the United States, but I don't mind having anything shipped from overseas. Thanks in advance!
Some of this you already know, but here goes.
Your Mark S Sabertooth has about 50-52mm center CPU toward RAM.
Avexir Sabranco is 30mm tall
Cryorig R1 Universal is mostly white and is 48.5mm center CPU to front of 13mm front fan.
Stock fan clears no problem. Using TY-147 or TY-147A fans or some other white fans would move fan over RAM a little.
Not many white coolers out there. I'm not impressed with the Dark Night coolers. Have you considered using white light gray spray paint on a cooler? As long as the top is color matched to your system, the fins hardly show. And by spraying at a steep angle the edges get colored when painting the top of cooler without hindering cooling. We just don't want a lot of paint going between the fins, but on the edges it no problem.
I have never used Aerocool fans so can't really help there. I do use TY-140, TY-143, TY-147 and TY-147A fans and love them all.
I know that these are really more CPU cooler fans, but.. I have Phanteks PH-F140HP and they work great. They're quiet and keep my Phenom II 1090T six core pretty cool when running IBT for 3 hours. I know the CPU cooler comes into play a lot in this though. As case fans.. not sure. I wanted to use them in my case but the design of the mounts in the case are not normal so I could not use them. I'm not trying to step on Doyll's toes or anything, just a suggestion. Maybe he could chime in.
Also, chasing bunnies.. literally?
maddangerous is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
