* * Ways to Better Cooling; Airflow, Cooler & Fan Data..* - Page 9 - Overclock.net - An Overclocking Community
post #81 of 1479 (permalink) Old 04-15-2015, 04:46 PM
Linux Lobbyist
cephelix's Avatar
Rep: 62 (Unique: 47)
Well,an update to my situation. I finally zip-tied a 120mm fan (AP-121L) to the unused pcie slots under my gpu. Must say,it barely fits and i would need to put some padding between the fan and the board. Of significant interest is that it brought my gpu core temps under control. With ambients at 26C(air conditioned room) my gpu temps at stock(core clock 977MHz, memory clock 1250MHz), i used to get 77C core temps on load with case temps getting up to 31C quite fast but with my patented airflow system(lol) i can finally OC my gpu(core clock 1100MHz, core voltage +44 in AB) and i still get the same load temps with case temps taking alot longer to reach 30C. Apparently it seems that my gpu has been recycling it's own exhausted air which causes a fast increase in temps.
Do you think i'd get any better temps by switching to a better fan?looking at the noctua ippc unless i start ordering from overseas. And if so, any suggestions for fans??
Elevated
(22 items)
i7 4790K
Gigabyte Z97X Gaming 7
MSI Vega 56
Kingston Low Voltage Value Ram
Crucial M500 480GB
Western Digital Green 3TB
Seasonic X750
EK Supremacy Evo
Nidec Servo Gentle Typhoons 1850rpm x 8
Alphacool Nexxos XT45 360mm
Alphacool Monsta 240mm
EK Radeon Vega Acetal+Copper Full Cover
EK XTop D5 PWM Revo
Corsair Obsidian 750D
Operating System
Windows 10 Pro 64-bit
Philips 240B1CB 1920 x 1200
Samsung Syncmaster 2443BW 1920 x 1200
Keyboard
Filco Majestouch 2 Ninja TKL
Mouse
Zowie FK-1
Mouse
Barracuda Juggernaut
Audio
Corsair H2100 Wireless Headset
Other
NZXT Sentry 3
cephelix is offline
post #82 of 1479 (permalink) Old 04-16-2015, 07:14 AM
PSILVA's Avatar
Rep: 0
Hi, my first post, i have a LianLi PC7 Plus Se2 case with 5 fans (2 front+1 side+1 rear+1 top) controled by a Zalman MCF1 Plus.
The fans are 1 Noctua NF-P12 and 4 Noiseblocker M12-3.
I have 2 front+side intake and rear+top exhaust
Is this the correct distribution?
I have a i5-4690k with a Noctua NH-12u se2 cooler and i want oc de cpu to 4.4 or 4.6.
Thanks
PSILVA is online now
post #83 of 1479 (permalink) Old 04-16-2015, 07:35 AM - Thread Starter
doyll's Avatar
Rep: 1636 (Unique: 918)
Should be okay. As long as your temps are good. If not, you might be able to use your 5.25" front bays as another intake. This would flow cool air directly to your CPU cooler.
How Heatpipes Work
doyll is offline
post #84 of 1479 (permalink) Old 04-16-2015, 07:51 AM
PSILVA's Avatar
Rep: 0
That is what I did because this case originally only brought one fan in front:thumb:
post #85 of 1479 (permalink) Old 04-16-2015, 08:02 AM - Thread Starter
doyll's Avatar
Have you tried removing the PCIe back slot covers to see if that helps flow air from front to back? I often use an incense stick to see if a vent is drawing air in or pushing air out. wink.gif
doyll is offline
post #86 of 1479 (permalink) Old 04-16-2015, 08:08 AM
PSILVA's Avatar
Rep: 0
I bought the ventilated pci black slots from Lian Li.
I think I can not improve more just changing for better box but for now I get this and see how they run temperatures.
Thanks for the help.
post #87 of 1479 (permalink) Old 04-17-2015, 08:46 AM - Thread Starter
doyll's Avatar
Vented PCI covers will flow half the air the opening flow with no covers. wink.gif
doyll is offline
post #88 of 1479 (permalink) Old 04-20-2015, 11:26 PM
lmarklar's Avatar
Rep: 37 (Unique: 31)
I vote sticky for this thread! Amazing compilation of data.
lmarklar is offline
post #89 of 1479 (permalink) Old 04-22-2015, 12:23 PM
Linux Lobbyist
Calibos's Avatar
Rep: 28 (Unique: 28)
I'm sorry but I patented the PCI slot fan idea back in late 2011. You now owe me substantial royalties wink.gif
https://www.overclock.net/t/1550235/graphics-cards-way-too-hot-even-with-7-case-fans/10#post_23775920
Calibos is offline
post #90 of 1479 (permalink) Old 04-22-2015, 03:39 PM
Linux Lobbyist
cephelix's Avatar
Hahaha....then kudos to you sir...in 2011 i was still using an i5 750 in an nzxt tempest evo case and haven't discovered OCN yet biggrin.gif
Edit:actually looking at the thread, i got the idea from you!!lol...i didnt believe it at first but i thought what the heck,since then i've swapped out the silverstone fan with a gentle typhoon 1850rpm one and my temps dropped further.now with 26C ambients,load temps are around 70C max
Elevated
(22 items)
i7 4790K
MSI Vega 56
Crucial M500 480GB
Seasonic X750
EK Supremacy Evo
EK XTop D5 PWM Revo
Operating System
Keyboard
Mouse
Zowie FK-1
Mouse
Audio
Other
NZXT Sentry 3
cephelix is offline
