Cooler Master Hyper 212 Evo for 6-core Intel 5820k? - Overclock.net - An Overclocking Community
post #1 of 23 (permalink) Old 10-16-2014, 09:32 PM - Thread Starter
overclockerjames's Avatar
Rep: 28 (Unique: 27)
Can the Cooler Master Hyper 212 Evo handle a 6-core Intel 5820k if I put two 120mm fans on it instead just one that came with it?
overclockerjames is offline
post #2 of 23 (permalink) Old 10-16-2014, 10:03 PM
Retired Staff
dman811's Avatar
Location: [email protected] Section - Man Cave - North Carolina
Rep: 120 (Unique: 92)
It'll handle it, I just wouldn't bother trying to OC it.
Still In Beta Folding Team Captain
post-flame-small.gifProudly Folding For Still In Betapost-flame-small.gifHFM Live Stats
Steam: ctxdemon | Origin: DerickM
Signature Worthy Quotes (Click to show)
I romanced Liara in ME 1.
I last minute romanced Garrus in ME 2.
Then in ME 3 I told Liara we were still together right after telling Garrus the same thing. Progressed on with Liara then (unintentionally) had a shower with Traynor and (intentionally) led on Allers.
So am I a bad person or is my female Shepard just easy?
They didn't get kinky no matter what I did. Disappointment.
dman811 is offline
post #3 of 23 (permalink) Old 10-17-2014, 10:07 AM - Thread Starter
Is your i5 760 overclocked?
post #4 of 23 (permalink) Old 10-17-2014, 10:17 AM
jonnyblaze
strong island 1's Avatar
Rep: 134 (Unique: 88)
for right now just to setup my os for benching and doing some memory testing I have a hyper 212 evo on my 5960x. I would say my limit is about 1.325v. I get to around 70-75c max during firestrike. I don't run it for long periods of time but it seems to work ok.
For the amount you spent on the setup I would go for a noctua or aio, but I would say you could get away with evo, really depends on what you want to do.
Hello
Bench Rig
(20 items)
Intel i7 core 5960x
intel i7 core 4770k
Rampage V Extreme
Asus GTX 980 Strix
Asus 780 ti Matrix
G-Skill Trident X
G-Skill Ripjawz 4
Samsung 840 Evo 120gb
Corsair Neutron 120gb
Corsair AX1200
Kingpin Tek 9 Fat GPU Pot
Kingpin F1 Extreme CPU Pot
EK Universal GPU Water Block
EK Supremacy CPU Block
Dimastech Easy v3 Bench and Armaflex
Operating System
Win 7 64 bit
Operating System
Win XP 32 bit
Samsung S27A950D
Other
Gigabyte Z97 SOC Force Motherboard
strong island 1 is offline
post #5 of 23 (permalink) Old 10-17-2014, 10:18 AM
Water-cooler
NBrock's Avatar
Rep: 45 (Unique: 39)
Probably not ideal. I would imagine overclocking is out of the question. What load temps are you getting with stock clocks and something like intel burn in test or prime 95?
NBrock is offline
post #6 of 23 (permalink) Old 10-17-2014, 10:22 AM - Thread Starter
stock with push-pull hyper 212 evo on prime95 and intel burn its hovering low 30s.
At 4.4ghz I pushed it to 1.27v
https://www.overclock.net/t/1511684/here-are-my-5820k-benchmark-results-compared-to-my-old-amd-1055t/30#post_22876967
I've seen up to low 50s but cpu-z has me at 42 at 4.4 and 1.27 volts
http://valid.x86.fr/519zy4
4.4 is a mild overclock for the 5820k, others are getting 4.6 on air and 4.9 on water
https://www.overclock.net/t/1510388/haswell-e-overclock-leaderboard-owners-club
the hyper 212 evo is probably not the best hsf on the market but it's doing very well
post #7 of 23 (permalink) Old 10-17-2014, 10:24 AM
Water-cooler
NBrock's Avatar
As long as your temps stay within the "ideal" operating range I would say you are fine. Not sure what kind of tasks you use your computer for but just watch long term use temps (like rendering or gaming for over an hour or so).
Intel says the tcase is 66.8*c (Case Temperature is the maximum temperature allowed at the processor Integrated Heat Spreader (IHS)).
NBrock is offline
post #8 of 23 (permalink) Old 10-17-2014, 10:25 AM - Thread Starter
what are you clocking it at with 1.325 volts?
I'm at 1.27 to reach 4.4 on a 5820k, cpu-z says it's 42 but I've seen low 50s
post #9 of 23 (permalink) Old 10-17-2014, 10:33 AM
jonnyblaze
I just bought the cheapest air cooler I could find to use to setup my os's for new cpu's and then I move on to more extreme cooling. But right now I am at about 4.4ghz at 1.3v. I can go to about 1.325v, any higher and I think my temps would reach an uncomfortable range. But I have only done a few benches and testing, not a lot of 24/7 use.
With the low voltage you use and a cooler chip you should be fine with the evo.
I also forgot to mention I only have one corsair sp 120 fan on it. A second fan should help.
Hello
Bench Rig
(20 items)
Intel i7 core 5960x
intel i7 core 4770k
Rampage V Extreme
Asus GTX 980 Strix
Asus 780 ti Matrix
G-Skill Trident X
G-Skill Ripjawz 4
Corsair AX1200
Operating System
Win 7 64 bit
Operating System
Win XP 32 bit
Samsung S27A950D
Other
post #10 of 23 (permalink) Old 10-17-2014, 10:49 AM
Retired Staff
dman811's Avatar
Unfortunately not, my board doesn't support OCing, BCLK or otherwise.
dman811 is offline
