What is the pin layout on the ASUS 970 5pin fan connector? - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 11-17-2014, 02:46 PM - Thread Starter
hutt132's Avatar
Rep: 2 (Unique: 2)
I purchased a 5pin female connector to wire a 4pin PWM fan to run off the ASUS 970 5pin connector.
This is what I am guessing is the 5pin layout:
  • Pin1: RPM (Fan 2) 1x Wire
  • Pin2: Ground 2x Wire
  • Pin3: +12V 2x Wire
  • Pin4: RPM (Fan 1) 1x Wire
  • Pin5: PWM 2x Wire
Is this correct?
Pictures of wires on cooler:
Minecraft Towny Survival Server
Website: www.cathalcraft.com
hutt132 is offline
post #2 of 4 (permalink) Old 11-17-2014, 03:09 PM
doyll's Avatar
Rep: 1661 (Unique: 924)
I think that's incorrect, but I need to look at my drawing. It's filed away somewhere and might take me awhile to find, but will post it up when I find it.
doyll is offline
post #3 of 4 (permalink) Old 11-17-2014, 03:51 PM
doyll's Avatar
I'm pretty sure this is the pin-out:
Pin-1 = RPM sensor (from fan #2) 1x wire
Pin-2 = Ground 2x wires here
Pin-3 = +12V 2x wires here
Pin-4 = RPM sense (from Fan #1) 1x wires here
Pin-5 = PWM signal (from VGA header) 2x wires into this pin
The rpm sensor leads are single wire leads in plug.
doyll is offline
post #4 of 4 (permalink) Old 11-18-2014, 12:59 AM - Thread Starter
hutt132's Avatar
Rep: 2 (Unique: 2)
Thank you!
hutt132 is offline
