** Thermlright Le GRAND MACHO is out! ** - Page 42 - Overclock.net - An Overclocking Community
post #411 of 428 (permalink) Old 11-17-2018, 03:02 PM
Meep
Gilles3000's Avatar
Rep: 291 (Unique: 216)
Quote: Originally Posted by rderubeis View Post
so this cooler is so big i had to mount it while my motherboard was mounted in my case. How do they expect you to reach that long screw driver down a dark hole that u cant even see through to tighten it. It took me and a friend over 2 hrs of several tries trying to get the screw to catch. It was a not fun at all. Anyone else have this issue. Any tips to make it easier
Not really, removed and remounted my Macho multiple times a few days ago, never took me more than a minute.
Just line everything up, put the screw on the long magnetic screwdriver that came with it and lower it into the hole, then tighten. Done.
I assume your friend was trying to put in the screw while the hole in the crossbar wasn't aligned with the hole in the mount, ofcource, that won't work very well...
Gilles3000 is offline
post #412 of 428 (permalink) Old 04-13-2019, 08:21 AM
Rep: 1 (Unique: 1)
Guys, how does the LGM RT mount on consumer CPUs? I'm asking this because the coldplate is 40x53 and the CPUs are 40x40~. It goes centered and it has 6.5mm at each end, or it just align to one of the sides and goes off 13mm?
Con any1 give me some insight about this? @doyll ?
Oh!....by the way... https://m.intl.taobao.com/detail/det...6c3153a1O3U7X1
I'm not sure about it, but i think the coldplate on this one is flat.
If the ryzen 3000 has the heat more spread across the IHS due to the new chiplet design, i'm expecting to see some crazy good results with this cooler.
Shenhua is offline
post #413 of 428 (permalink) Old 04-13-2019, 10:46 AM - Thread Starter
doyll's Avatar
Rep: 1636 (Unique: 918)
Normally the mount centered cooler base over CPU IHS.
doyll is offline
post #414 of 428 (permalink) Old 04-15-2019, 05:27 AM
aerial's Avatar
Rep: 36 (Unique: 32)
Let me join the club
Ram clearance:
It is matx z270 board, no issues.
I have some experience with mountaing various thermalright coolers, but fitting that thing while board is inside matx case = pain.
I doubt I'll ever be able to get access to pci-e latch to remove gpu
When it comes to pros of the cooler, fan mounted pretty low, blowing through m2 nvme drive and board vrm is always nice, previously used noctua U12s, small 120mm heatsink, and there was zero air movement around mobo pcb with this thing.
Overall cooler does what macho does best, performs at low rpm, heatsink has very wide gaps for low static pressure air to go through, thats also why it works so well in pure pull configuration when fan is mounted at the rear panel, through air duct.
aerial is offline
post #415 of 428 (permalink) Old 04-15-2019, 07:29 AM
Abula's Avatar
Rep: 37 (Unique: 33)
Sry wrong thread
GAME - Intel i9 9900K | AsRock Z390 Tachi | G.SKILL 32GB DDR4 3200Mhz | Asus RTX2080Ti Strix | Samsung 970Pro 1TB + Samsung 860Pro 4TB
SIM - Intel i7 8700K | AsRock Z370 ITX/AC | Corsair 16GB DDR3000 | MSI RTX2080ti Duke | AData XPG 8200 Pro 1TB
SB - Intel i9 7940X | AsRock X299 Fatal1ty | G.SKILL 32GB DDR4 3200Mhz | Asus GTX1660Ti
WS - AMD 1950X | AsRock X399 Taichi | G.Skill 32GB DDR4 3200Mhz | 9271-8i 22TB Raid6 | Intel 900p 480GB
Abula is offline
post #416 of 428 (permalink) Old 04-15-2019, 07:32 AM - Thread Starter
doyll's Avatar
Hi aerial! Haven't seen you posting in awhile. Nice looking rig. Kinda surprised you had problems mounting cooler. I usually have someone give me a hand to hold cooler in place so it doesn't tip over backwards, then position crossbar and use magnetic tip of screwdriver to hold screws as I place and start them. A few times when I didn't have a 3rd hand I've used a spacer to hold back of cooler from tipping while I got crossbar and screws started, then remove spacer.
doyll is offline
post #417 of 428 (permalink) Old 04-15-2019, 07:37 AM
Overclocker in training
ThrashZone's Avatar
Rep: 46 (Unique: 37)
Hi,
Still think the name is a miss should be mucho grande
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #418 of 428 (permalink) Old 04-15-2019, 07:53 AM
aerial's Avatar
I didn't have that much issues with attaching cooler itself, as with mounting fan clips. As you can see case has psu shroud, and it is really hard to get your fingers there to latch fan clip near motherboard. I initially also tried with gpu installed, but quickly abandoned that idea
This cooler is very bulky and if you work in tight space it can get quite annoying. Mountaing mechanism is pretty oldschool as well, they figured how to make universal mount with same parts, so I guess that cuts costs, but compared to for example noctua, which has nice captive threaded screws with springs, its night and day when it comes to mountaing it.
aerial is offline
post #419 of 428 (permalink) Old 04-15-2019, 08:07 AM
ThrashZone's Avatar
Hi,
Yep mounting this thing is crazy
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #420 of 428 (permalink) Old 04-15-2019, 09:43 AM - Thread Starter
doyll's Avatar
I find the fan clips more of a challenge than cooler mount.
Sure, spring loaded captured screws like Noctua use would be nice, but magnetic screwdriver really does solve the problem quite nicely.
Fan clips are a big more challenging. I've found it best to attach clips to cooler first (before even installing cooler), than clip one side onto fan while tensioning fan toward other side to hold first clip in place and postion fan to clip other side.
Being/going old school (having learned to 'practice/trial-assemble before actual install) only adds a minute or two to build and often eliminates the potential for all kinds of unforceen problems.
I see Thermalright China has released a new version of Le Grand Macho RT. Le Grand Macho RT Rev. B with TY-147BP 600-1800rpm 33.98-90.96cfm, 0.32-3.00mm H2O fan (instead of 1300rpm fan).
doyll is offline
