Is the Noctua NH-D15 still the king of cpu air coolers? (why is it still so good?) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 205 (permalink) Old 12-17-2016, 08:50 AM
Mong Grel's Avatar
Rep: 7 (Unique: 7)
Still use a TRUE copper 120 on the HTPC, just an unusual thing still have around. Have a NH-D14 on the main still that still has never had me really ponder trying a AIO out personally.
Space restrictions always seemed the main reason to go AIO myself, as has been mentioned.
Just thought I'd mention it as an odd thing, even epoxied a copper boss to it and have a guy wire system rigged up on it, weighs about 4 lbs biggrin.gif
I've stuck with the D14 as messing with something else would cost more than it would be worth more or less, and it still works well.
Mong Grel is offline
post #22 of 205 (permalink) Old 02-02-2020, 03:33 AM - Thread Starter
gasolin's Avatar
Rep: 7 (Unique: 7)
Zalman CNPS20X beat's Noctua by a huge margin
https://www.kitguru.net/components/l...ctua-look-out/
gasolin is offline
post #23 of 205 (permalink) Old 02-02-2020, 03:35 AM
The last VRM burner
Rep: 45 (Unique: 27)
4 freaking years old thread with no relevance.
Just - why?
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #24 of 205 (permalink) Old 02-02-2020, 03:42 AM - Thread Starter
gasolin's Avatar
Rep: 7 (Unique: 7)
Why ?
Because we now see a cpu cooler that beats the noctua, not by a few c but more than 5c, noctua isn't the king of air coolers any more.
Rip Noctua NH-D15
gasolin is offline
post #25 of 205 (permalink) Old 02-02-2020, 05:34 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
Sorry, just because one review by some chrome domed talking head who doesn't give us details of test procedure so we know testing is even remotely accurate does't prove anything.
This early there few others that have tested this Zalman, but the one other test I found shows it 2c cooler than D15S which runs 2-3c hotter htan NH-D15. So basically we have another cooler with performance similar to other top tier air coolers. Considering most testing uses room air temp with "room temperature is between 20-23°" often taken at beginning and end of test session means a temp reading of 72c in 20c room would be 75c in 23c room. Also keep in mind they are not testing all coolers the same day .. meaning other variables are in play, like barometric temp, humidity, etc.
Link to other testing:
https://www.tweakpc.de/hardware/test...nps20x/s03.php
doyll is offline
post #26 of 205 (permalink) Old 02-02-2020, 11:20 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 438 (Unique: 291)
Why ?
Rip Noctua NH-D15
And here - https://www.gamezoom.net/artikel/Zal...Review-44709-3 - it can't keep up with the D15 at like noise levels. Bravado statements based on a single review rarely work out well.....
ciarlatano is offline
post #27 of 205 (permalink) Old 02-02-2020, 11:22 AM - Thread Starter
gasolin's Avatar
Rep: 7 (Unique: 7)
Non of them uses a ryzen 3900x
gasolin is offline
post #28 of 205 (permalink) Old 02-02-2020, 11:35 AM
doyll's Avatar
As long as heat is transfered from CPU chip through IHS into cooler base, what CPU it is makes no difference. Heat is heat.
Pay close attention to how testing is done. Does reviewer monitor and record air temp into cooler at same time as they do CPU temp? Because every degree change in air temp into cooler is same degree change in CPU temp at same load and fan speed. So if air temp into cooler is 20-23c in test room resulting temp of 75c in 20c room would be 78c in 23c room. That's 4c of difference because room temp is not constant.
This is why I often preach about reviews not monitoring and recording actual air temp entering cool air at same time they take CPU temps. While there are still plenty of variables in play, at least they could narrow down the results by at 3-4c unknown.
doyll is offline
post #29 of 205 (permalink) Old 02-02-2020, 11:39 AM
ciarlatano's Avatar
Both reviews use a 3900X. You're grasping at straws. There is a thread about the Zalman 20X, your posts would seem to be better suited to that thread.....though no posters there seem high on it, either.
post #30 of 205 (permalink) Old 02-02-2020, 11:48 AM
NewUser16's Avatar
Rep: 54 (Unique: 36)
There is so many variables when testing performance of coolers, especially when people these days trying to squeeze even 2-3 C out of them and call it "The Best"
Besides the speed of fans RPM and their Db, so far you hear that tests are done at certain ambient, but not only ambient is important, but the humidity level as well. If you have e.g. ambient of 25C and 20-30% humidity and then you do the testing with competitive cooler at the same ambient but against 30-40% of humidity, you will see higher temp with higher humidity, so I'm wonder if anyone even tried to get as close as possible in that respect and then compare the # I'm sure you will see a different readings.
NewUser16 is offline
