Is the Noctua NH-D15 still the king of cpu air coolers? (why is it still so good?) - Page 6 - Overclock.net - An Overclocking Community
post #51 of 76 (permalink) Old 03-24-2020, 04:58 AM
Rep: 9 (Unique: 9)
Quote: Originally Posted by Abula View Post
Cant say i have ever tried such a high TDP cpu/load, but ill test a 3950x + GIGABYTE X570 AORUS XTREME with an NH-D15 and HR22 in a week or so, with TY147 / TY143 / NF-A15 and maybe NF-A12x25.
It's probably not gonna be enough. You'll probably reach thermal limit before you even reach 200w power consumption. I'm lf to it tho.
Shenhua is offline
post #52 of 76 (permalink) Old 03-24-2020, 05:30 AM
Fix it till its broke
Owterspace's Avatar
Rep: 6 (Unique: 4)
It’s very easy to exceed 250+ watts on old CPUs like x58 hexacores, new ones seem to limit themselves internally. A quick look at a review shows 3950x pulls a little more power than a stock x5690 which has a stock tdp of 130w, where the 3950x was doing all core boost at 140w. Pretty energy efficient.
3770K @ 4700 1.375v|Le Grand Macho RT/TY-143|Asus P8Z77-V|8GB G.Skill Mix @ 1100 9-11-9-28 2T 1.68v|Intel 545S @ Raid 0|EVGA GTX 980 Classified @ 1500/2001|CM Silent Pro M2 850|FD Meshify C TG
X5690 E.S. @ Stock+Turbo|True Spirit 140 Power/TY147B|Asus Rampage III Formula|10GB G.Skill Mix @ 666 8-8-8-24 1T 1.575v|Intel 520|EVGA GTX 970 FTW ACX 2.0 @ 1404/1753|TT TP650|FD Define R4
Owterspace is offline
post #53 of 76 (permalink) Old 03-24-2020, 06:49 AM
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
Rep: 163 (Unique: 127)
older cpus are easier to cool due to larger node and silicon size
nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴ
TK421 is offline
post #54 of 76 (permalink) Old 03-24-2020, 07:00 AM
Owterspace's Avatar
Rep: 6 (Unique: 4)
Yes. But a bigger cooler won’t get your smaller cpu to run cooler. It’s just going to run hot regardless of what you do. Ask those guys with high dollar loops on their 9900K etc what kind of core temps they see.
post #55 of 76 (permalink) Old 03-24-2020, 09:54 AM
doyll's Avatar
Rep: 1683 (Unique: 934)
True, some of the newer chips are much small. But their effect on cooling is not as much a problem as some like to make it sound. Sure, their smaller surface effects heat transfer, but more often than not the problem is not just heat transfer from chip to IHS, but poor chip to IHS seat and/or IHS to cooler/waterblock seat that is limiting heat transfer. Then it depends on if chip to IHS is solder or TIM. Obviously soldered is much harder to delid and do a better seat. If it's TIM then delid and re-seating chip to IHS, lapping IHS flat if there is not a good print to cooler / waterbock (more problematic than many realize) so there is definitely a good seat to cooler / waterblock and heat transfer is rarely a problem .. unless you are really pushing a lot of voltage into chip like some do.
doyll is offline
post #56 of 76 (permalink) Old 03-25-2020, 07:30 AM
Owterspace's Avatar
Rep: 6 (Unique: 4)
Just an example from my limited experience:
My x5690, easy to cool if you have a good cooler, puts out a ton of heat once you start to wind it up. My 3770K, difficult to cool, runs very hot when you wind it up, puts out no heat. 32nm vs 22nm, now take that down to 14nm, I can see those chips being a pita.. and if AMD is down to 12nm, then yeah, I can see why people are getting nowhere fast. That's all she's got captain.
post #57 of 76 (permalink) Old 03-25-2020, 08:44 PM
Rep: 0
I heard the new NH-U12A is better than the NH-D15 despite being smaller due to its additional heat pipe and higher performance fans. Is this true?.
PCGamingGuy is offline
post #58 of 76 (permalink) Old 03-25-2020, 10:32 PM
NewUser16's Avatar
Rep: 53 (Unique: 36)
It’s not better by any means. NH-U12A has to spin its fans much higher RPM’s to get close to the performance of D15, which normally would up the noise level, but the new U12 fans are very quiet, even at high speeds so It’s very good cooler/fan combination, but It’s not better.
NewUser16 is offline
post #59 of 76 (permalink) Old 03-27-2020, 07:37 AM
doyll's Avatar
What NewUser16 said.
I would even go so far as to say many other bigger coolers definitely have more cooling ability at lower noise levels.
doyll is offline
post #60 of 76 (permalink) Old 04-01-2020, 08:08 PM
- Insanity Beckons -
Elrick's Avatar
Rep: 176 (Unique: 91)
Quote: Originally Posted by doyll View Post
Indeed, while it's not the only 'king' out there it is one of the best. Only downsides are higher price and baby-poo brown colors.
YES but when you have them born so small, the colour of their poo isn't what's so tragic, it's the smell. Truly horrifying on every level. Yes you get use to the smell and cleaning it up all the time but eventually you do understand why this little person has to do it and you do develop a high tolerance to the smell and the way it looks and feels (don't ask).
Trust Noctua in choosing such a lame colour for their fans, ugly choice of colour here but they do still PERFORM on par to most other fans currently being sold. Also Noctua fans are easily available here in my country so choosing another particular fan model isn't easy, due to cost and our complete isolation.
Others with similar performance are
Cryorig R1
Thermalright Silver Arrow all varients
Thermalright TRUE Spirit 140 Power
Thermalright HR22 & Le Grand Macho all varients
Scythe Fuma II
Phanteks PH-TC14PE
be quiet! Dark Rock Pro3 & 4
Alpenfohn Olymp & K2
Noctua NH-D14
Reeven Ouranos & Okeanos
Silverstone HR01
and the list goes on and on.
You missed out mentioning Noctua NH-U12A, a decently performing air cooler due to those very special fans. Also Noctua has the very best CPU attachment 'thingies' supplied able to attach to most other CPU sockets with extreme ease.
Can easily attach any Noctua Cooler far quicker than using any Thermalright or BeQuiet Dark Rock Pros. Just through experience you then understand why Noctua sell far more air coolers than anyone else on Planet Earth.
Elrick is offline
