how to mount corsair H100 original on AMD AM4 ryzen socket? - Overclock.net - An Overclocking Community
post #1 of 17 (permalink) Old 02-26-2018, 07:26 PM - Thread Starter
>^o.o^<___/
1TM1's Avatar
Rep: 21 (Unique: 15)
I am looking for advice if someone has made a bracket to mount an old but working h100 cooler on a ryzen chip AM4 socket.
I do have the corsair AM4 mounting kit with a round hole but it is for newer models like h100i and not for the old h100 with a square peg.
alternatively if someone has unneeded AMD bracket from their old h100 AIO cooler I would gladly pay postage to try that way.
1TM1 is offline
post #2 of 17 (permalink) Old 02-27-2018, 01:53 AM
poah's Avatar
Rep: 6 (Unique: 5)
if the bracket comes off then you should be able to fit an AM4 bracket from any of the other asetek based coolers of the same generation.
poah is online now
post #3 of 17 (permalink) Old 02-27-2018, 02:21 AM
R2D2C4Z9
D1namis's Avatar
Rep: 2 (Unique: 2)
D1namis is offline
post #4 of 17 (permalink) Old 02-27-2018, 06:16 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 422 (Unique: 282)
You can try customer service at coolitsystems.com. They would be the one making the kit if it exists.
It's not an Asetek, it's a CoolIt. They don't use the same mounting kit or one that is even remotely similar.
ciarlatano is offline
post #5 of 17 (permalink) Old 02-27-2018, 08:02 AM
doyll's Avatar
Rep: 1678 (Unique: 932)
What ciarlatano said.
Here is list of CLCs by brand and model with who actually manufactured them:
https://www.overclock.net/forum/23781217-post80.html
Here are links to where much of that data came from
https://www.gamersnexus.net/guides/2...d-coolers-oems
https://www.gamersnexus.net/guides/2...work-deep-dive
They clearly show all of H100 series except H100i GTX were all made by CoolIT
doyll is offline
post #6 of 17 (permalink) Old 02-27-2018, 08:15 AM
TheHorse's Avatar
Rep: 21 (Unique: 17)
What precisely the hell is wrong with these cooler producing companies that a year after release there's still almost no AM4 support, and customers have to go out of their way to find a bracket that fits the AM4 socket and their cooler properly? I'm pretty sure for intel they have coolers released for new sockets BEFORE they even come out and basically every cooler has a bracket option for a new intel socket within a month.
TheHorse is offline
post #7 of 17 (permalink) Old 02-27-2018, 08:40 AM
Hey I get one of these!
KyadCK's Avatar
Rep: 315 (Unique: 220)
The bit where the OG H100 was released in 2011 and came with a 5 year warranty.
But it's irrelevant anyway, because the OG H100 used the AM2 mounting clips... and AM4 is the exact same size when it comes to those clips, so it would work just fine.
Forge
(15 items)
AMD Ryzen R9 3900X
Gigabyte X570 Master
AMD 5700XT PowerColor Devil
32GB G.Skill TridentZ Neo (2x16GB 3600Mhz/C16)
Intel 900P 480GB
Corsair AX1200
Corsair H150i
Phanteks Evolv X
Operating System
Windows 10 Enterprise x64
2x Acer XR341CK
Keyboard
Corsair Vengeance K70 RGB
Mouse
Corsair Vengeance M65 RGB
Audio
Sennheiser HD700
Audio
Sound Blaster AE-9
Audio
Audio Technica AT4040
KyadCK is offline
post #8 of 17 (permalink) Old 02-27-2018, 09:20 AM
doyll's Avatar
Seems your entire post is irrelevant.
No idea where you are getting your information, but AM2 and AM4 are not at all the same mount.
One does not work for the other.
doyll is offline
post #9 of 17 (permalink) Old 02-27-2018, 09:51 AM
KyadCK's Avatar
The clips. No one cares about the holes, it doesn't use the holes.
http://www.corsair.com/ru-ru/blog/20...mounting-guide
Forge
(15 items)
AMD Ryzen R9 3900X
Intel 900P 480GB
Corsair AX1200
Corsair H150i
Phanteks Evolv X
Operating System
2x Acer XR341CK
Keyboard
Mouse
Audio
Sennheiser HD700
Audio
Sound Blaster AE-9
Audio
KyadCK is offline
post #10 of 17 (permalink) Old 02-27-2018, 10:14 AM
KyadCK's Avatar
$16 if you pick it up off Corsair. Their shipping isn't the fastest, but it should work fine.
Forge
(15 items)
AMD Ryzen R9 3900X
Intel 900P 480GB
Corsair AX1200
Corsair H150i
Phanteks Evolv X
Operating System
2x Acer XR341CK
Keyboard
Mouse
Audio
Sennheiser HD700
Audio
Sound Blaster AE-9
Audio
KyadCK is offline
Tags
am4 , Amd , bracket , Corsair , h100
