5 pin gpu fan on 4 pin header - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 10-10-2018, 12:35 PM - Thread Starter
Linux Lobbyist
Rep: 0
Hey, so my blower style PNY GTX 970 gets pretty hot and loud. My friend gave me his dead Asus GTX 970 and I tried to connect the fan to my current gpu which has a 4 pin header. It connects (because part of the header on the gpu is broken) and the fans spin but I dont know if this setup could cause any trouble. Can leave it like that or should I get some kind of adapter? If so which one? Thanks for the help. Pic attached of the fan header attached. Sorry if all of this sounds stupid I'm pretty new to this. Thanks in advance.
Iloveramen is offline
post #2 of 10 (permalink) Old 10-10-2018, 03:00 PM
Melcar's Avatar
Rep: 637 (Unique: 439)
The extra pin is for rpm sensing (usually). What will matter in this case is the order and position of the colored cables. Check the fan plug on your original cooler and see it the colors match on the Asus one.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
CM Storm QuickFire TK
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #3 of 10 (permalink) Old 10-11-2018, 01:52 AM - Thread Starter
Linux Lobbyist
Rep: 0
The cables on the original one are all black. So I can't match anything.
post #4 of 10 (permalink) Old 10-11-2018, 05:30 AM
doyll's Avatar
Rep: 1682 (Unique: 933)
The image you posted clearly shows colored wires going into plug.
I'm pretty sure this is the pin-out:
Pin-1 = RPM sensor (from fan #2) 1x wire
Pin-2 = Ground 2x wires here
Pin-3 = +12V 2x wires here
Pin-4 = RPM sense (from Fan #1) 1x wires here
Pin-5 = PWM signal (from VGA header) 2x wires into this pin
The rpm sensor leads are single wire leads in plug.
At least that was the pinout on Asus GPU I had.
doyll is offline
post #5 of 10 (permalink) Old 10-11-2018, 06:20 AM - Thread Starter
Linux Lobbyist
Rep: 0
[IMG class=inlineimg]/forum/images/smilies/headscratch.gif[/IMG] The image you posted clearly shows colored wires going into plug.
He asked me to match the colours with the original fan plug. Which are all black. Am I able to plug it in without problem? The red cable would be left unplugged
post #6 of 10 (permalink) Old 10-11-2018, 08:48 AM
Melcar's Avatar
The red cable goes to one of the RPM sense pins? If that's the case and the fans spin then you should not have a problem. CHeck fan speeds and if they react to GPU temperatures properly.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #7 of 10 (permalink) Old 10-11-2018, 08:48 AM
Melcar's Avatar
The red cable goes to one of the RPM sense pins? If that's the case and the fans spin then you should not have a problem. Check fan speeds in Windows and if they react to GPU temperatures properly.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #8 of 10 (permalink) Old 10-11-2018, 10:54 AM - Thread Starter
Linux Lobbyist
Rep: 0
I just checked everything and the fans work as intended! Thanks a lot!
post #9 of 10 (permalink) Old 10-11-2018, 11:09 AM
doyll's Avatar
What is the pin order you are using? Same as I supplied or different? Normally red is a power lead, but computer wiring often does not use normal wire color coding.
doyll is offline
post #10 of 10 (permalink) Old 10-12-2018, 08:54 AM - Thread Starter
Linux Lobbyist
Rep: 0
The pin layout is the same. But strangely after reapplying thermal paste and reconnecting the fans they run at 100% all the time. Weird.
Edit: Fans run normal again. Just had to replug it again.
Tags
Fans , Gpu
