* * Thermalright's new TF6 and TF8 Thermal Paste * * - Page 6 - Overclock.net - An Overclocking Community
post #51 of 55 (permalink) Old 09-10-2019, 02:41 PM
homestyle's Avatar
Rep: 87 (Unique: 80)
Also, why does Thermalright recommend spreading it into a thin layer?
That is counter to most of the test I've seen. Are they saying this to be idiot-proof, and make sure you don't put too much or too little TIM?
homestyle is offline
post #52 of 55 (permalink) Old 09-10-2019, 04:29 PM
Fix it till its broke
Owterspace's Avatar
Rep: 2 (Unique: 2)
Where are you guys getting air bubbles from? That’s what happens when you lift your cooler to check your Tim print. You aren’t supposed to put your cooler back on when you do that. Your supposed to clean it off and reapply.
3770K @ 4600 1.3v/Le Grand Macho RT/TY-143/TF8
Asus P8Z77-V/8GB G.Skill BBSE @ 1066 9-9-9-24 2T 1.65v
EVGA GTX 980 Classified @ 1495/2001
Intel 545S 256 @ Raid 0, WD 1TB Black, Toshiba 1TB
Fractal Design Meshify C TG/5x 120x38 Panaflo/CM Silent Pro M2 850
Owterspace is offline
post #53 of 55 (permalink) Old 09-10-2019, 06:06 PM
Contiusa's Avatar
Rep: 6 (Unique: 6)
Perhaps for you to spend more paste and buy another tube? For sure, no matter how pro you are, you are going to spend more paste spreading it. That OC pro in the video seems to be spreading peanut butter on a slice of bread.
-- Win10 | i5-9600K | Barrow 360 Push Pull | GA-Z390-UD | GTX 1060 GamingX | Corsair 16GB 3200Mhz | Samsung 970 EVO 250GB | WD Velociraptor 1TB | RM 750W | Carbide 300R --
-- Win7 64bits | FX-6300 | 9900NT | GA-970A-D3P | Sapphire HD 6870 | Trident X 8GB 2400Mhz | GS 128GB | HX650W | Sileo 500 --
Contiusa is offline
post #54 of 55 (permalink) Old 09-10-2019, 11:47 PM
homestyle's Avatar
Amazon says it has carbon microparticles in TF8.
It sounds like the same type of material in IC Diamond that will stain and remove the markings on the cpu.
post #55 of 55 (permalink) Old 09-11-2019, 04:01 AM
Owterspace's Avatar
Rep: 2 (Unique: 2)
IC Diamond has diamonds in it. It doesn’t stain your ihs, it’s like sandpaper. TF8 is nothing like ICD7. No stains, no marks easy on easy off.
